Drag, resize, and gesture primitives
ui-kit ships the input-driven gesture primitives: dragging a payload onto a
target, resizing a region, and reading a swipe or a pointer drag. This page is
the usage reference. Each primitive’s own TSDoc carries the fine print for every
argument; what follows is how to put them together.
Basic usage
A drag needs a source that carries a payload and a target that accepts its type.
import { hash } from "@ember/helper";
import dDragAndDropSource from "discourse/ui-kit/modifiers/d-drag-and-drop-source";
import dDragAndDropTarget from "discourse/ui-kit/modifiers/d-drag-and-drop-target";
<template>
  <div {{dDragAndDropSource type="card" data=(hash id=@card.id)}}>
    {{@card.title}}
  </div>
  <div {{dDragAndDropTarget accepts="card" onDrop=@onDrop}}>
    Drop a card here
  </div>
</template>
@action
onDrop({ source, position }) {
  // source.data is what the source attached; position is "before" or "after"
  this.file(source.data.id, position);
The type string is the whole matching vocabulary. A target engages only for
sources whose type is in its accepts, and everything else drags straight
over it.
Picking a primitive
I want to… Use
Move something onto a target and transfer a payload dDragAndDropSource + dDragAndDropTarget
Take page content the browser started dragging, with no source dDragAndDropTarget with adopts
Take files, HTML, URLs, or text from outside the window dDragAndDropExternalTarget
Upload the files somebody dropped the upload pipeline, not the modifier above
React to a drag without becoming a drop target dDragAndDropMonitor
Scroll a container while a drag hovers near its edge dDragAndDropAutoScroll
Open or reveal something once a drag has hovered it a moment dDragDwell
Render from the in-flight drag the dragAndDrop service
Press, move, and track a value continuously dPointerDrag
Put an accessible handle between two regions DResizeSeparator
Resize on one axis with your own element and semantics dResizeEdge
Resize a box from its edges and corners DResizeHandles
Detect a directional flick dSwipe
Know that an element changed size dOnResize, which is not a gesture
dDragAndDropSource
Marks an element draggable and attaches the payload.
Arguments
Argument Type Purpose
type string, required The discriminator targets filter on. Overwrites any type in the payload.
data object Static payload, read back as source.data.
getInitialData () => object Dynamic payload, called once just before dragstart.
dragPreview Element or render function What the drag image shows. Defaults to the source element.
dragPreviewOffset {x: string, y: string} CSS lengths pushing a rendered preview clear of the pointer.
effectAllowed DataTransfer["effectAllowed"] What the drag permits. Defaults to "move".
dragHandle Element An element inside this one that a drag must start from.
disabled boolean Detaches the registration. A drag in flight still finishes.
canDrag (feedback) => boolean Returning false blocks the drag from starting.
onDragStart (event) => void Fires once the drag is confirmed.
onDragEnd (event) => void Fires at the end of every drag, landed or abandoned.
onDrop (event) => void Fires only for a drag that ended on a target.
The element carries data-drag-source while registered and --dragging for the
duration of the drag. Style and assert against those, never against
draggable: that attribute sits on whichever element was registered, which is
the handle when there is one.
Dragging by a handle
Without a handle the whole element starts a drag, so text inside it cannot be
selected and a touch press meant to scroll starts a drag instead. Pass the
handle element itself, captured with a modifier, not a selector.
import Component from "@glimmer/component";
import { tracked } from "@glimmer/tracking";
import { modifier } from "ember-modifier";
export default class Row extends Component {
  @tracked gripElement;
  captureGrip = modifier((element) => {
    this.gripElement = element;
    return () => (this.gripElement = undefined);
  <template>
    <li {{dDragAndDropSource type="row" dragHandle=this.gripElement}}>
      <span {{this.captureGrip}} aria-hidden="true"></span>
      {{@item.label}}
    </li>
  </template>
The row stays the drag body: it keeps data-drag-source, it is what a target
reports as source.element, and it is what the default preview photographs.
Custom previews
An Element preview is photographed in place. A render function mounts a fresh
preview into an isolated offscreen container, so nothing around the source
bleeds into the drag image, and may return a cleanup function.
dragPreview = ({ container, element }) => {
  const node = element.cloneNode(true);
  container.append(node);
  return () => node.remove();
dDragAndDropTarget
Accepts element drags and reports where the drop would land.
