Troubleshoot email on a new Discourse install
You just installed Discourse via the install guide, but email doesn’t seem to work. Unfortunately this means you can’t log in as an admin to finalize the install. :cry: Let’s troubleshootize!
Try the doctor :woman_health_worker:
If you run ./discourse-doctor it will check several ways that your mail configuration might be broken, and offer advice. Try that first.
Did you enter email settings correctly?
The simplest way is to run ./discourse-setup again. Did you enter everything correctly? But wait! If your password has anything other than numbers and letters, you might be better off editing your app.yml with nano or your favorite editor.
You can also double check the settings in your containers/app.yml file. A valid email section looks like this:
DISCOURSE_DEVELOPER_EMAILS: 'name@example.com'
DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: postmaster@discourse.example.com
DISCOURSE_SMTP_PASSWORD: aUd34cdWKCu6CTjfoH7ykk
Closely examine all values for correctness. Note that:
  • it all aligns
  • no leading # characters
  • single quotes around the developer email field
  • password does not include #, ", ', %, ] or other special characters (a # in a YAML value can be misinterpreted as a comment; if you must use special characters, wrap the value in double quotes, e.g. DISCOURSE_SMTP_PASSWORD: "#pass#ord")
If you had any errors in your app.yml and made changes, you MUST rebuild the container for those changes to take effect!
cd /var/discourse/
./launcher rebuild app
Well, you don’t always need to rebuild
Doing a rebuild will often fix things that seem broken, but it takes a while. There are times when a full rebuild is not necessary; the above is usually the best advice, but If you change just SMTP settings, you can do just this to apply them without doing a full rebuild:
cd /var/discourse
./launcher destroy app
./launcher start app
Are your SMTP connections being blocked?
To confirm that your server can indeed contact the email server, issue this command:
telnet smtp.mailgun.org 587
If you can’t connect this way, you’re almost certainly blocked. (And if you do get connected, the escape character for SMTP is ctrl+], then use quit to exit telnet.)
If this happens, first try port 2525, and if that fails, contact your cloud provider support and confirm that your email connections are not being blocked.
What do the Discourse logs say?
From the command line, issue this command:
cd /var/discourse
tail shared/standalone/log/rails/production.log
This will show the last few lines of the log. Look for anything mail related. If you need to view the fuller logs, try
less shared/standalone/log/rails/production.log
To page through the complete log, press space or type GG to jump to the end. Look closely for any email related messages or press /, type email, and hit enter to search.
What do your email provider logs say?
Assuming there are no errors in the Discourse logs, or your Discourse mail configuration, the emails probably went out. The question, is what did your email provider do with them?
Most email providers have a log viewing function. Check the logs for your email domain and see what happened with the incoming emails.
Did you properly set up DKIM and SPF records for your domain?
You must enter those crucial DNS records for DKIM and SPF, otherwise your emails may arrive only sporadically, if at all.
Is the email domain correct?
The default email from address is based on the install domain plus subdomain, so if your URL is discourse.example.com it will be:
noreply@discourse.example.com
But if your mail provider is expecting:
noreply@example.com
.. you may have problems! To get around this, edit and uncomment this exec line in app.yml
#- exec: rails r "SiteSetting.notification_email='noreply@example.com'"
You’ll need to issue a rebuild after uncommenting the above line and setting the from email address as required.
You can also change this from the command line, if needed:
./launcher enter app
rails r "SiteSetting.notification_email = 'discourse@yoursite.com'"
exit
If using Mailgun – have you activated your domain and provided credit card info?
If you are using Mailgun, after you enter your DKIM and SPF records, you must visit https://mailgun.com/app/domains/YOUR.DISCOURSE.DOMAIN.com and click the “Check DNS Records Now” button. At the top of that page you should see “State ACTIVE” (in a calming green). If it says “State Unverified” (in a scary warning-yellow) Mailgun will not accept mail.
