Шаблоны для Url Composer
There’s been a lot of discussions about having composer templates for tags. That didn’t work in my use-case so i built this instead. It can be used for that at a push, modified slightly to work for tags too, or if you add something to your discourse that modifies the url to trigger the templates where you want them.
This sniffs the url and puts a template in the composer anytime it finds it. So you could put developers in and that would show any time the tag developers is used.
You’d normally want to be more specific though and use tag/developers or an intersection like /tags/intersection/developers/pineapple
You can use it for categories like c/general which would recreate and override the categories template option, so you could get creative and use it as a conditional template in a category.
You can use it on only the 1st post, only replies, or all posts in a thread:
You can have the template text appear:
  • only if there’s no topics/threads at that location yet
  • all the time
To-do: only put a template in if the user visiting hasn’t posted a topic at that location, even if others have. Sadly i ran into difficulties with this and ran out of time for this functionality, for now.
Install this theme component
Github: GitHub - focallocal/url-composer-templates: Reads url strings and adds template text to the composer if a match is found
URL Composer Templates
A Discourse theme component that pre-fills the composer with template text based on URL parameters. Designed to work seamlessly with Docuss to provide context-specific templates for different types of interactions.
Features
  • URL Parameter Support: Automatically detects ?composer_template=X in URLs and applies the corresponding template
  • Multiple Template Types: Configure up to 6 different templates for different purposes (report, going, invite, custom templates)
  • Auto-Open Composer: Optionally auto-opens the composer when visiting a Docuss link with no existing threads
  • Flexible Application: Templates can apply to first post only, all replies, or both
  • Session Persistence: Uses sessionStorage to maintain template selection across page navigations
  • Debug Mode: Enable detailed console logging to troubleshoot template application
Installation
  1. Install the theme component on Discourse:
    • Go to Admin → Customize → Themes
    • Click “Install” → “From a Git repository”
    • Enter: https://github.com/focallocal/url-composer-templates
    • Add the component to your active theme
  2. No plugin rebuild required! The composer_template parameter support already exists in dcs-discourse-plugin and dcs-client.
  3. Deploy your React app (fl-maps) with the updated DCSLink components that pass the composerTemplate prop.
  4. Configure templates in the component settings (Admin → Customize → Themes → your theme → url-composer-templates → Settings).
Configuration
Template Settings
Each template has three configuration options:
Template 1 (Report)
  • template_1_id: report - The URL parameter value to trigger this template
  • template_1_text: The text to pre-fill in the composer
  • template_1_use_for: first_post - Apply only when creating new topics
Template 2 (Going)
  • template_2_id: going - For “I’m going” type interactions
  • template_2_text: Pre-filled text for going confirmations
  • template_2_use_for: all_replies - Apply to all replies (not first posts)
Template 3 (Invite)
  • template_3_id: invite - For invitation interactions
  • template_3_text: Pre-filled text for invitations
  • template_3_use_for: all_replies - Apply to all replies
Templates 4-6 (Custom)
  • Disabled by default
  • Can be enabled and customized for specific use cases
  • Configure ID, text, and application scope as needed
Auto-Open Settings
  • enable_auto_open_composer: true - When enabled, automatically opens the composer if:
    • A Docuss link is clicked (URL contains ?composer_template=X)
    • No threads exist yet for that tag combination
    • Helps users start discussions immediately
Debug Mode
  • debug_mode: false - Enable to see detailed console logs with emoji prefixes:
    • :artist_palette: Template application logs
    • :rocket: Auto-open composer logs
Docuss Integration
Automatic Integration
The url-composer-templates component is designed to work automatically with Docuss. When you have both:
  • This component installed on your Discourse instance
  • The updated Docuss client and plugin (with composer_template support)
Templates will be automatically applied based on:
  1. Interact Mode:
    • DISCUSS mode → Uses triggerId hints (going, invite) or defaults to report
    • COMMENT mode → Uses report template
Custom Templates via HTML Attributes
For more precise control, you can specify templates directly in your HTML using the data-dcs-composer-template attribute:
<!-- Example: Report button -->
<div class="dcs-trigger"
     data-dcs-trigger-id="issue-report"
     data-dcs-interact-mode="DISCUSS"
     data-dcs-composer-template="report">
  Report an Issue
</div>
<!-- Example: Going button -->
     data-dcs-trigger-id="event-rsvp"
     data-dcs-composer-template="going">
  I'm Going!
