2.2.3 Immagini interrotte ed errori JS
Just updated from 2.2.2 (self hosted, upgrade started via web interface, selected upgrade all) to 2.2.3 has broken images and caused some js errors
Uncaught Error: Could not find module `discourse/helpers/topic-status-icons` imported from `discourse/plugins/discourse-solved/discourse/initializers/extend-for-solved-button`
    at o (ember_jquery-cf9339810550f9c92505dfbb37362c58a4a8a83bcee2d99174547b01c06ed7d3.js:18)
    at i (ember_jquery-cf9339810550f9c92505dfbb37362c58a4a8a83bcee2d99174547b01c06ed7d3.js:18)
    at o.module.exports.p.(/forums/anonymous function) (https://www.finalbuilder.com/forums/assets/ember_jquery-cf9339810550f9c92505dfbb37362c58a4a8a83bcee2d99174547b01c06ed7d3.js:18:15997)
    at e (ember_jquery-cf9339810550f9c92505dfbb37362c58a4a8a83bcee2d99174547b01c06ed7d3.js:18)
    at require (ember_jquery-cf9339810550f9c92505dfbb37362c58a4a8a83bcee2d99174547b01c06ed7d3.js:18)
    at application-6157201f89cbc41715dde34af85ed4c9d799cece2e11aac8f0710af120c2affd.js:7
    at Array.forEach (<anonymous>)
    at n.start (application-6157201f89cbc41715dde34af85ed4c9d799cece2e11aac8f0710af120c2affd.js:7)
    at preload-application-data-0a59ccab480941aaac91f9e7fa7f77496323ae056aaa4158822dea35de319c01.js:1
I tried rebuilding the container but so far no joy.
@vinothkannans can you have a look?
3 Mi Piace
I rebuilt the container a second time, same result. Seems like icons etc are missing
Also none of our header customisations are showing, should be a bunch of links across the top which match the rest of our website.
Exact same problem, icons are missing, JS error occurs, no luck in Safari nor in Firefox:
1 Mi Piace
Are you on tests-passed or beta? can you flick to tests-passed and do a rebuild?
I think they’re in stable. It doesn’t have required Ember helper file.
1 Mi Piace
Is there any easy way to make this cross compatible?
I can add the helper file in stable. It will not break the UI. And it will not add the feature too.
1 Mi Piace
Sure… go for it, we need it fixed. No need to back port the whole feature.
1 Mi Piace
It’s fixed here. @vincentp & @yangyubo can you please do the upgrade.
6 Mi Piace
Problem goes away after do the upgrade, thanks!
FYI, we are on stable, and tried a rebuild as we found icons were missing.
4 Mi Piace
@vinothkannans Thanks, that fixes it!
3 Mi Piace