Mailgun now requires a credit card in order to deliver mail (other than to you). If your mailgun logs have a message about “free accounts,” this is your problem.
Other mail services have similar requirements.
Are you using an IP address as the mail domain?
This does not work in our experience. You must use a domain name when sending email, not an IP address like 192.168.1.1.
If you really want to go on with an IP address, try mail settings similar to these:
DISCOURSE_SMTP_ADDRESS: 172.17.0.1         # e.g. use internal docker IP here
DISCOURSE_SMTP_USER_NAME: "YOUR-SMTP-USER-NAME"
DISCOURSE_SMTP_PASSWORD: "YOUR-SMTP-PASSWORD"
DISCOURSE_SMTP_ENABLE_START_TLS: true     # (optional, default true)
DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none
DISCOURSE_SMTP_DOMAIN: example.com
Need to log in without receiving a registration email?
We don’t recommend this, because your email is still broken, and you have a broken Discourse until email is working. But if you absolutely must log in as admin with email broken, here’s what to do:
cd /var/discourse
rake admin:create
And answer the prompts. It takes a few seconds before they appear. When it asks for the password, you will not be able to see what you type. That is why it makes you type it twice.
Email smtp port selection (Using 465?)
The ability to be able to AUTH using ‘telnet’ is extremely important in your first steps of email troubleshooting.
Port 465 (SMTP over SSL) uses implicit TLS. If you need to use port 465, add this to your app.yml:
DISCOURSE_SMTP_PORT: 465
DISCOURSE_SMTP_FORCE_TLS: true
You may also need to try alternate ports such as port 2525 or port 587 (Mail Submission) when things do not seem to work as expected.
Command Line SMTP tests for experienced sysadmins
If you’re comfortable with the command line, these might help diagnose network or certificate problems. If these do not seem “easy-to-follow” then you should please ignore this section.
See also Test SMTP authentication and StartTLS - Sysadmins of the North.
Office 365 Tweaks
If you’re using Office 365, be sure to include these (the first line is what you are likely missing):
DISCOURSE_SMTP_AUTHENTICATION: login
and set the correct value for DISCOURSE_NOTIFICATION_EMAIL (which is likely different from your forum hostname).
TLS and SSL issues
By default, Discourse uses STARTTLS to encrypt its connection to the email server. Some email servers (increasingly rare nowadays) don’t support this or aren’t configured to use it, so it can be disabled by adding this line:
DISCOURSE_SMTP_ENABLE_START_TLS: false    #default: true
Other email servers might support STARTTLS, but use a self-signed certificate. This is uncommon and can be enabled with:
DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none #default: peer
Email still doesn’t work! What next?
Anything else I forgot here? Feel free to edit this.
Debug issues with first connection to smtp server from inside the Discourse container
1. Enter your container:
2. Check dns resolving for your smtp server name via getent hosts:
(dig, nslookup, ping etc. are not installed inside the container.)
getent hosts your.smtp.server
On success, it will look like this or will be blank on failure.
# IPv4
123.123.123.123 your.smtp.server
# IPv6
2001:db8:0:0:0:ff00:42:8329 your.smtp.server
3. Try to open a connection to your smtp server via openssl:
(telnet, nc etc. are not installed inside the container.)
Fiddle with some different settings until you succeed with a connection.
openssl s_client -connect your.smtp.server:465
openssl s_client -connect your.smtp.server:587 -starttls smtp
# IPv4
openssl s_client -connect 172.17.0.123:465
openssl s_client -connect 172.17.0.123:587 -starttls smtp
# IPv6
openssl s_client -6 -connect "[2001:db8:0:0:0:ff00:42:8329]:465"
openssl s_client -6 -connect "[2001:db8:0:0:0:ff00:42:8329]:587" -starttls smtp
See: How to check SMTP connection → Step 3: Checking SMTP Connection Over TLS Using Openssl
4. Use your found working connection settings with Discourse.
:rocket:
Bonus: show Discourse IP from inside docker container
( ifconfig , ip etc. are not installed inside the container.)
hostname -I
Result like:
172.17.0.2
I am not getting any emails
Unable to send email
Mail system not working even thought I tested it with telnet and other platforms
Post Install Email Issues
Installing Discourse on DigitalOcean - got stuck
Activation email not being delivered, test email working
Announcing Discourse Doctor
Recommended SMTP provider
Discourse SMTP not receiving mails?
