2.6.0 Beta4 update failed with what looks like db errors
Hi,
I just tried doing a command line ‘launcher rebuild app’ to update from 2.6.0.beta3 (7afb5be5f9), which has been running fine for a while, to 2.6.0.beta4 (as of 20 minutes ago). This is how I usually do my updates.
The update failed, please see output below. I tried running launcher rebuild once more, but it failed with the same error. Next I ran discourse-doctor, which also errored out on the rebuild, but which managed to start Discourse back up on 2.6.0.beta3.
Just to recap that last bit: I’m back up on 2.6.0.beta3 and the site is functioning. But I’m not about to try an update to 2.6.0.beta4 again until I understand what happened.
The launcher output says “database system was interrupted”, but Discourse was up and running fine when I started the launcher rebuild command.
Discourse resides on AWS EFS, so has virtually unlimited space. The server has 32 GB of memory, which is plenty for this site (about 1.3 million pageviews/month).
Appreciate any help and pointers in figuring this out.
Here’s the full output log from running rebuild:
gunnar@dewis:/var/discourse$ sudo ./launcher rebuild app
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20201004-2310: Pulling from discourse/base
Digest: sha256:076ad6f035d7f38e08a2d4fdd4f429ad7a40a9cc72d9958445261cdb9e743d26
Status: Downloaded newer image for discourse/base:2.0.20201004-2310
docker.io/discourse/base:2.0.20201004-2310
Fetching origin
remote: Enumerating objects: 15, done.
remote: Counting objects: 100% (15/15), done.
remote: Compressing objects: 100% (12/12), done.
remote: Total 15 (delta 5), reused 9 (delta 3), pack-reused 0
Unpacking objects: 100% (15/15), done.
From https://github.com/discourse/discourse_docker
   1b97cb1..468f1f9  master                 -> origin/master
 * [new branch]      imagemagick-policy-xml -> origin/imagemagick-policy-xml
Updating Launcher...
Updating 1b97cb1..468f1f9
Fast-forward
 samples/mail-receiver.yml | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
Launcher updated, restarting...
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up to date.
I, [2020-10-19T18:46:41.157056 #1]  INFO -- : Loading --stdin
I, [2020-10-19T18:46:41.162007 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2020-10-19T18:46:41.197444 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2020-10-19T18:46:41.197650 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2020-10-19T18:46:41.202176 #1]  INFO -- :
I, [2020-10-19T18:46:41.202375 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-10-19T18:46:41.208709 #1]  INFO -- :
I, [2020-10-19T18:46:41.208877 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2020-10-19T18:46:41.215819 #1]  INFO -- :
I, [2020-10-19T18:46:41.215957 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2020-10-19T18:46:41.219629 #1]  INFO -- :
I, [2020-10-19T18:46:41.219800 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-10-19T18:46:41.222805 #1]  INFO -- :
I, [2020-10-19T18:46:41.222936 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/10/19 18:46:41 socat[27] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): Connection refused
I, [2020-10-19T18:46:41.237039 #1]  INFO -- :
I, [2020-10-19T18:46:41.237173 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-10-19T18:46:41.292499 #1]  INFO -- :
I, [2020-10-19T18:46:41.292674 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-10-19T18:46:41.304292 #1]  INFO -- :
I, [2020-10-19T18:46:41.304434 #1]  INFO -- : > mkdir -p /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-10-19T18:46:41.310575 #1]  INFO -- :
I, [2020-10-19T18:46:41.310782 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/12-main.pg_stat_tmp
I, [2020-10-19T18:46:41.317554 #1]  INFO -- :
I, [2020-10-19T18:46:41.322287 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2020-10-19T18:46:41.326660 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2020-10-19T18:46:41.330737 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2020-10-19T18:46:41.334906 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2020-10-19T18:46:41.335100 #1]  INFO -- : > chown -R root /var/lib/postgresql/12/main
I, [2020-10-19T18:46:42.155381 #1]  INFO -- :
I, [2020-10-19T18:46:42.155536 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/12/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-10-19T18:46:42.157629 #1]  INFO -- :
I, [2020-10-19T18:46:42.157703 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-10-19T18:47:06.520719 #1]  INFO -- :
I, [2020-10-19T18:47:06.520876 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-10-19T18:47:06.523564 #1]  INFO -- :
I, [2020-10-19T18:47:06.523706 #1]  INFO -- : > /root/upgrade_postgres
I, [2020-10-19T18:47:06.540126 #1]  INFO -- :
I, [2020-10-19T18:47:06.540286 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2020-10-19T18:47:06.542555 #1]  INFO -- :
