The UI kit of shared Discourse components, helpers, and modifiers
ui-kit is the layer of reusable, domain-free building blocks that core, plugins, and themes compose their interfaces from. It lives under frontend/discourse/app/ui-kit/ and ships three kinds of primitive:
  • Components: d-button, d-modal, d-native-select, d-skeleton, and so on.
  • Helpers (ui-kit/helpers/): d-icon, d-format-date, d-concat-class, d-user-avatar, and so on.
  • Modifiers (ui-kit/modifiers/): d-trap-tab, d-on-resize, d-close-on-click-outside, the drag-and-drop family, and so on.
Everything in it is prefixed with d- (D in PascalCase) and is considered public API for plugins and themes. This page explains when to reach for it, what is in it, and how to add to it. Each primitive’s own JSDoc/TSDoc is the reference for its arguments; the interactive styleguide shows most of them rendered.
Importing
Import from the discourse/ui-kit namespace:
import { on } from "@ember/modifier";
import DButton from "discourse/ui-kit/d-button";
import dIcon from "discourse/ui-kit/helpers/d-icon";
import dAutoFocus from "discourse/ui-kit/modifiers/d-auto-focus";
<template>
  <label class="rename-form__label">{{dIcon "pencil"}} {{@label}}</label>
  <input
    class="rename-form__input"
    value={{@name}}
    {{dAutoFocus selectText=true}}
    {{on "input" @onInput}}
  <DButton
    class="btn-primary"
    @action={{@onSave}}
    @label="save"
    @icon="check"
    @isLoading={{@isSaving}}
</template>
discourse/components/*, discourse/helpers/*, and discourse/modifiers/* are still where domain-specific, non-shareable components live; only the reusable primitives were moved into the kit. The old paths of the moved ones (discourse/components/d-button, discourse/helpers/d-icon, and so on) still resolve through the shims in frontend/discourse/app/ui-kit-shims.js, so existing plugins keep working, but new code should import them from discourse/ui-kit/... directly.
Do not import anything from a -internals directory, wherever it appears (discourse/ui-kit/-internals/..., discourse/lib/-internals/..., and so on). Those modules are private implementation details of the primitives that wrap them: they are not part of the public API and can be renamed, reshaped, or removed without notice or a deprecation cycle. If a primitive does not expose what you need, extend the primitive rather than reaching past it.
When to use it
Before writing a component, check whether the kit already covers the need:
  1. Browse the ui-kit/ directory (component, helper, and modifier names are descriptive) and the styleguide sections.
  2. Prefer composing existing primitives over adding a variant. A d-button with @icon and a class attribute is better than a new button component; a d-empty-state with a custom @ctaLabel is better than a bespoke empty message.
  3. If the need is a form, use FormKit rather than assembling inputs by hand; FormKit’s controls are themselves built on ui-kit primitives.
  4. If the need is anchored or hover-triggered UI (tooltips, menus, popovers), use float-kit rather than positioning things yourself. It ships both components (DTooltip, DMenu, DPopover, DToast, and their headless variants, imported from discourse/float-kit/components/...) and the tooltip, menu, and toasts services for showing the same things programmatically. See Menus, Tooltips, and Toasts.
Reach for a new component in frontend/discourse/app/components/ when the thing you are building knows about Discourse domain concepts (a topic, a post, a category, a user’s notification level). Add to ui-kit/ only when the primitive is domain-free and useful to more than one consumer; see Adding a primitive below.
What is in it
The groups below are a map, not an exhaustive list. Run ls frontend/discourse/app/ui-kit for the current inventory, and read the JSDoc/TSDoc of each file for its arguments and blocks.
Actions
Primitive Use it for Styleguide
DButton Every clickable action. Handles labels, icons, @isLoading, @disabled, and ARIA. Buttons
DComboButton A primary action paired with a dropdown of secondary actions. Combo button
DCopyButton Copy a value to the clipboard with feedback.
DPageActionButton Actions in a page header.
DBadgeButton, DToggleSwitch, DTogglePasswordMask Toggles and badge-shaped actions.
DShortcut Render a keyboard shortcut in the platform’s notation. Shortcut
Inputs
Form-level composition belongs to FormKit. These are the underlying controls, useful when a single control is needed outside a form.
