Aggiornamento 2.6.0 beta 3 fallito su spazio su disco e/o memoria
I was prompted to update my 2.6.0 beta 2 site to beta 3, but the update process reportedly failed for me both times I tried it (disconcerting because I don’t recall any previous updates thus far throwing errors)
Weirdly, even part way through the update in progress, with the progress bar about half way through, the ‘Upgrade now’ button became highlighted again, even as the log below showed ongoing activity was occurring. The first time this happened, I absent mindedly clicked it, though hard to tell what effect this had.
Each time I found the process appeared to stall before the end, with error message ‘Update failed’
The log from 2nd attempt is pasted below
*** Please be patient, next steps might take a while ***
Cycling Unicorn, to free up memory
Restarting unicorn pid: 32161
Waiting for Unicorn to reload.
Waiting for Unicorn to reload…
Stopping 1 Unicorn worker(s), to free up memory
Stopping job queue to reclaim memory, master pid is 15550
$ cd /var/www/discourse && git fetch --tags --force && git reset --hard HEAD@{upstream}
From [GitHub - discourse/discourse: A platform for community discussion. Free, open, simple.](https://github.com/discourse/discourse)
t [tag update] latest-release -> latest-release
HEAD is now at 6acd2ab7d4 UX: Allow horizontal scroll on mobile post buttons
$ cd /var/www/discourse/plugins/discourse-adplugin && git fetch --tags --force && git reset --hard HEAD@{upstream}
HEAD is now at a626b8e DEV: Add testing workflow
$ cd /var/www/discourse/plugins/discourse-bbcode && git fetch --tags --force && git reset --hard HEAD@{upstream}
HEAD is now at 093fc66 DEV: linting
$ cd /var/www/discourse/plugins/discourse-data-explorer && git fetch --tags --force && git reset --hard HEAD@{upstream}
HEAD is now at 4a167a7 DEV: attempts to fix indentation
$ cd /var/www/discourse/plugins/procourse-static-pages && git fetch --tags --force && git reset --hard HEAD@{upstream}
HEAD is now at 52f6f7c Merge pull request #17 from jbrw/master
$ bundle install --deployment --jobs 4 --without test development
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set deployment 'true'` , and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set without 'test development'` , and stop using this flag
Fetching gem metadata from https://rubygems.org/…
Using rake 13.0.1
Using concurrent-ruby 1.1.7
Using thread_safe 0.3.6
Using zeitwerk 2.4.0
Using builder 3.2.4
Using erubi 1.9.0
Using mini_portile2 2.4.0
Using crass 1.0.6
Using rack 2.2.3
Using mini_mime 1.0.2
Using aws-eventstream 1.1.0
Using aws-partitions 1.329.0
Using jmespath 1.4.0
Using ember-source 2.18.2
Using execjs 2.7.0
Using msgpack 1.3.3
Using bundler 2.1.4
Using byebug 11.1.3
Using cbor 0.5.9.6
Using chunky_png 1.3.12
Using coderay 1.1.3
Using colored2 3.1.2
Using connection_pool 2.2.3
Using openssl-signature_algorithm 1.0.0
Using cppjieba_rb 0.3.3
Using diffy 3.4.0
Using method_source 1.0.0
Using thor 1.0.1
Using discourse-ember-source 3.12.2.2
Fetching minitest 5.14.2
Fetching public_suffix 4.0.6
Fetching discourse-fonts 0.0.4
Installing minitest 5.14.2
Installing public_suffix 4.0.6
Fetching exifr 1.3.8
Using fspath 3.1.2
Using image_size 1.5.0
Using in_threads 1.5.4
Using progress 3.5.2
Using email_reply_trimmer 0.1.13
Using excon 0.76.0
Using multipart-post 2.1.1
Using fast_blank 1.0.0
Using fast_xs 0.8.0
Using fastimage 2.2.0
Using ffi 1.13.1
Using flamegraph 0.9.5
Using gc_tracer 1.5.1
Using guess_html_encoding 0.0.11
Using hashie 4.1.0
Using highline 2.0.3
Installing exifr 1.3.8
Using hkdf 0.3.0
Using htmlentities 4.3.4
Using http_accept_language 2.1.1
Using json 2.3.1
Using jwt 2.2.2
Using kgio 2.11.3
Using libv8 8.4.255.0 (x86_64-linux)
Using logstash-event 1.2.02
Fetching logster 2.9.4
Installing logster 2.9.4
Using lru_redux 1.1.0
Using lz4-ruby 0.3.3
Using maxminddb 0.1.22
Using memory_profiler 0.9.14
Fetching redis 4.2.2
Installing discourse-fonts 0.0.4
Installing redis 4.2.2
Using mini_sql 0.3
Using multi_json 1.15.0
Using multi_xml 0.6.0
Using mustache 1.1.1
Fetching nio4r 2.5.4
Installing nio4r 2.5.4 with native extensions
Using oauth 0.5.4
Using optimist 3.0.1
Using pg 1.2.3
Using r2 0.2.7
Using raindrops 0.19.1
Using rchardet 1.8.0
Using rinku 2.0.6
Using rotp 6.1.0
Using rqrcode_core 0.1.2
Using rtlit 0.0.5
Using rubyzip 2.3.0
Using tilt 2.0.10
Using sshkey 2.0.0
Using stackprof 0.2.15
Using unf_ext 0.0.7.7
Using seed-fu 2.3.9
Using jquery-rails 4.4.0
Using lograge 0.11.2
Fetching rails_failover 0.5.7
Fetching rails_multisite 2.5.0
Using sassc-rails 2.1.2
Fetching discourse-ember-rails 0.18.6
Installing rails_multisite 2.5.0
Installing rails_failover 0.5.7
Installing discourse-ember-rails 0.18.6
Bundle complete! 124 Gemfile dependencies, 161 gems now installed.
