Уведомление о неотвеченной теме
Hello,
Is there a way to set up a notification/reminder to myself or a group of moderators when a topic is left unanswered for longer than x hours?
I suppose not every topic needs it (so an exclusion from certain categories would be useful), but I’m generally searching for a solution that may help us not overlook topics that are “hanging” without any reaction from our side for too long.
PS. I’ve searched through the forum, but I only encountered topics from ancient times, like 2017(sic!) I suppose something may have changed since then :slightly_smiling_face:
Thanks!
I don’t think there is anything default available for this, but maybe it can be done with
They have this trigger
Which maybe you can re-use in a custom script in combination with a filter such as unsolved?
Worth looking into imo, but will take some dev work probably.
Simpler approach might be looking at auto-bump settings:
CleanShot 2025-08-07 at 11.58.39
It’s not exactly what you want, but you could make open topics in a certain category bump daily, to draw attention. As long as you’re diligent with closing them when resolved (or setting an auto-close), that might work.
But if you want it specifically for moderators, and specifically a notification, I think the automation plugin is your best bet atm.
2 лайка