Arguments
accepts string | string[] Which source types engage the target. Omit to accept any.
adopts NativeDragAdoption | NativeDragAdoption[] Also take browser-started page content. See below.
acceptsSelf boolean false refuses a drop whose dragged element is this element.
position "before" | "after" | "inside" A fixed position, which wins over midpoint math.
axis "vertical" | "horizontal" Which midpoint is measured. Defaults to "vertical".
indicator boolean false suppresses the indicator class.
canDrop (feedback) => boolean Gate asked while hovering. false defers to an ancestor.
dropEffect DropEffect or (feedback) => DropEffect The cursor feedback the browser shows.
getData () => object Metadata attached to the drag’s record of this target.
getIsSticky () => boolean Whether the target stays current after the pointer leaves.
onDragEnter (event) => void This target became the deepest accepted target.
onDrag (event) => void Throttled, while it stays the deepest accepted target.
onDragLeave (event) => void It stopped being the deepest accepted target.
onDrop (event) => void The drag was released here.
A registered target carries data-drop-target.
Positions and indicator classes
A target resolves before, after or inside and paints one class while a
compatible drag is over it:
Position Vertical axis Horizontal axis
before --drag-above --drag-left
after --drag-below --drag-right
inside --drag-inside --drag-inside
Positions are logical, not physical. In a right-to-left row, before still
means the reading-order start, and the class flips to --drag-right so the
indicator stays under the pointer. Consumers need no special case.
Nesting
Only the deepest accepted target receives lifecycle callbacks, so nested targets
never handle one drop twice. The cost is that an ancestor stops indicating the
moment a descendant claims the drag. When a container has to stay highlighted
while its descendants activate in turn, render from the service instead and
leave drop handling to the descendants.
A descendant that answers false from canDrop is not accepted, so the drop
falls through to the nearest ancestor that does accept it. That is how a target
hands back a region it does not own, such as an edge band that belongs to the
enclosing container. Eligibility is sampled while the drag hovers and is not
asked again at the release, so the answer a target last gave is the one that
counts.
Adopting browser-started drags
The browser starts drags on ordinary page content, such as a link or an image,
which registers no source and could not. An adoption lets a target take those
too. It names the kind of drag and supplies a predicate:
export const WEB_LINK = {
  type: "web-link",
  match: ({ element }) => Boolean(element.closest("a[href]")),
<div {{dDragAndDropTarget adopts=WEB_LINK onDrop=this.addLink}}></div>
From there it is an ordinary drag: the same callbacks, the same positions, the
same indicator. The adoption’s type becomes source.type, so a monitor or
auto-scroll filters on it like any other type, and the native payload arrives on
source.native with the same reader API an external target hands you. Its
items list is always empty, because the handles go inert when dragstart ends.
Three rules are not guessable from the signature:
  • Adoption is resolved once for the page, not per target. At dragstart the
    first live adoption whose predicate matches names the drag, and every target
    listing that name accepts it. Two adoptions sharing a name must therefore share
    a predicate. Declare one as a module constant and offer it from each target.
  • adopts without accepts refuses every registered source. A target that
    named what it wants through adopts is not also asking for everything else on
    the page.
  • It covers only what the browser started on this page. To take the same
    content dragged in from outside the window, pair the target with
    dDragAndDropExternalTarget on the same element.
Adoption deliberately leaves several drags alone: a registered source keeps its
own lifecycle, an element somebody else made draggable keeps its own drag, files
go to an external target, and a text selection is never adopted, including one
held inside an input or textarea. A predicate that throws is reported and
refuses, rather than deciding for the adoptions after it.
Accepts payloads dragged in from another window or another application. It never
sees a drag that began on this page.
Arguments
accepts "files" | "html" | "text" | "urls" or array Which kinds engage the target. Omit to accept any.
position "before" | "after" | "inside" Opts into resolving a position at all.
axis "vertical" | "horizontal" Same, from the pointer against the midpoint.
It shares every kernel argument with the element target: canDrop,
dropEffect, getData, getIsSticky, indicator, and the four lifecycle
callbacks.
Without position or axis the target is one destination rather than a slot:
callbacks receive position: null and the indicator is the single
--drag-over-external class. A registered external target carries
data-drop-target-external.