Gems in the groups test and development were not installed.
Bundled gems are installed into `./vendor/bundle`
$ bundle exec rake plugin:pull_compatible_all
procourse-static-pages is already at latest compatible version
discourse-merge-users is already at latest compatible version
discourse-subscriptions is already at latest compatible version
discourse-data-explorer is already at latest compatible version
docker_manager is already at latest compatible version
discourse-adplugin is already at latest compatible version
discourse-multiselect-user-field is already at latest compatible version
discourse-bbcode is already at latest compatible version
discourse-jitsi is already at latest compatible version
Discourse-nav-links-component is already at latest compatible version
$ SKIP_POST_DEPLOYMENT_MIGRATIONS=1 bundle exec rake multisite:migrate
Multisite migrator is running using 1 threads
Migrating default
== 20200810053843 CreateDataExplorerQueries: migrating ========================
– create_table(:data_explorer_queries)
-> 0.0879s
– create_table(:data_explorer_query_groups)
-> 0.0115s
– add_index(:data_explorer_query_groups, [:query_id, :group_id], {:unique=>true})
-> 0.0019s
== 20200810053843 CreateDataExplorerQueries: migrated (0.1271s) ===============
== 20200819021210 AddUserSelectableColumnToColorSchemes: migrating ============
– add_column(:color_schemes, :user_selectable, :bool, {:null=>false, :default=>false})
-> 0.0361s
== 20200819021210 AddUserSelectableColumnToColorSchemes: migrated (0.0368s) ===
== 20200819030609 MigrateUserTopicTimersToBookmarkReminders: migrating ========
== 20200819030609 MigrateUserTopicTimersToBookmarkReminders: migrated (0.0227s)
== 20200819203846 AddColorSchemeIdToUserOptions: migrating ====================
– add_column(:user_options, :color_scheme_id, :integer)
-> 0.0032s
== 20200819203846 AddColorSchemeIdToUserOptions: migrated (0.0037s) ===========
== 20200820174703 AddPartialTargetIdIndexToReviewables: migrating =============
– add_index(:reviewables, [:target_id], {:where=>“target_type = ‘Post’”, :algorithm=>:concurrently, :name=>“index_reviewables_on_target_id_where_post_type_eq_post”})
-> 0.0134s
== 20200820174703 AddPartialTargetIdIndexToReviewables: migrated (0.0142s) ====
== 20200902054531 AddFirstUnreadPmAToGroupUser: migrating =====================
– add_column(:group_users, :first_unread_pm_at, :datetime, {:null=>false, :default=>#<Proc:0x00007f5e2c725088@/var/www/discourse/db/migrate/20200902054531_add_first_unread_pm_a_to_group_user.rb:5 (lambda)>})
-> 0.0272s
– execute(“UPDATE group_users gu\nSET first_unread_pm_at = gu.created_at\n”)
-> 0.0720s
== 20200902054531 AddFirstUnreadPmAToGroupUser: migrated (0.1001s) ============
== 20200902082203 AddFirstUnreadPmAtToUserStats: migrating ====================
– add_column(:user_stats, :first_unread_pm_at, :datetime, {:null=>false, :default=>#<Proc:0x00007f5e2c742d90@/var/www/discourse/db/migrate/20200902082203_add_first_unread_pm_at_to_user_stats.rb:5 (lambda)>})
-> 0.0288s
– execute(“UPDATE user_stats us\nSET first_unread_pm_at = u.created_at\nFROM users u\nWHERE u.id = us.user_id\n”)
-> 0.0754s
== 20200902082203 AddFirstUnreadPmAtToUserStats: migrated (0.1051s) ===========
== 20200910020909 MakeImapSyncLogColsNotNull: migrating =======================
– change_column_null(:imap_sync_logs, :message, false)
-> 0.0011s
– change_column_null(:imap_sync_logs, :level, false)
-> 0.0003s
== 20200910020909 MakeImapSyncLogColsNotNull: migrated (0.0020s) ==============
== 20200910051633 ChangeUploadsVerifiedToInteger: migrating ===================
– add_column(:uploads, :verification_status, :integer, {:null=>false, :default=>1})
-> 0.0556s
== 20200910051633 ChangeUploadsVerifiedToInteger: migrated (0.2459s) ==========
== 20200911031738 AddIndexToUploadsVerificationStatus: migrating ==============
– execute(“CREATE INDEX CONCURRENTLY IF NOT EXISTS\nidx_uploads_on_verification_status ON uploads USING btree (verification_status)\n”)