After Installation Discourse is unable to send Verification email
No activation email
Mail error 504 5.7.4 Unrecognized authentication type
Not Receiving Email for Admin Creation
Trouble setting up smtp
Mail server setup
Discourse and MailJet issue
All files and directories disappeared from root
Email not sending
Emails Failing to Send
Discourse SMTP Error
Email installation issue
SMTP do not work
Post Install Can't complete email verification
Errors with Sidekiq - emails not sending
My Discourse is not sending emails
Unable to find verification email
MKJ's Opinionated Discourse Deployment Configuration
Email not sending after update
Database shut down error at the end of discourse docker setup
E-Mail not working after moving to self-hosting and adding DKIM record
Email not working with 123-reg and discourse on hosted Virtual Private Server - all other aspects appear to
New users not receiving activation emails
SMTPAuthenticationError: 535 Incorrect authentication data
Issue on Discourse Digest Email
How do I change my primary email
Letters are not sent. What to do?
Sidekiq email errors and settings issue
Noob installation : email not working, trouble with the digitalocean console
SMTPAuthenticationError From Discourse-Doctor On New Install
Outgoing/incoming email changes for our hosted customers
Any MailJet alternatives?
Mail subdomain problem
Activation Not send
Email jobs failing after latest update, certificate verify failed (unable to get local issuer certificate)
Problems with email
Email not working (SSL_connect returned=1)
Email Hostname Certificate Mismatch Causing sidekiq Queue Overload, Severe Site Instability
Zoho Mail problems
Cant setup admin account
Understanding mail concept
How to resend activate email when I close the tab
Unable to send email from my forum
Site installed but NO admin email activation
Emails automatically generated from the forum are not working. Any ideas?
./launcher start app - does not run (need to re-setup SMTP)
UNEXPECTED ERROR Net::SMTPAuthenticationError
Discourse-app container starts then silently stops
Fresh Discourse/Docker install wont send mails
I don't receive the activation email to log in as an admin
Discourse install and SMTP issue
Cannot send email - problem with port 465
Will ./launcher destroy app && ./launcher start app remove the built Docker image?
Trying everything, no luck with smtp working
MailJet SMTP is Not Working
SMTPAuthenticationError - I don't receive mail from mailgun to setup the admin account
My forum does not send emails
SMTP problem with Amazon SES
I dont know whats wrong with the SMTP service
Problem when updating Discourse Forum
ERROR – 535 auth failure
Troubleshooting Outgoing Email
Backup installation problem?
Yet other SMTP 587 port email various errors
Reset password at command line
Some people are unable to complete the registration, the activate button does not work or the email does not arrive
New setting up and SMTP is not working
Emails not arriving on Gmail
Struggling to Configure SMTP in Discourse with Azure Communication Service
501 5.5.4 You are not allowed to send from this address
When i use email :timeout?
Activation Email Not Received for Discourse Admin Account, After Registering User in The Forum
Restore a backup from the command line
Unable to Send Admin Emails After Forum Installation
Can't Send Emails
Trouble with Email Verification After Discourse Installation
Issue with setting up email: Job exception: Net::SMTPAuthenticationError
:cn: Discourse Official Install Guide | Discourse 云平台安装
Getting up Brevo correctly with Discourse
Cheapest way to run Discourse?