<div
  {{dDragAndDropExternalTarget
    accepts=(array "urls" "text")
    onDrop=this.acceptLink
></div>
The payload exposes types, containsFiles(), getFiles(), containsHTML(),
getHTML(), containsText(), getText(), containsURLs() and getURLs().
items and getFiles() are only populated at the drop.
This is not the upload path. A file dropped here does not enter upload
validation, progress, retries, or the upload record. Reach for it only when the
consumer genuinely wants the raw payload.
dDragAndDropMonitor
Reacts to an element drag happening anywhere, without becoming a drop target.
types string | string[] Which drag types to watch. Omit to watch all.
onDragStart (event) => void A watched drag began.
onDrag (event) => void Throttled, while it is in flight.
onDrop (event) => void It was released.
The element only anchors the modifier’s lifecycle; a monitor is global.
Scrolls a container while a drag hovers near its edge.
types string | string[] Element drag types that engage it.
externalKinds "files" | "html" | "text" | "urls" or array External kinds that engage it.
axis "vertical" | "horizontal" | "all" Which direction to scroll.
target "element" | "window" Scroll this element or the window.
Element drags and external drags arrive through different adapters, so an
observer that watches both names both: types for the element side,
externalKinds for the external side. accepts stays a drop-taking word.
dDragDwell
Fires a callback once a drag has hovered its element for a delay — a folder
opening under a file held over it — without making the element a drop target.
It watches drags the way a monitor does, for both element drags and, when
asked, external ones, and tests its own rectangle against the pointer. It
never joins the drop-target hierarchy: no indicator, no positions, and it
composes freely with a real target on the same element.
types string | string[] Element drag types to watch. Omit to watch all.
externalKinds external kinds or array External kinds to watch. Omitting it, or naming no kinds, refuses external drags.
delay boolean | number Hover before the dwell fires: true (default) the standard 500 ms, false immediate, or milliseconds.
leaveDelay boolean | number Grace before a fired dwell is undone on leave: true (default) mirrors the entry delay, false immediate, or milliseconds.
canDwell (feedback) => boolean Gates candidacy; shares a drop target’s canDrop feedback shape.
acceptsSelf boolean Whether the element’s own drag may dwell. Defaults to true.
onDwell (event) => void The drag hovered long enough.
onDwellEnd (event) => void The candidacy ended; the place to undo what onDwell did.
<div
  {{dDragDwell
    types="card"
    canDwell=this.canDwell
    onDwell=this.open
    onDwellEnd=this.close
onDwellEnd carries reason ("left" or "drag-ended"), fired (whether
onDwell ran for this candidacy), and droppedHere (whether the drop landed
on a drop target on the element or on one of its descendants — always false
when that subtree registers no target at all) — together the undo predicate: close
again when fired and not droppedHere, and a drop into the element keeps
it open.
The gate runs when a candidacy would start, on every frame while it is
pending, and once more as the dwell fires — but not after: a dwell that opens
a section falsifies its own “only when closed” gate, so after firing only the
rectangle and the types/externalKinds filters decide when the candidacy
ends. canDwell refuses only
on a literal false, after types/externalKinds filtering, exactly like a
target’s canDrop — the two may share one function.
Adoption stays the co-located target’s job: the dwell has no adopts, and an
adopted browser drag answers to its adoption’s declared type in types.
Two limits worth knowing: the rectangle test does not see occlusion — the
dwell answers to the pointer being inside the element’s box, not to the box
being visible under the pointer — and an element drag that leaves the window
freezes its last position, so a pending dwell can fire while the pointer is
outside; the drag’s eventual end delivers the onDwellEnd that undoes it.
createDragDwell, the engine underneath
The modifier wraps createDragDwell, a plain factory re-exported from the
same module, for a consumer driving a dwell directly when it is coordinate-driven
rather than element-bound: one tracker across many discovered elements, or a
sub-rect rule such as a center-third band.
Option Type Purpose
destroyable object Bounds the dwell’s lifetime; usually the owning component.
delay number Milliseconds of hovering before the dwell fires; defaults to 500.
identity (target) => unknown Keys candidacy; defaults to the target itself.
onDwell (target) => void Fires once, with the latest same-identity target.
