Easiest is probably to change DRC to DRC1 (or whatever) in the web interface (and I think it’ll also fix @ references in posts?). You don’t need to change username_lower, as that’s calculated.
Plot twist: No matter which of the two users I click in the web GUI, I get the profile details of just one of them (the first one, the one with the lowest id#). Seems even the web GUI is getting confused by these duplicates.
I was going to rename the newest user, because I figure the first to register the username has dibs, but the GUI doesn’t give me that option.
This is all making me very nervous. I think yet another backup is in order.
Right. The GUI will use the index, which will return the first one (because it’s the one in the index).
I would probably rename the new user in rails, I guess. Here ends my free support on this one. If you can’t find an example and no one else will help, you can email jay@literatecomputing.com if you’ve got a budget.
In my case, the problem was duplicate users. So, focusing on that, one way of finding them that worked well for me, was this:
SELECT username_lower, count(*) from users GROUP by username_lower HAVING count(*) > 1;
This gave me a list of the duplicates, with the count for each.
username_lower | count
jagger | 2
richards | 2
patrick | 2
peter | 2
jagman | 2
(5 rows)
After fixing those, I was able to run a successful reindex, and after that, a successful rebuild.
Good one! I couldn’t remember to do the count(*) offhand.