-> 0.0076s
== 20200911031738 AddIndexToUploadsVerificationStatus: migrated (0.0082s) =====
== 20200916085541 CreateUserIpAddressHistories: migrating =====================
– create_table(:user_ip_address_histories)
-> 0.0086s
– add_index(:user_ip_address_histories, [:user_id, :ip_address], {:unique=>true})
-> 0.0034s
== 20200916085541 CreateUserIpAddressHistories: migrated (0.0125s) ============
Seeding default
*** Bundling assets. This will take a while ***
$ RUBY_GC_MALLOC_LIMIT_MAX=20971520 RUBY_GC_OLDMALLOC_LIMIT_MAX=20971520 RUBY_GC_HEAP_GROWTH_MAX_SLOTS=50000 RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=0.9 bundle exec rake assets:precompile
Purging temp files
Bundling assets
I, [2020-09-26T04:15:34.191484 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/lt-aff59463076fd6741c6fec826e5bc3502630659e40a89a52385304d0d733f79e.js
I, [2020-09-26T04:15:34.831688 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/sw-1395ffdab0bd6fb90088df32240eac995374d095fa941b1c2c1151600ac690a0.js
I, [2020-09-26T04:15:35.334795 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/sv-e2c0bd16da62d25e1def2038c63f5c6a5691956299c8d1b2f2cd4e930d7570e3.js
I, [2020-09-26T04:15:36.112998 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/pt-1652f51dd6fac1cb7b5bd0faa78711b334158b553e3c7ab3ffa4380636f7ec0f.js
I, [2020-09-26T04:15:36.615626 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/es-2472cdc3c9ad70b1e74f54eac90d9418f9c8eace508a410ed67af7f521944549.js
I, [2020-09-26T04:15:37.639016 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/ru-c915653c8cf6115bf1e025ffbac13d4e705a1f715405b57759e3730d923a0251.js
I, [2020-09-26T04:15:38.008935 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/et-624e57018cbb201b8651dd25c8beb55b64ec70181a51cc5a34a4b98c6e29b8a5.js
I, [2020-09-26T04:15:39.174525 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/uk-bc59cb69648cd93765329edb21899195ec0e5ce929999087903281dcb8084697.js
I, [2020-09-26T04:15:40.235470 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/zh_CN-80e7ae3829c3a54c2b6cd230f0c43de5c8c9486d4bbce223c58b24333123515a.js
I, [2020-09-26T04:15:41.316997 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/da-51f3429bfb7e22d37494982fdcaef124a9b3c69d14afb04037f02276abb15e9d.js
I, [2020-09-26T04:15:42.401166 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/lv-f70a3961f0c2542ce855bb85b1810a4f47d1e8eb6c09bf5e5eeac238c5e2fd72.js
I, [2020-09-26T04:15:43.580012 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/he-bcb6d095f5b8a42b573cdd74c97028bfdcc447219657760d03da61e10093b0a5.js
I, [2020-09-26T04:15:44.716505 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/id-ada97e90f6c87be672e04aa85bfbd50b804f41c265ae7854aaf8bd02e12b140d.js
I, [2020-09-26T04:15:45.594078 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/sr-5bc40f5193d1f586aec28ca766eb94c7ed7e3791939d14f8087347f7de4cf1e6.js
I, [2020-09-26T04:15:46.244516 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/ja-2dfe206addb2e7069a2ee3f052b544d6ca588df14d82e819b0c4fa31feca9dd7.js
I, [2020-09-26T04:15:46.668071 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/en_US-98e1ee15d08bd830e804ac18f7aeec58a1e4689f21070d75440a5d6cf72fdbce.js
I, [2020-09-26T04:15:46.842460 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/en-d82bead5db4ee27e1698099fce258e58d16d3f6fb10901b9c5192c0de842f9b1.js
I, [2020-09-26T04:15:47.668330 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/ur-05dfafea819b54aa09ba584e043d0c30f25e87fcb8818951ab59f943359ebc75.js
I, [2020-09-26T04:15:48.398426 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/pl_PL-dff34fd819af2ae2a12fd315ec1f33d99e54f2d841d5bd2de1817495d5dd617d.js
I, [2020-09-26T04:15:49.087841 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/te-96f5c93e18f5ba7c1e1d7f04031aeedb10166aaacadedda0bbc50c9ecee9b765.js
I, [2020-09-26T04:15:49.994768 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/cs-8fa82bc7a9d51be5c76f490b54e9a45e9a657fc76ad4a943175871fba81f47e8.js