The returned tracker has two members: update(target) reports the current
candidate (null for none), and reset() cancels and clears, ready for the
next drag.
Semantics worth knowing:
  • One fire per uninterrupted candidacy. Reporting the same identity again never
    pushes the deadline out and never re-fires an already-fired dwell. A new
    identity restarts the full delay, and null clears, so the same identity can
    dwell again after leaving and returning.
  • Silence is not null. A consumer that stops calling update — a monitor
    frame without input, a pointer holding still — leaves the pending dwell
    running. Only an explicit null or reset() cancels it.
  • A drop or teardown ends the drag without a leave, so wire reset() into the
    drop and drag-end paths explicitly. The destructor registered on
    destroyable covers teardown.
  • When the consumer builds a fresh descriptor per report, pass identity to
    name the stable part, or every report reads as a new candidate and the dwell
    never fires.
The dragAndDrop service
The service holds the in-flight drag as tracked state, so a surface can render
from it without wiring a callback.
Member Purpose
currentDrag The in-flight element drag, or null.
currentExternalDrag The in-flight external drag, or null.
isDragging Whether either is in flight.
accepts(types) Whether the element drag’s type is in types.
acceptsExternal(kinds) Whether the external drag carries one of kinds.
currentDrag carries type, data, element, and native for an adopted
drag.
<div class={{if (this.dragAndDrop.accepts "row") "is-drop-zone"}}></div>
Use the service to read and the monitor to respond. Rendering from monitor
callbacks means keeping state the service already owns.
Note that accepts() and acceptsExternal() treat an empty or missing filter
as matching nothing, because a caller that has not decided should not light up
for every drag. A target’s accepts reads the other way: omitting it accepts
everything.
dPointerDrag
Press, move, and release on one element, for a value that tracks the pointer.
It transfers nothing and has no targets.
onDragStart (event, info) => boolean | void The gesture began. Returning false refuses it.
onDrag (event, info) => void The pointer moved.
onDragEnd (event, info) => void The gesture finished.
onDragCancel (event, info) => void It was interrupted rather than finished.
threshold number Pixels of movement before the gesture starts.
draggingClass string Class applied to the element while dragging.
bodyClass string Class applied to document.body while dragging.
cancelCommits boolean Whether a cancel commits the last value.
stopPropagation boolean Whether to stop the pointer events propagating.
touchAction TouchActionToken The touch-action to apply for the gesture.
Always handle onDragCancel. A gesture interrupted by the browser otherwise
leaves whatever onDragStart opened still open.
DResizeSeparator
The default for resizing between two regions. dResizeEdge underneath keeps the
value math, the bounds and the keyboard operation; the separator adds the
accessibility contract on top: role="separator", one tab stop, an
aria-orientation, and live aria-valuenow updates.
label string, required What the separator is called, already translated.
axis "vertical" | "horizontal" "vertical" resizes height. Defaults to "vertical".
side "start" | "end" The edge the handle sits on, naming the edge opposite the one that moves.
measure Element or (separator) => Element The box being resized. Given this, it measures itself.
value number or () => number The current size, when it is not the measured extent.
min / max number or () => number Bounds. Override the measurement.
onResizeStart () => void The gesture began.
onResize (size) => void Throughout the gesture. Preview here.
onResizeEnd (size) => void Once at the end. Commit here.
label is required because a focusable role="separator" with no accessible
name is announced as a bare “splitter”, which says nothing about what it
resizes.
<DResizeSeparator
  @label={{i18n "sidebar.resize"}}
  @measure={{this.panelElement}}
  @onResizeEnd={{this.persistWidth}}
  @axis="horizontal"
onResizeEnd also fires if the separator is destroyed mid-gesture, so anything
opened at the start still gets closed.
dResizeEdge
The modifier underneath DResizeSeparator. Use it directly only when the
element and its separator semantics are already yours to provide.
value number | null or a function, required The current size.
min / max number or a function, required Bounds.
axis "vertical" | "horizontal" Which dimension is resized.
side "start" | "end" Which edge the handle sits on.
bodyClass string Class applied to document.body while resizing.
onResize (size, meta) => void Throughout the gesture.
onResizeEnd (size, meta) => void Once at the end.
