Bootstrapが失敗しました。助けてください :(
Trying to update and Discourse is failing to bootstrap, can anyone advise what steps I should take to get my site back online? I ran discourse-doctor, but it wasn’t able to rebuild either. I’ll paste my logs from my (third?) attempt below:
 I, [2020-04-11T13:05:40.743940 #1]  INFO -- : Loading --stdin
I, [2020-04-11T13:05:40.750131 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2020-04-11T13:05:40.800464 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2020-04-11T13:05:40.800750 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2020-04-11T13:05:40.804473 #1]  INFO -- :
I, [2020-04-11T13:05:40.804720 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-04-11T13:05:40.809297 #1]  INFO -- :
I, [2020-04-11T13:05:40.809573 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2020-04-11T13:05:40.813859 #1]  INFO -- :
I, [2020-04-11T13:05:40.814113 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2020-04-11T13:05:40.818749 #1]  INFO -- :
I, [2020-04-11T13:05:40.819005 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-04-11T13:05:40.823141 #1]  INFO -- :
I, [2020-04-11T13:05:40.823401 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/04/11 13:05:40 socat[26] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): Connection refused
I, [2020-04-11T13:05:40.831215 #1]  INFO -- :
I, [2020-04-11T13:05:40.831436 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-04-11T13:05:40.837350 #1]  INFO -- :
I, [2020-04-11T13:05:40.837549 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-04-11T13:05:40.843241 #1]  INFO -- :
I, [2020-04-11T13:05:40.843486 #1]  INFO -- : > mkdir -p /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-04-11T13:05:40.848311 #1]  INFO -- :
I, [2020-04-11T13:05:40.848643 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-04-11T13:05:40.853421 #1]  INFO -- :
I, [2020-04-11T13:05:40.863897 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2020-04-11T13:05:40.873965 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2020-04-11T13:05:40.884485 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2020-04-11T13:05:40.895036 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2020-04-11T13:05:40.895478 #1]  INFO -- : > chown -R root /var/lib/postgresql/10/main
I, [2020-04-11T13:06:09.192272 #1]  INFO -- :
I, [2020-04-11T13:06:09.192593 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/10/bin/initdb -D /shared/postgres_data || exit 0
I, [2020-04-11T13:06:09.197837 #1]  INFO -- :
I, [2020-04-11T13:06:09.197992 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2020-04-11T13:06:09.228153 #1]  INFO -- :
I, [2020-04-11T13:06:09.228375 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2020-04-11T13:06:09.233425 #1]  INFO -- :
I, [2020-04-11T13:06:09.233760 #1]  INFO -- : > /root/upgrade_postgres
I, [2020-04-11T13:06:09.243357 #1]  INFO -- :
I, [2020-04-11T13:06:09.243596 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2020-04-11T13:06:09.249007 #1]  INFO -- :
I, [2020-04-11T13:06:09.249495 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/10/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.272106 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.272853 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.273496 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.274139 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.274757 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.275288 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2020-04-11T13:06:09.282029 #1]  INFO -- :
I, [2020-04-11T13:06:09.282556 #1]  INFO -- : Replacing (?-mix:#?max_wal_senders *=.*) with max_wal_senders = $db_max_wal_senders in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.330309 #1]  INFO -- : Replacing (?-mix:#?wal_level *=.*) with wal_level = $db_wal_level in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.331016 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.331655 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.332347 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/10/main/postgresql.conf
