Categories bulk edition
It would be nice to have an admin view of all the categories (as a table list) and being able to apply bulk changes.
Maybe a first version would allow to perform these actions only:
  • Delete
  • Colors
  • Parent category
  • Images
  • Template
… as they don’t require as much brain fluid as merging settings or permissions which can be nested.
Or maybe just overwrite everything?
I’d love your feedback on that.
7개의 좋아요
I think this is a good idea, something in a similar vein to bulk selection and editing of topics would save lots of time, since the explorer plug in is read only and running rails commands is discouraged that leaves everyone in the “reverse engineer the API if you don’t want to spend an hour adjusting things” I think.
3개의 좋아요
Yea and I’d also love the ability to bulk change permissions :smiling_face::folded_hands:t2:
3개의 좋아요
Is there a way in 2025 to change the parent simultaneously on n categories? Either by UI or in the console?
2개의 좋아요
I’m not sure I understand what you are asking.
For a while, you can change the notifications for a Parent and all its children. But I don’t think that we can any more.
1개의 좋아요
In the topic list, as an admin, you can select all topics and perform bulk actions on them. I’m asking for the same towards categories.
But actually I did it manually already :wink:
1개의 좋아요