How to change this email
Discourse + DigitalOcean + Mailjet setup
Email for completion not sending because smtp are not correct
Connect SMTP to Discourse
SMTP Mails don't send and connection fails, but openssl works
Issue with creating admin account for first time
ReadTimeout error (No solution)
Confusing email documentation
Users don't get confirmation e-mail
How Do I Set Up the E-Mail SMTP Server Required for Discourse?
Initial Activation email Not sent. What's wrong with this yaml?
Not Receiving Emails After Successful SMTP Configuration with Neo.Space
Email does not work; Net::SMTPAuthenticationError
What can I do when my users stop receiving verification emails?
Flarum to Discourse Migration with users and discussion
Editing Mail Server
Outlook SMTP Not Working
How to set domain value in Email -> Server Settings
Trouble sending mail via Namecheap Private Email (SMTP) on self-hosted Discourse
Who can help me ? Thanks!有没有人愿意帮我解决一下邮箱问题?
GMail delivery problems: is subdomain discourse.ourdomain.org strictly necessary in outgoing mails?
Not Receiving Admin Verification Email After Setup
Latest version of Discourse not sending Email
Persistent SMTP Timeout Issue with Spacemail on Discourse (VPS, Docker)
Email delivery configuration checklist
How to change Discourse email settings after installation
Deploy Discourse without Docker
./discourse-setup puts SMTP username at start of SMTP password
[Résolu] Please les modalités simple pour modifier smtp_password
How do I create Discourse forum with docker and VPS?
无法收到邮件的问题
新安装的discourse无法使用网易邮箱发送验证邮件?
Moving from Mailgun to Amazon SES as an amateur
Email don't send
Editing posts cause notification
Activation email on Spam
Installation success but no email
Admin activation E-Mail not sent on fresh self-hosted install (ubuntu 20.04)
Problem with changing password from mail
Problème de réception du mail de confirmation admin (installation sur Hostinger)
Discourse on Azure VM
Email not sending - Domain Spoofing Prohibited
DNS - NameCheap - Mailchimp - sanity check please
How can I change this? smtp
Waiting the activation email, been hours still not received
Not getting activation email
I have a question about configuring the mail system
Connecting to a SMTP server on localhost:25 without auth?
SMTP error: Must issue a STARTTLS command first
I have a problem that needs help because the Email can't be sent
Email for new user not sent
How might we better structure #howto?
Mail doesnt work after installation
Not receiving confirmation email
I did not receive an email to activate my account
Emails are not sent
New signups not receiving welcome email
Discourse with other websites, SMTP issue: End of file reached
Setup wont send me the email
Siteground email
Update failed - Not starting
Email config help
404 Error after installaton
List all users with a given email domain
I created a droplet to install Discourse, what should I do next?
New install email not working "shadowed so this will be ignored"
Is this up to date information? It did not work for me; I had to rebuild the app after changing the SMTP port.
If discourse-doctor tells the connection to port 587 failed, but the openssl s_client -connect your.smtp.server:587 -starttls smtp works fine, try this, both commands should takes the same amount of time:
time openssl s_client -starttls smtp -connect your.smtp.server:587 </dev/null > /dev/null
docker run --rm discourse/base:2.0.20231023-1945 bash -c 'time openssl s_client -starttls smtp -connect your.smtp.server:587 </dev/null' > /dev/null
If docker version is far longer, you may have a wrong configuration in your /etc/docker/daemon.json file. You may try to put google nameserver in first place :
  "dns": ["8.8.8.8", "ww.xx.yy.zz", "ww.xx.yy.za"]
port 2525 works for mailjet.
587 failed.
I edited the OP to suggest using port 2525. It’s your hosting service that blocks the port. Because of that, many mail services also support 2525.
hey, just wanted to add a note about this;
I signed up this week (July 2024) and so far, its working without having to add a credit card, using the base free tier. Based on what I have seen in old forum threads, it seems like they have been flip-flopping on this policy, and their free tiers usage and limitations, perhaps
Wow. That’s crazy and very different from how things have been for as long as I can remember.
