I’m study how discourse was implemented, and I hope to understand each fields in schemas of discourse database, so that I can quickly know the meaning of things done by ruby codes.Is there a suite document for me?
The best source of schema information is probably the annotations at the bottom of fiiles in the app/models directory. For example, the posts table columns are
The Data Explorer Plugin might be worth a look too. It has the tables and columns listed out.
Been a while here, but if you have the Data Explorer Plugin, you can also use the api to fetch everything: /admin/plugins/explorer/schema.json.