I, [2020-09-26T04:15:51.006513 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/fa_IR-f9897cc43dd1de36c163584a1b0f83be558c9f6b1daec6c8ccc349b7ec813fa1.js
I, [2020-09-26T04:15:52.051896 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/it-56d672ee509b6949ce9c53bf5f6fc0dc392a21c1466745dda6070a41849061dc.js
I, [2020-09-26T04:15:52.977508 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/ko-7ddfe94800616c59283238ec775b47f4d97c8851b93dec269ec4bb30d1f44374.js
I, [2020-09-26T04:15:54.004067 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/nl-8c40a317a6ff534078af7ace0280b52018da73a6b5ce9e244ee4683b4fad9603.js
I, [2020-09-26T04:15:54.925540 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/nb_NO-adcf93de3a7e6599ac92d0b998ac1a84e2dc8dd47ad13923027703445c2055c5.js
I, [2020-09-26T04:15:56.296000 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/th-8e2e7820508fa6f59c54d73aa51fb5b62f31c6ac53d38daca44d8284180a55d2.js
I, [2020-09-26T04:15:57.370523 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/ar-6d3800d74b50c32ee4be893960604b974097f1919d5a3f645714192dea225e0b.js
I, [2020-09-26T04:15:58.413891 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/gl-998870ca224ed5491ff7678f2ac390f5613029833caf8e5f655a5b936308007c.js
I, [2020-09-26T04:15:59.566612 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/sl-55b7b296aa9faad86b9370b2fc5289591c632cb396a6f835faceda9d19e091e1.js
I, [2020-09-26T04:16:00.476105 #20861] INFO – : Writing /var/www/discourse/public/assets/locales/hu-bc3fdd2c5161268dba71d58f87363776688eac5b6d7928458b0b13a3a9fece98.js
I, [2020-09-26T04:16:05.194849 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-adplugin-5d2f3eaacb0cdc2555b2a299fcb86eedbf23e2844628a623d4ec20ec907bcf84.js
I, [2020-09-26T04:16:05.747380 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-bbcode-1082e092e50e283df15df91614bccdf621e6342f98ec2e877bbfd58ed56e6b86.js
I, [2020-09-26T04:16:07.947593 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-data-explorer-10f42136f8ee7c543dc16393ee33d1587add4b0832d82e2e868fa50d7cd4da17.js
I, [2020-09-26T04:16:08.077099 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-details-0bd38e4002b071b9455a7fdd1038802c31d7226032c566be9ff26f168d23cefc.js
I, [2020-09-26T04:16:09.506385 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-local-dates-747acffabe6d8ac2bd99774aab5ca1cf227100c8db167286796368501e13c863.js
I, [2020-09-26T04:16:09.733285 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-merge-users-ba6ca6eef6e563e2b4936b343c09bef16dff611e867702773b840c2e283d1ce5.js
I, [2020-09-26T04:16:09.829293 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-multiselect-user-field-b338bd25aae99fd968ca39829ea166a20d381671236ecdab04c1e89f02960392.js
I, [2020-09-26T04:16:09.889116 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-narrative-bot-c43db87f1004dffa72bf81db5bfe561550f830b224352505680dde210d6ec6e1.js
I, [2020-09-26T04:16:10.355973 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-presence-550080222a76cbecd779c71e12e4088ff7bed2880db527c159342ccd66ccfc1c.js
I, [2020-09-26T04:16:15.254140 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/discourse-subscriptions-e80d52ef37a11a7026eb620965da785034738cbd2d69fcc2c140527fc3562a94.js
I, [2020-09-26T04:16:15.358506 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/docker_manager-4ced9f9c7bda9ba563c04006dbb93828d43f2c7d5b533065717c5a63da77d5fc.js
I, [2020-09-26T04:16:15.470571 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/lazy-yt-13878a92cc5d5039d6f32688a86500182843ceac829df20e96639d8026a65a8a.js
I, [2020-09-26T04:16:17.869982 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/poll-1d66ca8ab4ee4c249469ae3d51b7176593b240a8fc7a6b2fe2b416a6f7cc7a0d.js
I, [2020-09-26T04:16:18.329498 #20861] INFO – : Writing /var/www/discourse/public/assets/plugins/procourse-static-pages-0299b14a74e8a98373f3d5b5bf47f3e24e8218698628c8fa6b24a976f2367541.js
rake aborted!