I, [2020-10-19T18:47:06.543828 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/12/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.544330 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.545027 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.545814 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.546523 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.547230 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.547896 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2020-10-19T18:47:06.561717 #1]  INFO -- :
I, [2020-10-19T18:47:06.562046 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.562327 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.563080 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/12/main/postgresql.conf
I, [2020-10-19T18:47:06.564238 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/12/main/pg_hba.conf
I, [2020-10-19T18:47:06.564505 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/12/main/pg_hba.conf
I, [2020-10-19T18:47:06.565039 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main
I, [2020-10-19T18:47:06.566806 #1]  INFO -- : > sleep 5
2020-10-19 18:47:06.629 UTC [50] LOG:  starting PostgreSQL 12.4 (Debian 12.4-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
2020-10-19 18:47:06.629 UTC [50] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2020-10-19 18:47:06.629 UTC [50] LOG:  listening on IPv6 address "::", port 5432
2020-10-19 18:47:06.665 UTC [50] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2020-10-19 18:47:07.211 UTC [53] LOG:  database system was interrupted; last known up at 2020-10-19 18:40:46 UTC
I, [2020-10-19T18:47:11.568937 #1]  INFO -- :
I, [2020-10-19T18:47:11.569207 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2020-10-19 18:47:11.636 UTC [57] postgres@postgres FATAL:  the database system is starting up
2020-10-19 18:47:11.638 UTC [58] postgres@template1 FATAL:  the database system is starting up
createdb: error: could not connect to database template1: FATAL:  the database system is starting up
I, [2020-10-19T18:47:11.640042 #1]  INFO -- :
I, [2020-10-19T18:47:11.640270 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2020-10-19 18:47:11.704 UTC [69] postgres@discourse FATAL:  the database system is starting up
psql: error: could not connect to server: FATAL:  the database system is starting up
I, [2020-10-19T18:47:11.706232 #1]  INFO -- :
I, [2020-10-19T18:47:11.706429 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
2020-10-19 18:47:11.761 UTC [80] postgres@discourse FATAL:  the database system is starting up
I, [2020-10-19T18:47:11.763159 #1]  INFO -- :
I, [2020-10-19T18:47:11.763357 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
2020-10-19 18:47:11.818 UTC [91] postgres@discourse FATAL:  the database system is starting up
I, [2020-10-19T18:47:11.819734 #1]  INFO -- :
I, [2020-10-19T18:47:11.819998 #1]  INFO -- : Terminating async processes
I, [2020-10-19T18:47:11.820025 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main pid: 50
2020-10-19 18:47:11.820 UTC [50] LOG:  received fast shutdown request
I, [2020-10-19T18:47:21.820568 #1]  INFO -- : HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main pid:50 did not terminate cleanly, forcing termination!
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 81 exit 2>
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
809e00dc988196b9a3c0bfe215ff0ba30fa00056e1d2ad92818bc6b9d911df62
That is a very peculiar choice. Why not use RDS ?
This happens when the container is not gracefully shutdown, so PostgreSQL will have to perform a recovery process on next start up.
This usually happens very fast, but if your database is big (your case) and/or the disk is slow (really your case) this can be too slow and our rebuild script doesn’t know what to do.
A simple recovery method is starting the container again with ./launcher start app, letting it run happily for some time (let’s say 1h) and trying a rebuild later.
Because I have zero idea how to even begin implementing that. It’s an interesting idea, though.
EFS is just a file system, so easy to implement. And fast enough for normal operations, at least for our use. Or, at least that’s what I thought.
Right, that’s what I thought. The interesting part is that when I fired up launcher, Discourse had been running for a while. So, it was the launcher script itself that shut down PostgreSQL.
OK, I’ll try that. Thanks!
Do you know when was your last previous rebuild?
I increased the time we wait for the DB to shutdown gracefully in wait a bit more if necessary for container stop · discourse/discourse_docker@49ed141 · GitHub, so if you were behind that commit this was a common problem.
Not sure, but it was definitely after May, when I see that change was committed. Probably more like a month ago. You can even see the “-t 60” in the output above.
I just tried the rebuild again, and this time it completed successfully. I guess in the future I have to check first and make sure that PostgreSQL is idle or near idle before I hit rebuild.
Thanks for all your help!
Not sure how I missed that :man_facepalming:.
Do you remember if that step took the full 60 seconds and continued after that ?
yay!
I can’t say for sure, but I’m pretty sure it didn’t take as long as 60s. I’ll pay more attention to that in the future, when I rebuild.
