Users are reporting that MathJax expressions are not rendering correctly within poll options, despite working in topic bodies and the poll preview. ascension.forum initially reported the bug and provided a live example of the issue Just a random math exercise - . It was noted that this is a known issue with a related post on Discourse Meta Rendering math inside polls. joffreyjaffeux committed to a fix, sharing the PR herejoffreyjaffeux described the fix as a
Not sure if this should be a bug for the MathJax plugin, but when you add a MathJax expression to a poll, it won’t be rendered correctly (MathJax renders properly in topics body and it also works in the poll preview panel, see screenshot below).
Poll is an old plugin and it’s probably doing something incorrect which forces me to do this here. I saw the issue but honestly didn’t dig the root cause as this interaction discourse-math/poll is quite a niche subject in our codebase and couldn’t justify spending days on it.
Thank you @j.jaffeux for sharing the PR! Even though I don’t know how the PR solves the issue, but the elegance and the speed of the change are impressive!
Hi @j.jaffeux, I tried the latest build with your fix, and it works as expected. Only issue is that the fix seems not to be applied to on the Vote results view. This is a minor issue but just want to share here in case you are interested.