MiniRacer::ScriptTerminatedError: JavaScript was terminated (either by timeout or explicitly)
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_racer-0.3.1/lib/mini_racer.rb:209:in `eval_unsafe' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_racer-0.3.1/lib/mini_racer.rb:209:in ` block (2 levels) in eval’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_racer-0.3.1/lib/mini_racer.rb:350:in `timeout' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_racer-0.3.1/lib/mini_racer.rb:208:in ` block in eval’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_racer-0.3.1/lib/mini_racer.rb:206:in `synchronize' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mini_racer-0.3.1/lib/mini_racer.rb:206:in ` eval’
/var/www/discourse/lib/discourse_js_processor.rb:134:in `block in perform' /var/www/discourse/lib/discourse_js_processor.rb:127:in ` synchronize’
/var/www/discourse/lib/discourse_js_processor.rb:127:in `perform' /var/www/discourse/lib/discourse_js_processor.rb:30:in ` transpile’
/var/www/discourse/lib/discourse_js_processor.rb:17:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:75:in ` call_processor’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:57:in `block
 in call_processors'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in
 ` reverse_each’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in `call_processors' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:134:in ` load_from_unloaded’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:60:in `block in load' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:317:in ` fetch_asset_from_dependency_cache’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:44:in `load' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:20:in ` block in initialize’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:47:in `load' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/bundle.rb:23:in ` block in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/utils.rb:200:in `dfs' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/bundle.rb:24:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:75:in `call_processor' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:57:in ` block in call_processors’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in `reverse_each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/processor_utils.rb:56:in ` call_processors’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:134:in `load_from_unloaded' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:60:in ` block in load’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/loader.rb:317:in `fetch_asset_from_dependency_cache'
 ` load’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:20:in `block in initialize' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/cached_environment.rb:47:in ` load’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/base.rb:66:in `find_asset' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/base.rb:73:in ` find_all_linked_assets’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:134:in `block in find' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:133:in ` each’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:133:in `find' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/sprockets/manifest.rb:186:in ` compile’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-rails-3.2.2/lib/sprockets/rails/task.rb:67:in `block (3 levels) in define' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-3.7.2/lib/rake/sprocketstask.rb:147:in ` with_logger’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/sprockets-rails-3.2.2/lib/sprockets/rails/task.rb:66:in `block (2 levels) in define' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/exe/rake:27:in ` <top (required)>’
/usr/local/bin/bundle:23:in `load' /usr/local/bin/bundle:23:in ` ’
Tasks: TOP => assets:precompile
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:178:in `run' /var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:86:in ` upgrade’
/var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:95:in `block in upgrade' /var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:91:in ` fork’
/var/www/discourse/plugins/docker_manager/app/controllers/docker_manager/admin_controller.rb:91:in `upgrade'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal/basic_implicit_render.rb:6:in
 ` send_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/abstract_controller/base.rb:195:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal/rendering.rb:30:in
 ` process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/abstract_controller/callbacks.rb:42:in `block
 in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/callbacks.rb:135:in
 ` run_callbacks’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/abstract_controller/callbacks.rb:41:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal/rescue.rb:22:in ` process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal/instrumentation.rb:33:in `block
 in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/notifications.rb:180:in
 ` block in instrument’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/notifications/instrumenter.rb:24:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/notifications.rb:180:in ` instrument’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal/params_wrapper.rb:245:in
 ` process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/railties/controller_runtime.rb:27:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/abstract_controller/base.rb:136:in ` process’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-6.0.3.2/lib/action_view/rendering.rb:39:in `process' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.4/lib/mini_profiler/profiling_methods.rb:78:in ` block in profile_method’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal.rb:190:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_controller/metal.rb:254:in ` dispatch’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/route_set.rb:50:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/route_set.rb:33:in ` serve’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/mapper.rb:18:in `block
 in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/mapper.rb:48:in
 ` serve’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/journey/router.rb:49:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/journey/router.rb:32:in ` each’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/journey/router.rb:32:in `serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/route_set.rb:834:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/engine.rb:527:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/railtie.rb:190:in ` public_send’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/railtie.rb:190:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/mapper.rb:19:in ` block in class:Constraints’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/mapper.rb:48:in `serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/journey/router.rb:49:in ` block in serve’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/journey/router.rb:32:in `each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/journey/router.rb:32:in ` serve’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/routing/route_set.rb:834:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/conditional_get.rb:40:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/head.rb:12:in `call' /var/www/discourse/lib/content_security_policy/middleware.rb:12:in ` call’
/var/www/discourse/lib/middleware/anonymous_cache.rb:336:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in ` context’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/cookies.rb:648:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/callbacks.rb:101:in ` run_callbacks’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in
 ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/show_exceptions.rb:33:in
 ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.9.3/lib/logster/middleware/reporter.rb:43:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/rack/logger.rb:37:in ` call_app’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/rack/logger.rb:28:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:19:in ` call’
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/remote_ip.rb:81:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/request_id.rb:27:in `call' /var/www/discourse/lib/middleware/enforce_hostname.rb:22:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/executor.rb:14:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.3.2/lib/action_dispatch/middleware/host_authorization.rb:76:in
 ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.4/lib/mini_profiler/profiler.rb:200:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-3.3.1/lib/message_bus/rack/middleware.rb:61:in ` call’
/var/www/discourse/lib/middleware/request_tracker.rb:176:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/engine.rb:527:in ` call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/railtie.rb:190:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.3.2/lib/rails/railtie.rb:190:in ` method_missing’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in ` each’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.6.0/lib/unicorn/http_server.rb:632:in ` process_client’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.6.0/lib/unicorn/http_server.rb:728:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.6.0/lib/unicorn/http_server.rb:548:in ` spawn_missing_workers’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.6.0/lib/unicorn/http_server.rb:562:in `maintain_worker_count' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.6.0/lib/unicorn/http_server.rb:295:in ` join’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.6.0/bin/unicorn:128:in `<top (required)>' /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in ` load’
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `’
Spinning up 1 Unicorn worker(s) that were stopped initially
After the 2nd apparently failed attempt, on clicking the ‘back to site link’ in the update page, I was first met with error ‘502 bad gateway’ error, but then refreshing browser, the site reappeared normally.