</div>
<!-- Example: Invite button -->
     data-dcs-trigger-id="invite-friends"
     data-dcs-composer-template="invite">
  Invite Friends
</div>
<!-- Example: Custom template -->
     data-dcs-trigger-id="feedback"
     data-dcs-composer-template="custom1">
  Give Feedback
</div>
Template ID Matching
The component matches template IDs from the URL parameter with the configured template IDs:
URL Parameter Template Setting Default Purpose
?composer_template=report template_1_id Bug reports, issues
?composer_template=going template_2_id Event RSVPs
?composer_template=invite template_3_id Invitations
?composer_template=custom1 template_4_id Custom use
?composer_template=custom2 template_5_id Custom use
?composer_template=custom3 template_6_id Custom use
How It Works
Template Application Flow
  1. URL Detection: When a user navigates to a URL with ?composer_template=X, the component stores the template ID in sessionStorage
  2. Composer Interception: When the composer opens, the component checks for a stored template ID
  3. Template Matching: Finds the matching template based on ID
  4. Scope Validation: Checks if the template should apply (first post, reply, or both)
  5. Text Insertion: Pre-fills the composer with the template text
  6. Cleanup: Marks the template as applied to prevent re-application
Auto-Open Flow
  1. Parameter Detection: Checks if URL contains ?composer_template=X and auto-open is enabled
  2. Topic Search: Searches for existing topics with the current tag combination
  3. Composer Opening: If no topics found, automatically opens the composer
  4. Template Application: The template is then applied via the normal flow above
Example Use Cases
Event Website
# settings.yml
template_2_id: "going"
template_2_text: "I'm planning to attend! 🎉\n\nLooking forward to seeing everyone there."
template_2_use_for: "all_replies"
template_3_id: "invite"
template_3_text: "I'd like to invite friends to this event.\n\nWho I'm inviting:\n- \n\nWhy they should come:\n"
template_3_use_for: "first_post"
Issue Tracking
template_1_id: "bug"
template_1_text: "**Bug Description:**\n\n**Steps to Reproduce:**\n1. \n2. \n3. \n\n**Expected Behavior:**\n\n**Actual Behavior:**\n"
template_1_use_for: "first_post"
template_4_enabled: true
template_4_id: "feature"
template_4_text: "**Feature Request:**\n\n**Use Case:**\n\n**Proposed Solution:**\n"
template_4_use_for: "first_post"
Community Engagement
template_1_id: "question"
template_1_text: "**My Question:**\n\n**What I've Tried:**\n\n**Additional Context:**\n"
template_2_id: "answer"
template_2_text: "Here's what worked for me:\n\n**Solution:**\n\n**Why it works:**\n"
Troubleshooting
Templates Not Applying
  1. Check URL Parameter: Ensure the URL contains ?composer_template=X where X matches a template ID
  2. Enable Debug Mode: Turn on debug_mode in settings to see console logs
  3. Verify Template Scope: Check if use_for setting matches your action (creating topic vs replying)
  4. Clear SessionStorage: Open browser console and run: sessionStorage.clear()
Auto-Open Not Working
  1. Check Setting: Ensure enable_auto_open_composer is set to true
  2. Verify URL: Auto-open only works when URL contains ?composer_template=X
  3. Check Existing Topics: Auto-open only triggers when NO topics exist with the tag combination
  4. Enable Debug Mode: Look for :rocket: emoji logs in the console
Wrong Template Applying
  1. Check Template IDs: Ensure your URL parameter matches the template ID exactly (case-sensitive)
  2. Verify Priority: If multiple templates could match, the first matching template is used
  3. Clear Session: SessionStorage might contain old values: sessionStorage.clear()
Docuss Integration Issues
  1. Update Docuss: Ensure you have the latest versions of:
    • dcs-client (with composerTemplate support in HtmlBased.js)
    • dcs-discourse-plugin (with URL parameter generation in DcsIFrame.js.es6)
  2. Check HTML Attributes: Verify data-dcs-composer-template is set correctly on triggers
  3. Inspect Network: Check browser DevTools Network tab to see if URL parameters are being added
Version History
v1.0.0 (Current)
  • Initial release
  • Support for 6 configurable templates
  • URL parameter-based template selection
  • Auto-open composer for Docuss links
  • SessionStorage persistence
  • Debug mode for troubleshooting
Contributing
Found a bug or have a feature request? Please open an issue on the GitHub repository.
License
This component is open source and available under the MIT License.
Credits
Developed by Andy@Focallocal and works well with Docuss - a system for embedding Discourse discussions into any website.
1 лайк
So this component must be used with that plugin installed and a React app setup? Is there any more information on this? Perhaps this should be iterated more strongly.
2 лайка
Thanks for pointing that out @NateDhaliwal
No, it just sniffs the url looking for a specific string and pre-fills the the composer with one of a few a templates when it finds that string.
The Docus plugin puts that string into urls as one of its functions, but this component will work with any string or delivery mechanism someone wants to use, so it can stand alone. I’ll update the readme to explain that.
For example, you could tell it to look for: ‘/tag/introductions’ and it would become a tag template component. Or you could use it as i am to put that template into tag-intersections, like: tags/intersection/introductions/webdevs
I’ll move the string it looks for into the admin section so it’s easier for others to modify and use without digging into the code.
1 лайк
Took a lot longer than i intended, but this component is fully working now.
1 лайк
Looks good. But maybe some screen shots of settings as it looks cleaner than the copy blocks.
Very nice. I have a lot of work to do now. :grin:
1 лайк
