기본 페르소나/봇을 삭제하는 방법은?
I translated all the prompts to my language because Discourse ships them only on english.
So I have a lot of users and personas that I will never use because I can use the prompt in english but adding ‘reply on the question language’ and it’s not possible to edit them either.
Can I remove them using the console? May I ask for a simple guide for someone non-technical like me?
No, they are part of the plugin code. Also you want then available if we update something like the structured output format and you need to update your version.
Thanks for your reply, I totally understand.
Perhaps we need something like custom texts, that should inform for changes and allow us to edit?
Yeah, eventually if we do a breaking change we will need to build something like that.