Going back to admin/update settings, I saw the site now reports itself as up to date.
I now don’t know whether I have a corrupted site or not, especially given the reported error reference in the log:
How do I tell?
Superficially everything seems to be working as I navigate around my site. The software, all plugins and even Docker Manager all now reported as up to date.
Is there any sort of site/verification utility available that would help allay fears of corruption?
Even if all is ok however, this upgrade process is probably not the most confidence inspiring user experiance for the average site administrator. Errors and ‘upgrade failed’ reports aside, basic things like the progress bar indicator apparently not actually corresponding to progress, and the ‘upgrade now’ button reactivating part way through upgrading are a worry.
Ciao Paul,
Per favore, rimuovi il testo dei log dal formato citazione.
Basta selezionare tutto il testo dei log e premere questo pulsante nel compositore; dopo potrai verificare il risultato nell’anteprima. :arrow_down: Mostrerà i tuoi log con un’altezza fissa, rendendoli molto più leggibili per tutti. :slightly_smiling_face:
Grazie - mi chiedevo a cosa servissero quei </>. Molto meglio!
Ho notato alcune stranezze di recente: ho effettuato l’aggiornamento tramite l’URL …/admin/upgrade ieri sera e il sito sembrava essere attivo quando ho provato, ma ho ricevuto molte email da Uptime Robot durante la notte. Il sito sembrava occasionalmente restituire un errore 502.
Ho eseguito ./launcher rebuild app quindici minuti fa e non ho visto alcun errore da allora, ma il problema sembrava essere piuttosto casuale, quindi non posso dire con certezza se abbia aiutato.
Hai provato ad aggiornare tramite la shell?
Assumendo che tu abbia un’installazione vanilla…
cd /var/discourse
Ehi @Paul_King,
ti consiglio di eseguire questo aggiornamento tramite la riga di comando invece di usare l’interfaccia web.
una volta effettuato l’accesso alla riga di comando, ecco i comandi che ho usato per aggiornare
  1. apt-get update
  2. apt-get upgrade
  3. cd /var/discourse
  4. ./launcher cleanup (questo pulisce i vecchi file non utilizzati)
Un possibile indizio: quando ho provato questo comando dalla console del mio Droplet Digital Ocean, ho ricevuto l’errore “hai meno di 5 GB di spazio libero sul disco dove si trova /var/lib/docker. Avrai bisogno di più spazio per continuare”. Quando mi è stato chiesto di recuperare spazio, ho ottenuto quanto segue:
Il pannello di controllo di Digital Ocean segnala che il droplet sta utilizzando solo 1 GB sui 25 allocati (Discourse è l’unico software installato, per quanto ne so), e anche se ho impostato il droplet per eseguire backup settimanali tramite il servizio a pagamento di Digital Ocean, capisco che questo non occupi spazio nel droplet stesso. Non ho nemmeno snapshot memorizzati nel mio droplet.
Quattro domande:
  1. Perché il comando rebuild app conclude che ho utilizzato 21 GB su 25 GB se Digital Ocean non è d’accordo?
  2. Cosa potrebbe riempire 21 GB con un forum vecchio di 7 mesi, 700 utenti, un utilizzo molto sporadico e un caricamento di file minimo (l’immagine occasionale e piccola inclusa in un post)?
  3. Perché è richiesto addirittura 5 GB di spazio su disco per rebuild app? Sicuramente Discourse non è così grande?
  4. Potrebbe questo suggerire un bug?
Consiglio di usare questo comando spesso subito dopo una normale ricompilazione.
Usa quel comando ora, prima di ricompilare di nuovo per liberare spazio.