DResizeHandles
Renders the edges and corners of a two-dimensional box resize and reports
pointer geometry for the consumer to interpret.
directions BoxDirection[] Which of n, ne, e, se, s, sw, w, nw to render.
handles DResizeHandleDescriptor[] Explicit handle descriptors with their payloads.
handleClass / draggingClass string Classes for the handles and the active gesture.
measure MeasureTarget The box the geometry is measured against.
threshold number Pixels of movement before a gesture starts.
onResizeStart / onResize / onResizeEnd / onResizeCancel (payload, dragInfo) => void The gesture lifecycle.
@action
onResize(direction, { delta }) {
  if (direction.includes("e")) {
    this.width = Math.max(MIN, this.startWidth + delta.x);
  if (direction.includes("s")) {
    this.height = Math.max(MIN, this.startHeight + delta.y);
Do not give a two-dimensional box resize role="separator". It has no single
aria-valuenow to report, so the role would describe a control that does not
exist.
dSwipe
Reports a discrete directional flick with velocity, for touch surfaces that open
or dismiss something.
onDidStartSwipe (state, event) => void The gesture began.
onDidSwipe (state) => void It progressed.
onDidEndSwipe (state) => void It completed.
onDidCancelSwipe (detail) => void It was interrupted.
enabled boolean Whether the gesture is active.
lockBody boolean Whether to lock body scrolling during it.
Use dPointerDrag instead when a value must track the pointer continuously.
dSwipe answers “which way did they flick”, not “where is the pointer now”.
dOnResize is not a gesture
dOnResize wraps ResizeObserver: it reports that an element’s size changed,
and nobody resizes anything with it. The similar name is the trap. To let
someone change a size, use one of the resize primitives above.
Accessibility
A drag is not a keyboard interaction. Every reorder surface has to pair the
drag with a keyboard path, and every resize between regions should use the
keyboard support already in DResizeSeparator or dResizeEdge.
For a list the user puts in order, use DReorderableList. It pairs the
drag with a move menu and keyboard shortcuts, and it announces each completed
move. See the UI kit guide.
Announce the outcome, not the movement. A completed reorder reports the
item’s new visible position once through a11y.announce(). A no-op announces
nothing, and moving the pointer across drop indicators announces nothing.
Do not add aria-dropeffect or aria-grabbed. Both are deprecated and
neither makes a drag operable.
A drag handle is decorative and stays outside the tab order, because a
keyboard cannot operate it. The operable controls are the keyboard path beside
it.
Keep the two paths’ scopes honest. They may legitimately differ: arrows may
move within one labeled list while a drag crosses between lists. The keyboard
path should follow the list the user is stepping through rather than silently
crossing a semantic boundary.
A dwell only shortcuts a pointer drag. Whatever dDragDwell reveals
must stay reachable without it: the surface keeps its ordinary affordance — a
disclosure control, a keyboard path — and the dwell merely saves the pointer a
detour mid-drag.
Testing
Synthetic mouse events do not drive a native drag; they stall. Use the helpers.
In JavaScript tests, from
discourse/tests/helpers/ui-kit/drag-and-drop-helper:
Helper Drives
simulateDrag(source, target, opts) A registered source onto a target.
simulateUnsourcedDrag(source, target, opts) Browser-started page content onto a target.
simulateExternalDrag(target, opts) A payload from outside the window.
externalDragOver / dragOver / startDrag A drag left hovering, without dropping.
dragEvent / dragEventNow One event, with or without a frame after it.
centerOf / textTransfer / fileTransfer Coordinates and payloads.
Every synthetic drag event must carry finite clientX and clientY, which is
what centerOf is for.
A dwell needs no clock control: its delay collapses under test (see
discourse/lib/later), so hover with startDrag and dragOver, then
await settled() for the fire. Edges that must land before the collapsed
delay ride synchronous drop-target hierarchy changes via dragEventNow, which
is why a dwell test co-locates a drop target on the dwell element.
In system specs, use SystemHelpers#drag_and_drop.
dDraggable is deprecated
dDraggable raises discourse.ui-kit.d-draggable when instantiated. Use
dPointerDrag. It is not a drop-in: rename didStartDrag, dragMove and
didEndDrag to onDragStart, onDrag and onDragEnd, and add onDragCancel
so an interrupted gesture still finishes.
This document is version controlled - suggest changes on github.
6 إعجابات