DNativeSelect A native <select> with Discourse styling. Dropdowns
DMultiSelect Choose several values with search. Multi select
DTextField, DTextarea, DExpandingTextArea, DPasswordField, DRadioButton Single controls. Forms
DDateInput, DDatePicker, DTimeInput, DDateTimeInput, DDateTimeInputRange, DFutureDateInput, DRelativeTimePicker, DTimeShortcutPicker, DCalendarDateTimeInput Dates, times, and ranges. Date/time inputs
DOtp, DSecondFactorInput One-time codes. OTP
DFilterInput, DFilterControls Filter a list.
DIconGridPicker, DPickFilesButton Specialised pickers.
DCharCounter, DInputTip, DPopupInputTip Feedback attached to an input. Char counter
DAccessControl, DAccessControlField Edit access control lists.
DEditor The composer’s markdown editor.
Page chrome and layout
DPageHeader, DPageSubheader Titles, breadcrumbs, tabs, and actions of an admin or settings page.
DBreadcrumbsContainer, DBreadcrumbsItem Breadcrumb trails registered from routes. Breadcrumbs
DNavItem, DNavigationItem, DHorizontalOverflowNav Navigation bars; the overflow nav is built on DOverflowControls. Navigation bar
DOverflowControls Scrollable strips with edge fades, chevrons on whichever edges can still scroll, press-and-hold, and a way to reveal one item. Overflow controls
DTabs Tab panels switched in place, with the strip, keyboard cursor, and ARIA pairing built in. Tabs
DResponsiveTable, DTableHeaderToggle Tables that stay usable on narrow viewports, with sortable column headers.
DVirtualList Long lists that render only the rows in view. Virtual list
DReorderableList, DReorderableListGroup Lists the user can reorder by drag, a move menu, or the keyboard. The group lets a row move between lists. Reorderable list
DStatTiles Rows of headline numbers.
DTapTileGrid, DTapTile Grids of tappable choices.
DPostAccordion, DPostAccordionItem Collapsible sections.
DResizeHandles, DResizeSeparator User-resizable regions. Drag and drop
DSaveControls The save button and “saved” feedback of a settings form.
DFloatingControlBar A bar pinned to the bottom of the page offering to save or discard unsaved changes.
Loading, empty, and feedback states
DSkeleton Placeholder shapes while content loads. Prefer a skeleton that mirrors the eventual layout over a spinner.
DConditionalLoadingSpinner, DConditionalLoadingSection Show a spinner (@condition) or a dimmed, labelled section (@isLoading) in place of content while it loads.
DAsyncContent Render content that is loaded asynchronously. Give it a promise, a TrackedAsyncData, or a function that fetches the data via @asyncData, and fill the loading, content, empty, and error blocks; it reloads when @context changes, so there is no need to hand-roll loading flags and error handling.
DEmptyState A titled, illustrated “nothing here” message with an optional call to action. See Empty state.
DFlashMessage Inline success, error, and warning banners.
DLoadMore Infinite scrolling.
Content rendering
DCookText Render raw markdown as cooked HTML.
DDecoratedHtml Render HTML and apply the decorators registered through the plugin API to it.
DHighlightedCode Syntax-highlighted code.
DHtmlWithLinks, DCustomHtml Trusted HTML fragments.
DInterpolatedTranslation, DCountI18n Translations whose placeholders are components or counts.
DRelativeDate A live-updating relative timestamp.
DCdnImg, DLightDarkImg Images that follow the CDN and the colour scheme.
DAnimatedEmoji An emoji animated where an animation exists, static otherwise.
Users, avatars, and categories
DUserAvatar, DUserAvatarFlair, DAvatarFlair, DUserLink, DUserInfo, DUserStat, DUserStatusMessage, DSmallUserList, DBadgeCard, plus the d-avatar, d-bound-avatar, d-category-badge, d-category-link, d-discourse-tag, and d-topic-link helpers. See Categories.
Overlays
DModal and DModalCancel render modals; see the DModal API. DDropdownMenu renders the content of a menu opened through the menu service. DConditionalInElement renders its block into @element elsewhere in the DOM, or in place when @inline is set.
Helpers
d-icon, d-icon-or-image, d-emoji, d-replace-emoji, d-format-date, d-format-duration, d-number, d-age-with-tooltip, d-dasherize, d-dir-span, d-unique-id, d-base-path, d-loading-spinner, d-element (a typed wrapper for a chosen tag, so attributes and modifiers are checked against the right element), and d-concat-class (join class names, dropping falsy ones).
Modifiers
Modifier Use it for
d-auto-focus Focus an element when it renders.
d-trap-tab Keep keyboard focus inside a dialog.
d-tab-to-sibling Make Tab move focus between sibling elements.
d-roving-focus Arrow-key navigation over a group of items (a toolbar, listbox, menu, or tree) with a single tab stop, via roving tabindex or aria-activedescendant. See Roving focus.
d-close-on-click-outside Dismiss an overlay when the user clicks elsewhere.
d-on-resize, d-observe-intersection, d-scroll-into-view React to layout and visibility.
d-scroll-edges Stamp a scroll container’s overflow and edge state as data attributes, for a strip that brings its own chrome. Pair it with the scroll-strip stylesheet mixin, which paints the edge fades from those attributes.
d-autocomplete Attach an autocomplete popup to a text input.
d-swipe, d-pointer-drag, d-resize-edge, d-drag-dwell, d-drag-and-drop-* Gestures. See Drag, resize, and gesture primitives.
Adding a primitive
A primitive belongs in ui-kit/ when it is domain-free (it does not know what a topic or a post is) and either already has two consumers or is an obvious platform capability (a focus trap, a skeleton, a keyboard-shortcut renderer). Otherwise keep it next to its single consumer in app/components/.
When you add one:
  • Name it d-<name> and put it at frontend/discourse/app/ui-kit/d-<name>.gts (or helpers/d-<name>.js, modifiers/d-<name>.ts). See Splitting a large primitive when one file is not enough.
  • Write it in TypeScript with a Signature (Args, Blocks, Element) and TSDoc on the class and every public argument. The kit is platform-level code, so accurate types matter more here than elsewhere; d-shortcut.gts, d-skeleton.gts, d-resize-separator.gts, and modifiers/d-drag-dwell.ts are good models. See Types.
  • Forward ...attributes to the element consumers will want to target, and declare that element in the Element type so the type checker allows attributes and modifiers on it.
  • Use BEM class names rooted at the component name (older primitives predate this rule; new ones must follow it), d-<name>, d-<name>__part, and a standalone .--modifier, and put the stylesheet at app/assets/stylesheets/common/ui-kit/d-<name>.scss, registered in _index.scss. Use colour and spacing tokens only; no hard-coded colours. See CSS guidelines.
  • Prefer named blocks over boolean arguments when the consumer supplies content, and yield a small API object when the consumer needs to call back into the component.
  • Take strings already translated. A primitive receives display text as a plain string argument (@label, @title) that the consumer has already passed through i18n(); it never resolves translation keys itself. The kit does not know which locale file a consumer’s key lives in, and a key-taking argument forces a parallel @translatedX argument for every string. d-resize-separator.gts documents its label this way. DButton’s @label-as-key plus @translatedLabel pair predates this rule; do not copy it.
  • Gate development-only warnings and assertions on DEBUG from @glimmer/env. It is a build-time constant, so the gated code and its messages are stripped from production bundles; d-resize-handles.gts and modifiers/d-roving-focus/diagnostics.ts do this.
  • Do not mention plugins or specific libraries in its docs or comments; describe the mechanism instead.
A primitive whose behaviour outgrows one file keeps one public entry module and moves everything else into a sibling directory named after it. Consumers import only the entry; nothing outside the directory imports from -internals/.
ui-kit/
  d-widget.gts                     # the public component; the only import path
  d-widget/
    README.md                      # what each collaborator owns and why
    types.ts                       # every interface, incl. the ones the entry re-exports
    -internals/
      constants.ts                 # values shared by more than one collaborator
      engine/                      # the headless logic: state, algebra, resolution
      coordinators/                # non-rendering classes the component constructs once
      parts/                       # rendering subcomponents that own part of the public DOM
      modifiers/                   # element-attached behaviour private to this primitive
  modifiers/
    d-gesture.ts                   # a modifier entry follows the same shape
    d-gesture/
      types.ts
      keyboard.ts, strategies/, …
Use the buckets that apply; a two-file split needs only types.ts. What goes where:
  • types.ts holds every interface, including the ones the entry re-exports as public API. It is the documentation home for the argument reference, so the entry’s Args block can point at it.
  • -internals/engine/ is the headless layer: state, filtering, the move or selection algebra, value resolution. It has no DOM and no component reference, which is what makes it unit-testable on its own.
  • -internals/coordinators/ are plain classes the component constructs once and configures downward with thunks (() => this.args.x); they never hold a reference back to the component. Announcers, menu coordinators, and load-feedback timers live here.
  • -internals/parts/ are the rendering subcomponents. They receive the stable helper objects (the engine, a presenter) plus per-slot inputs, and render the elements of the primitive’s public DOM, the ones its stylesheet and tests target. They add no wrapper beyond that contract.
  • -internals/constants.ts exists so two collaborators that must agree on a value (a menu identifier, a selector) import it rather than restating it.
  • README.md explains the split: what each collaborator owns, the invariants that cross files, and the design decisions a future reader would otherwise undo.
Something shared by several primitives, rather than private to one, goes in ui-kit/-internals/<topic>/ (scroll-strip, for example, which the overflow controls and the tab strip share), still off-limits to consumers. Private modules covers where a shared mechanism goes and how to move one out of a single owner.
Blast radius and backward compatibility
The kit exists to build all of Discourse’s UI: core, every plugin, and every theme render through it. A change here therefore has a far larger blast radius than a change to a single feature, and code you cannot see (third-party plugins and themes) depends on the public surface exactly as it is today.
Before changing anything public facing (an argument, a block, a yielded API object, a class name, DOM structure, or a helper’s or modifier’s signature), work out:
  • Who can be relying on it. Search core, the in-repo plugins, and the wider plugin and theme ecosystem for the argument or class name; assume any exported name or documented argument has consumers you cannot see.
  • Whether the change is backward compatible. Adding an optional argument or block is; renaming, removing, changing a default, changing the element ...attributes land on, or restructuring the DOM that stylesheets target is not.
  • Whether a deprecation cycle is required. A breaking change to a public surface ships behind a deprecation first: keep the old path working, emit a deprecation with an id and a since version, document the replacement, and remove it only after the cycle. Do not skip this because the old behaviour looks unused.
For anything new (a feature, an argument, a component, a modifier), the bar is exhaustive testing rather than a happy-path check: every argument and block, keyboard and pointer input, the states a consumer can put it in, error paths, and the accessibility contract. A primitive that ships with a gap ships that gap to every surface that adopts it.
Testing a primitive
  • Rendering tests go in frontend/discourse/tests/integration/ui-kit/d-<name>-test.gjs, next to the other 40-odd kit tests. Assert through the public API and observable DOM, not internal state. Cover every argument and block, every input method the primitive answers to, and the states it can be driven into; the drag-and-drop family in frontend/discourse/tests/integration/ui-kit/modifiers/ shows the expected depth (modifier tests live in that modifiers/ subdirectory, helper tests in helpers/).
  • Type tests for .gts primitives go in frontend/discourse/type-tests/ui-kit/d-<name>-test.gts, using @glint-expect-error (and expect-type where a value type matters) to pin down both what compiles and what must not.
  • Module-level state (registries, callbacks) needs a reset export that frontend/discourse/tests/helpers/qunit-helpers.js calls from testCleanup(), as d-decorated-html and d-editor do.
  • System specs for behaviour a component test cannot reach (real drag negotiation, portaled overlays, scroll containers) go in the styleguide plugin when the primitive has no core consumer to exercise it.
Styleguide section
Every primitive is browsable at /styleguide/<category>/<section>, and the section is part of the deliverable, not an afterthought. Add or extend one under plugins/styleguide/assets/javascripts/discourse/components/sections/ and register it in plugins/styleguide/assets/javascripts/discourse/lib/styleguide.js.
A section should be designed, with multiple examples that each isolate one capability. sections/molecules/drag-and-drop.gjs is the model: it groups its examples with StyleguideGroups, and each Example carries a title, a @kind, a description of what the example demonstrates, a @tryThis prompt telling the reader what to do, an optional @note on the subtlety it exposes, and the source via @code so the reader can copy it. Aim for one example per argument or behaviour worth understanding (types, positions, disabled state, nesting, custom preview, and so on), rather than a single kitchen-sink demo.
DMultiSelect footer actions
DMultiSelect accepts an optional footer block below the search results, including when
there are no matching results. The block receives the menu API; await menu.close() before
opening another dialog so focus moves to the new dialog. Without a footer block, no footer
or divider is rendered. Set @matchTriggerWidth={{true}} when a caller needs the menu to
match the trigger width; this is opt-in and independent of the footer.
<DMultiSelect
  @loadFn={{this.loadItems}}
  @selection={{this.selection}}
  @onChange={{this.selectItems}}
  <:selection as |item|>{{item.name}}</:selection>
  <:result as |item|>{{item.name}}</:result>
  <:footer as |menu|>
    <DButton @action={{fn this.createItem menu}} @label="create" @icon="plus" />
  </:footer>
</DMultiSelect>
Related guides
This document is version controlled - suggest changes on github.