Puoi provare a scoprirlo, ad esempio al tuo prompt della shell root:
du -kx / | sort -n | tail -33
e forse anche
find / -xdev -size +1000k -ls | sort -n -k 2 | tail
OK, il comando du (=disk usage?) riporta:
root@nz:/var/discourse# du -kx / | sort -n | tail -33
747432  /var/lib/docker/overlay2/794d92242be8354a3ba468161d1d2ea416ab43a6f70ddd7ab060384bd5a9fcd5/diff/var/www/discourse/vendor/bundle
750792  /var/lib/docker/overlay2/794d92242be8354a3ba468161d1d2ea416ab43a6f70ddd7ab060384bd5a9fcd5/diff/var/www/discourse/vendor
819620  /var/log/journal/8bebc832e1a692c83690ffe65e1256e3
860600  /var/log/journal
926492  /var/lib/docker/overlay2/fadc3460a6249ba37efa266d885f5ea3d6f6de8fee0e9b056c5376599bb7f354/diff/var/www/discourse
926504  /var/lib/docker/overlay2/fadc3460a6249ba37efa266d885f5ea3d6f6de8fee0e9b056c5376599bb7f354/diff/var/www
998192  /var/lib/docker/overlay2/fadc3460a6249ba37efa266d885f5ea3d6f6de8fee0e9b056c5376599bb7f354/diff/var
1059968 /var/log
1202004 /var/discourse/shared/standalone/import/data
1237720 /var/lib/docker/overlay2/fadc3460a6249ba37efa266d885f5ea3d6f6de8fee0e9b056c5376599bb7f354/diff/usr
1307816 /var/discourse/shared/standalone/import
1399332 /var/discourse/shared/standalone/backups/default
1399336 /var/discourse/shared/standalone/backups
1636032 /var/lib/docker/overlay2/794d92242be8354a3ba468161d1d2ea416ab43a6f70ddd7ab060384bd5a9fcd5/diff/var/www/discourse
1636040 /var/lib/docker/overlay2/794d92242be8354a3ba468161d1d2ea416ab43a6f70ddd7ab060384bd5a9fcd5/diff/var/www
1678944 /var/lib/docker/overlay2/794d92242be8354a3ba468161d1d2ea416ab43a6f70ddd7ab060384bd5a9fcd5/diff/var
1692708 /usr
1820540 /var/lib/docker/volumes
2235084 /var/lib/docker/overlay2/794d92242be8354a3ba468161d1d2ea416ab43a6f70ddd7ab060384bd5a9fcd5/diff
2235104 /var/lib/docker/overlay2/794d92242be8354a3ba468161d1d2ea416ab43a6f70ddd7ab060384bd5a9fcd5
2285628 /var/lib/docker/overlay2/fadc3460a6249ba37efa266d885f5ea3d6f6de8fee0e9b056c5376599bb7f354/diff
2285644 /var/lib/docker/overlay2/fadc3460a6249ba37efa266d885f5ea3d6f6de8fee0e9b056c5376599bb7f354
2437984 /var/discourse/shared/standalone/postgres_data/base/16384
2461228 /var/discourse/shared/standalone/postgres_data/base
2545304 /var/discourse/shared/standalone/postgres_data
5184184 /var/lib/docker/overlay2
5692972 /var/discourse/shared/standalone
5693056 /var/discourse/shared
5695776 /var/discourse
7076692 /var/lib/docker
7446508 /var/lib
14417296        /var
18614840        /
18,6 GB?
Il comando `find` restituisce:
    root@nz:/var/discourse# find / -xdev -size +1000k -ls | sort -n -k 2 | tail
       524219  217044 -rw-------   1 lxd      mlocate          222248960 May 22 03:39 /var/discourse/shared/standalone/postgres_data/base/16384/20379
       523733  234132 -rw-------   1 lxd      mlocate          239747072 May 23 01:29 /var/discourse/shared/standalone/postgres_data/base/16384/19615
       610933  244612 -rw-------   1 lxd      mlocate          250478592 Sep 25 03:37 /var/discourse/shared/standalone/postgres_data/base/16384/153088
       610816  248180 -rw-------   1 lxd      mlocate          254132224 Sep 26 03:59 /var/discourse/shared/standalone/postgres_data/base/16384/152767
      2596079  307188 -r--r--r--   1 ReadyNAS ReadyNAS  314556297 Apr 29 20:50 /var/lib/docker/overlay2/fadc3460a6249ba37efa266d885f5ea3d6f6de8fee0e9b056c5376599bb7f354/diff/var/www/discourse/.git/objects/pack/pack-ffd1b8da21b9e26b4475a3fef6537a89f21989d6.pack
      1548730  464076 -rw-r--r--   1 ReadyNAS www-data         475209681 Sep 24 03:31 /var/discourse/shared/standalone/backups/default/nz-architecture-2020-09-24-033014-v20200820232017.tar.gz
      1548729  467616 -rw-r--r--   1 ReadyNAS www-data         478832984 Sep 25 03:38 /var/discourse/shared/standalone/backups/default/nz-architecture-2020-09-25-033723-v20200820232017.tar.gz
      1548294  467636 -rw-r--r--   1 ReadyNAS www-data         478853932 Sep 26 03:54 /var/discourse/shared/standalone/backups/default/nz-architecture-2020-09-26-035209-v20200820232017.tar.gz
       794198  627936 -rw-r--r--   1 ReadyNAS ReadyNAS         643002368 Mar 28  2020 /var/discourse/shared/standalone/import/data/index.db
        60454 2097156 -rw-------   1 root     root     2147483648 Jan  4  2020 /swapfile
C’è qualcosa che risalta come inaspettatamente grande?