I, [2020-04-11T13:06:09.333020 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/10/main/pg_hba.conf
I, [2020-04-11T13:06:09.333660 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/10/main/pg_hba.conf
I, [2020-04-11T13:06:09.334205 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main
I, [2020-04-11T13:06:09.338659 #1]  INFO -- : > sleep 5
2020-04-11 13:06:09.481 UTC [49] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2020-04-11 13:06:09.482 UTC [49] LOG:  listening on IPv6 address "::", port 5432
2020-04-11 13:06:09.544 UTC [49] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2020-04-11 13:06:10.813 UTC [52] LOG:  database system shutdown was interrupted; last known up at 2020-04-11 12:42:48 UTC
2020-04-11 13:06:12.356 UTC [52] LOG:  database system was not properly shut down; automatic recovery in progress
2020-04-11 13:06:12.416 UTC [52] LOG:  redo starts at 84/BD1A85B0
2020-04-11 13:06:12.446 UTC [52] LOG:  invalid record length at 84/BD7B3570: wanted 24, got 0
2020-04-11 13:06:12.446 UTC [52] LOG:  redo done at 84/BD7B3530
2020-04-11 13:06:12.446 UTC [52] LOG:  last completed transaction was at log time 2020-04-11 11:53:53.069757+00
I, [2020-04-11T13:06:14.343128 #1]  INFO -- :
I, [2020-04-11T13:06:14.343449 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2020-04-11 13:06:14.409 UTC [56] postgres@postgres FATAL:  the database system is starting up
2020-04-11 13:06:14.411 UTC [57] postgres@template1 FATAL:  the database system is starting up
createdb: could not connect to database template1: FATAL:  the database system is starting up
I, [2020-04-11T13:06:14.413548 #1]  INFO -- :
I, [2020-04-11T13:06:14.413822 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2020-04-11 13:06:14.493 UTC [68] postgres@discourse FATAL:  the database system is starting up
psql: FATAL:  the database system is starting up
I, [2020-04-11T13:06:14.495917 #1]  INFO -- :
I, [2020-04-11T13:06:14.496250 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
2020-04-11 13:06:14.574 UTC [79] postgres@discourse FATAL:  the database system is starting up
I, [2020-04-11T13:06:14.576284 #1]  INFO -- :
I, [2020-04-11T13:06:14.576674 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
2020-04-11 13:06:14.655 UTC [90] postgres@discourse FATAL:  the database system is starting up
I, [2020-04-11T13:06:14.658074 #1]  INFO -- :
I, [2020-04-11T13:06:14.658635 #1]  INFO -- : Terminating async processes
I, [2020-04-11T13:06:14.658722 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid: 49
2020-04-11 13:06:14.658 UTC [49] LOG:  received fast shutdown request
I, [2020-04-11T13:06:24.659800 #1]  INFO -- : HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/main pid:49 did not terminate cleanly, forcing termination!
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 80 exit 2>
exec failed with the params "su postgres -c 'psql $db_name -c \"alter schema public owner to $db_user;\"'"
3956a617d80571dd1ef87fcf7d23a319190bd909477e703ccb22cb25d0e137c8
データベースが破損しているようです。ディスク容量は十分ですか?(それが問題ではないとは思いますが、もしそうであれば助かります。)
最も簡単な解決策は、データベースディレクトリを削除して新しいデータベースを構築することです。その後、最新のバックアップから復元できます。
熱中症から抜け出した今、状況を報告します。サーバーを再起動したところ、アプリが再構築されました。これは @merefield さんの提案で、他の場所で偶然見つけたものを、最後の手段として試したものです。
したがって、Postgres が何を問題視していたのかは、いまだに謎のままです。今は新しい、しかしそれほど深刻ではない問題に直面しています。良い側面としては、大規模なデータベースを消去する必要がなかったことです。
@pfaffman さん、当社は十分なストレージ容量を持っており、上限に達するほどではありません。
ご意見ありがとうございます。私の苦い経験が、誰かの助けになれば幸いです :slight_smile:
こんにちは。
バージョンアップのための再構築中に、全く同じメッセージを受け取りました。
私たちも初めての経験で、同じことが起きていると思っていました。
そして、ためらいながらバックアップディレクトリを探しました。最新のバックアップがあったので、少し安心しました。
サーバーを再起動したわけではありませんが、少し待って、2回目の再構築も同じエラーメッセージ invalid record length at で失敗した後、3回目の試行でアップデートプロセスが機能するようになったことを共有したいと思います。サーバーには十分なディスク容量がありますが、現在はI/O負荷が少し高くなっています。
これは、同じような状況に陥っている他の人々にとって役立つかもしれません。この経験から、a) 再構築を試みる前にホストシステムのリソース過剰消費を軽減すること、b) あまり早く諦めないことをお勧めします。
よろしくお願いいたします。
Andreas.
回復処理中とのことですので、回復させてみてはいかがでしょうか。回復させるために、古いコンテナを再起動することをお勧めします。
解決しましたか?
すべてうまくいき、3回目の試行でエラーなくアップグレードが完了しました。ありがとうございました。そして、良いお年を!
以前に見られた類似の問題は、タイムアウト値を調整することで解決しました。
または、待つことによって解決しました。
