In a Support discussion tagged activitypub, icaria36 reports that HTML from RSS-imported posts breaks when federated via ActivityPub, appearing as malformed plain text on Mastodon — despite the intent to share podcast episodes across platforms with minimal effort. Screenshots show the discrepancy between clean Discourse rendering and broken Mastodon display. angus explains that ActivityPub content is federated as HTML by default and suggests a future custom filter might address this, though it’s not a top priority. icaria36 asks if this could be pushed via Marketplace, and tobiaseigen encourages posting there. nightpool1 suspects a bug — complex HTML should degrade to plain text, not broken markup — and notes missing images and a 406 error when accessing the post via ActivityPub. icaria36 offers to federate a test post for debugging and confirms plans to submit the request to Marketplace.
Ok, this is a potential corner case but maybe still interesting.
Posts imported with rss-polling contain HTML code. If these posts are federated, most of the HTML code breaks and goes through as plain text.
In an ideal world, at least links would be translated. But if this is too much hassle, at the very least it would be good to scrap the HTML code, leaving the text.
A couple of screenshots to illustrate the problem:
Why are we federating posts imported via RSS? The use case is: we are a community of podcasts, we import new episodes via RSS for listeners to like and comment in one place, and we want to offer these podcasts a window to the Fediverse, where they might get more listeners, comments and likes – without adding more work on their busy plates.
Just for your context, when ActivityPub content is federated (from any platform) it is typically federated as HTML. We will alway federate Discourse posts as HTML by default.
What you probably want is a custom filter for ActivityPub content. We may add that at some point soonish, however this is a relatively specific use case, and it’s not at the top of the priority list.
Looking at the screenshot they posted it still seems like there's almost certainly some kind of bug here, although I can't tell if it's on the Mastodon side or the Discourse side.
Even the most complex HTML should just turn into plain-text when Mastodon parses it. Not whatever broken HTML markup is going on here.
Also, when I view this thread from https://socialhub.activitypub.rocks/t/remove-html-code-from-activitypub-federated-posts/5293, why are the images missing?
Unfortunately, I can't view the topic itself in ActivityPub to determine who's at fault here, the server returns 406 Not Acceptable:
Thank you very much @nightpool for looking into this. I can see the post in my Mastodon timeline because I’m following the account but I don’t know how to get a URL that is not the original post on Discourse. If you want, you can follow the actor and then I can federate another post for testing purposes.
In any case, I plan to submit this request to Marketplace soonish.