Non ho modo di capire cosa sia normale e cosa, eventualmente, si possa cancellare in sicurezza…
(i file ReadyNAS sono backup del forum, generati da Discourse)
Il database è di 2,5 GB. I backup combinati sono di 1,3 GB.
Hai diversi layer Docker di grandi dimensioni: sei sicuro che ./launcher cleanup sia stato completato con successo?
./launcher cleanup mi restituisce il seguente risultato, quasi istantaneamente: non sono sicuro di cosa mi stia sfuggendo…
root@nz:/var/discourse# ./launcher cleanup
ATTENZIONE! Questo rimuoverà tutti i container fermi.
Sei sicuro di voler continuare? [y/N] y
Spazio recuperato totale: 0B
ATTENZIONE! Questo rimuoverà tutte le immagini senza almeno un container associato.
Quella grande area di importazione potrebbe essere sospetta. Ma sono solo 640 MB.
Ci sono alcuni consigli qui su come verificare cosa sta utilizzando Docker e cercare di ridurlo. (È possibile che alcuni dei consigli siano errati o pericolosi.) Ho visto questo nel mio mondo piuttosto piccolo:
# docker volume ls -qf dangling=true
# docker images -a
REPOSITORY            TAG                 IMAGE ID            CREATED             SIZE
local_discourse/app   latest              33ce56b34841        3 mesi fa           2,59 GB
<none>                <none>              991acdba0b1f        4 mesi fa           2,22 GB
# docker system df
TYPE                TOTAL               ACTIVE              SIZE                RECLAIMABLE
Images              1                   1                   2,591 GB            0 B (0%)
Containers          1                   1                   920,9 MB            0 B (0%)
Local Volumes       0                   0                   0 B                 0 B
Build Cache         0                   0                   0 B                 0 B
Hai visto questo consiglio riguardo alla pulizia del database e alla ricostruzione degli indici dopo l’aggiornamento recente di PostgreSQL?
Grazie Ed, entrambe le cose hanno aiutato.
La maggior parte dei post in quella discussione non ha aiutato, ma uno suggeriva docker system prune --all --volumes --force, che ha liberato più di 1 GB.
Quella procedura ha recuperato 2,3 GB, abbastanza per raggiungere il minimo di 5 GB.
Ho poi ripetuto i primi due comandi di
Ma il processo sembrava riempire di nuovo lo spazio, perché al terzo comando ho ottenuto:
root@nz:/var/discourse# ./launcher rebuild app
Hai meno di 5 GB di spazio libero sul disco dove si trova /var/lib/docker. Avrai bisogno di più spazio per continuare.
/dev/vda1        25G   22G  3.0G  88% /
Vuoi tentare di recuperare spazio pulendo le immagini e i container di Docker nel sistema? (y/N)y
Se la pulizia è andata a buon fine, puoi riprovare ora.
A quel punto ho provato di nuovo ./launcher cleanup, ma ho ottenuto:
root@nz:/var/discourse# /launcher cleanup
-bash: /launcher: File o directory non trovata
(Dovrebbe essere ./launcher, non /launcher)
Ah, grazie Ed! Questo ha liberato 2,6 GB, appena sufficienti per completare l’installazione.
Grazie mille a tutti per i suggerimenti utili.
Mi preoccupa ancora un po’ che stia apparentemente utilizzando così tanto spazio, almeno secondo quanto riportato da Ubuntu, perché presumibilmente gli aggiornamenti futuri del forum potrebbero riscontrare lo stesso problema.
Nella mia installazione di Discourse, lo spazio su disco libero disponibile per i backup è riportato come 9 GB: una discrepanza notevole. Cosa potrebbe esserci alla base di ciò?
** Modifica ** - Riprovando du -kx / | sort -n | tail -33, vedo che Discourse ha ragione: il mio utilizzo del disco è sceso a 15 GB grazie a tutto quanto sopra.
Se vai su yourdomain.com/admin/backups
Quanti backup hai lì? Forse puoi tenerne uno e cancellare gli altri.
Solo 3 backup ora da 457 MB ciascuno, ma sembra che il problema dello spazio disponibile sul disco sia stato risolto grazie alle varie pulizie… per ora almeno.
Ho letto di sfuggita qualcosa sui Docker che accumulano ‘dati di differenza’ e log a un ritmo frenetico, e molte persone riportano problemi simili con dischi che si riempiono da soli.
Concordo sul fatto che il messaggio seguente sia preoccupante, ed è strano che Discourse ritenga di essere completamente aggiornato:
