Once a poll is created, a user make a choice, can change his vote but he cannot cancel his vote.
Is this possible to add an option to revert the choice ?
Users are discussing the inability to remove a vote in a poll on Discourse, particularly for single-choice polls. Chopper initially asked if it’s possible to revert a vote, and Speck_of_the_Cosmos highlighted the need for this feature for digital voting and to correct misclicks. zogstrip clarified that votes can be changed until the poll closes, but users like Speck_of_the_Cosmos and DubZ found the process unintuitive, as it requires toggling ‘Show Results’ to modify a vote. seanblue and others expressed frustration over accidentally voting, with PackElend suggesting workarounds like adding ‘I voted by mistake’ options. seanblue proposed a simple solution: clicking a selected option again would remove the vote, while alex21 supported this and questioned if there’s opposition to implementation. sam suggested a visual mockup to push the idea forward, though PackElend argued the solution is straightforward and doesn’t require one.
Was this put somewhere else? I think a vote should be able to be changed until the poll closes. We can then use these to do digital voting for our organization if they can change their votes as discourse on the issue continues. Also, there’s misclicks and they can’t fix them.
Having you tried using the poll feature? You’ve always been able to change your vote since the inception of the plugin.
Ah, you have to untoggle show results to change your vote. That wasn’t obvious to me.
I guess I’ll just jump onto this topic rather than creating my own. I have occasionally voted in a poll by accident, which is particularly annoying because there is no way to remove my vote. Are there any plans to add a feature to remove your own vote for single choice polls?
I found this thread also after searching a while.
I agree that deleting his own vote would be useful AND also, that there is a second button or sth. similar to modify his own vote. without this thread I feel like I never would have found the modify possibility when pressing the show results button. this is not user firendly (IMO) and perfectly hided.
BR
على الرغم من أنني أكره رفع المواضيع، إلا أنني أكره إنشاء منشورات مكررة، لذا قد يكون من الأفضل رفع موضوع موجود. لا يزال لا يمكنك إزالة تصويتك في استطلاع خيار واحد. أحيانًا أختار الخيار الخطأ عن طريق الخطأ، والآن سيظن الناس أنني أتفق مع خيار آخر.
لدفع هذا الأمر إلى الأمام، أنصح المجتمع بنشر نموذج مرئي للتغيير المقترح.
بالنسبة للاستطلاعات ذات الخيار الواحد، يؤدي النقر على خيار ما إلى تحديده بصريًا وحفظ التصويت فورًا. إذا نقرت على “عرض التصويت”، ستظهر الخيارات مرة أخرى مع تحديد الخيار الموجود مسبقًا. أرى أن النقر مرة أخرى على الخيار المحدد يجب أن يزيل التصويت.
أما بالنسبة للاستطلاعات متعددة الخيارات، فمن المنطقي على الأرجح النقر على “تصويت” بعد إزالة الخيار(ات) المحدد(ة)، حيث يجب النقر على “تصويت” لإرسال أصواتك في المقام الأول.
أعتقد أن هذا سيكون النهج الأبسط، لأنه لن يتطلب أزرارًا جديدة أو ما شابه ذلك (مع الحاجة إلى تغيير بعض الأنماط وسلوك الأزرار الحالي). إذا كنت تعتقد أن زرًا صريحًا مثل “إزالة التصويت” سيكون أكثر منطقية، فيمكنني على الأرجح إنشاء نموذج أولي لذلك.
سيكون لإمكانية إلغاء التصويت دور فعال مع القدرة المضافة حديثًا على إنشاء استطلاعات بخيار واحد. يمكنك بعد ذلك إنشاء نماذج تسجيل مريحة.
أشعر أننا نفضل تشجيع الناس على استخدام أحداث مكون التقويم بدلاً من الاستطلاعات!
يجب تنفيذ هذا، من فضلك! كنت أحاول فقط تمييز نص الاستطلاع لنسخه/لصقه (لا أدري لماذا لا يُسمح بذلك، بالمناسبة)، والآن صوتت بالخطأ في استطلاع.
أنا أيضاً، يجب أن أنشئ استطلاعات الآن للسماح بإلغاء التصويت بشكل غير مباشر. هذا ليس احترافياً، أليس كذلك؟
نعم، لقد ارتكبتُ خطأً أثناء التصويت. من المزعج أنني لا أستطيع التراجع عنه.
انضمّ أنا أيضًا إلى الآخرين في طلب هذه الميزة. ستكون مفيدة جدًا، إذ قد يحدث التصويت في استطلاع عن طريق الخطأ بشكل متكرر، مثلًا عند التمرير في متصفح محمول يعاني من بطء نسبي.
أقترح نفس ما تم اقتراحه سابقًا:
هل هناك معارضة لتنفيذ هذه الميزة؟ هل ستستلزم جهدًا كبيرًا؟
أجل، غالبًا ما نضيف خيارات مثل “صوّتت عن طريق الخطأ”. إنه لأمر مؤسف حقًا أننا مضطرون إلى فعل ذلك.
هل هذا ضروري حقًا؟
أعتقد أن الحلول البديلة المقدمة واضحة جدًا. إذا نقرت مرة واحدة، يتم تأكيد الاختيار، وإذا نقرت مرة أخرى، يتم إلغاء الاختيار. يمكنك إضافة تحذير يشير إلى أنك على وشك إزالة اختيارك.