It’s been very hard for people to figure out how to get changed to the pay-as-you-go plan and not sign up for some fairly expensive monthly plan.
Have you sent to users other than yourself?
Yes, I have sent to users, and its working. Only hitch, is that for some reason AOL email addresses are blocking my emails, but I dont think that is MailGun’s fault. I am just as surprised as you :slight_smile:
update: seems that the reason some emails are getting blocked, is because the IP used to send the free emails from MailGun is shared, so it has been reported as “Spam” by some email platforms such as AOL, Yahoo Mail, and others. Seems like everyone who is not using Gmail is seeing bounced or rejected email delivery.
Can you please explain how to check the settings in our containers/app.yml file? Us noobs don’t know how to do these things without explicit instruction. lol
If you don’t know how to use a tool like nano, then run discourse-setup again. After it’s saved the changes, you can control-c and then
./launcher destroy app;./launcher start app
ok, but how do I check the settings in my containers/app.yml file so I can look at the email section and verify the data is correct?
If you don’t like my answer you can Google “nano”.
Arguably the OP should say something about nano, though, as I said, if you don’t know what it is then just running discourse-setup again is what to do, as it reads the values in the file and you can’t screw up the formatting
Oh I see what you mean now. When you run the destroy then start commands, it displays the data I need once it’s complete. My apologies! :slight_smile:
I ran the doctor and got an error that says SMTPAuthenticationError. The doctor then says this is not a common error and they have no suggestions on how to fix it. If this happens, make sure to double check your SMTP username and password, as the Discourse setup process doesn’t tell you if it’s wrong, it just doesn’t work (doesn’t send emails) and leaves you stumped. Some things I did that helped was SSH into my server using Ubuntu instead of LISH (because I am using Linode) because LISH is terribly buggy and doesn’t support copy/paste. I then redid the setup process and copy/pasted everything this time instead of typing out 100 character passwords, lol. Anyways, I hope this helps some of my fellow noobs out there!
Your username or password is bad.
Not sure why I didn’t manage to fix that, but the error is pretty self explanatory.
It could be that you copy/pasted it wrong. It could be that it has characters that need to be escaped.
I use Brevo as my notification email sender, yet every single notification sent was rejected due to an error occurrence. I found a message in Brevo stating that “Sending has been rejected because the sender you used is not valid. Validate your sender or authenticate your domain”. Because of this, my forum cannot function at all. I’m wondering how to troubleshoot this - what kind of sender do I need? Thanks a lot!!!
For sender address can be set to mail subdomain you are using to send mail, such as mail@domain_address.
To authenticate subdomain + sender there are a few steps for that they have a guide here:
Hi Discourse people!
I have fought for several days with setting the emails parameters with port 465, and the solution is not here nor in any post I read on the forum (and I have really dug).
Of course it is a matter of what your mail server accepts. In my case, only 465 over TLS.
The two required config lines to add in app.yml are:
Some details
Default settings resulted in a Net::ReadTimeout error when trying a test email with discourse-doctor. Sending test emails from within the container work fine with e.g. curl, exactly as in this post which led me to half of the solution: Cannot send email - problem with port 465 - #10 by schungx
I could only find out about the second setting after looking at app.yml content and modifying this parameter. I have the feeling that most programs (eg. Thunderbird) implicitly set the correct protocol when selecting port 465, so maybe Discourse should? This seems to be really standard, also as highlighted here:
(link to full post)
So I would really vouch for updating the section of this guide about port 465 or make discourse-setup automatically choose the best setting.
Normally i dont comment on stuff, but that was actually helpfull!
Thanks man, the maintainer of the discourse absolutly should include this setting in the default config, i mean it was tedious to setup theirs software, still i have nothing to crictise accept that in such big project some information is not fast available and somebody should “deep into”.
OK works for me!
A post was merged into an existing topic: Use of % in SMTP Password for discourse-setup
