2 emails rejected by 2026.4.0-latest ( 5f0d95e1f1 )
Hi, I’m seeing an intermittent inbound email processing failure on a self-hosted site using mail-receiver.
What happened
Two separate inbound emails:
  • were delivered to the correct Discourse address
  • appear in /admin/email/received
  • also appear in /admin/email/rejected
  • show the generic rejection text: “There was an unrecognised error whilst processing your email and it wasn’t posted.”
At around the same time, logs showed ActiveRecord::Deadlocked.
Why I think this may be a bug
I compared the rejected emails with a later successful email of a very similar format:
  • same sender pattern
  • same Microsoft / Power Automate path
  • same visible To: shape
  • same SMTP envelope recipient to the Discourse address
So this does not look like a simple configuration issue with mail-receiver.
Evidence
For both rejected emails:
  • they were separate deliveries with different Message-IDs
  • they had different Postfix queue ids
  • both were delivered for <ppyem3.accomodation@discourse.domain.com>
I also observed ActiveRecord::Deadlocked in logs around the same period.
Hosting context
  • self-hosted
  • using mail-receiver
  • small IONOS VPS
  • 1 web worker configured
I realise the 1 web worker may just be background context rather than the cause, since this appears to be inbound email/background processing rather than web request handling.
If useful, I can provide:
  • redacted headers for the 2 rejected emails
  • redacted headers for a successful comparable email
  • the deadlock log entry
browsing the /logs endpoint, i see the two errors
env
hostname	ubuntu-app
process_id	2297
application_version	5f0d95e1f11a9cb5acbe8c7a61142400fc506f06
job	Jobs::ProcessEmail
db	default
time	7:48 pm
backtrace
activesupport-8.0.5/lib/active_support/broadcast_logger.rb:218:in 'block in ActiveSupport::BroadcastLogger#dispatch'
activesupport-8.0.5/lib/active_support/broadcast_logger.rb:217:in 'Array#map'
activesupport-8.0.5/lib/active_support/broadcast_logger.rb:217:in 'ActiveSupport::BroadcastLogger#dispatch'
activesupport-8.0.5/lib/active_support/broadcast_logger.rb:129:in 'ActiveSupport::BroadcastLogger#error'
/var/www/discourse/lib/email/processor.rb:126:in 'Email::Processor#handle_failure'
/var/www/discourse/lib/email/processor.rb:31:in 'Email::Processor#process!'
/var/www/discourse/lib/email/processor.rb:13:in 'Email::Processor.process!'
/var/www/discourse/app/jobs/regular/process_email.rb:8:in 'Jobs::ProcessEmail#execute'
/var/www/discourse/app/jobs/base.rb:318:in 'block (2 levels) in Jobs::Base#perform'
rails_multisite-7.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in 'RailsMultisite::ConnectionManagement::NullInstance#with_connection'
rails_multisite-7.0.0/lib/rails_multisite/connection_management.rb:17:in 'RailsMultisite::ConnectionManagement.with_connection'
/var/www/discourse/app/jobs/base.rb:305:in 'block in Jobs::Base#perform'
/var/www/discourse/app/jobs/base.rb:301:in 'Array#each'
/var/www/discourse/app/jobs/base.rb:301:in 'Jobs::Base#perform'
sidekiq-7.3.10/lib/sidekiq/processor.rb:220:in 'Sidekiq::Processor#execute_job'
sidekiq-7.3.10/lib/sidekiq/processor.rb:185:in 'block (4 levels) in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:180:in 'Sidekiq::Middleware::Chain#traverse'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:183:in 'block in Sidekiq::Middleware::Chain#traverse'
/var/www/discourse/lib/sidekiq/suppress_user_email_errors.rb:6:in 'Sidekiq::SuppressUserEmailErrors#call'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:182:in 'Sidekiq::Middleware::Chain#traverse'
/var/www/discourse/lib/sidekiq/discourse_event.rb:6:in 'Sidekiq::DiscourseEvent#call'
/var/www/discourse/lib/sidekiq/pausable.rb:131:in 'Sidekiq::Pausable#call'
sidekiq-7.3.10/lib/sidekiq/job/interrupt_handler.rb:9:in 'Sidekiq::Job::InterruptHandler#call'
sidekiq-7.3.10/lib/sidekiq/metrics/tracking.rb:26:in 'Sidekiq::Metrics::ExecutionTracker#track'
sidekiq-7.3.10/lib/sidekiq/metrics/tracking.rb:134:in 'Sidekiq::Metrics::Middleware#call'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:173:in 'Sidekiq::Middleware::Chain#invoke'
sidekiq-7.3.10/lib/sidekiq/processor.rb:184:in 'block (3 levels) in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:145:in 'block (6 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_retry.rb:118:in 'Sidekiq::JobRetry#local'
sidekiq-7.3.10/lib/sidekiq/processor.rb:144:in 'block (5 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/config.rb:39:in 'block in <class:Config>'
sidekiq-7.3.10/lib/sidekiq/processor.rb:139:in 'block (4 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/processor.rb:281:in 'Sidekiq::Processor#stats'
sidekiq-7.3.10/lib/sidekiq/processor.rb:134:in 'block (3 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_logger.rb:15:in 'Sidekiq::JobLogger#call'
sidekiq-7.3.10/lib/sidekiq/processor.rb:133:in 'block (2 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_retry.rb:85:in 'Sidekiq::JobRetry#global'
sidekiq-7.3.10/lib/sidekiq/processor.rb:132:in 'block in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_logger.rb:40:in 'Sidekiq::JobLogger#prepare'
sidekiq-7.3.10/lib/sidekiq/processor.rb:131:in 'Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/processor.rb:183:in 'block (2 levels) in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:182:in 'Thread.handle_interrupt'
sidekiq-7.3.10/lib/sidekiq/processor.rb:182:in 'block in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:181:in 'Thread.handle_interrupt'
sidekiq-7.3.10/lib/sidekiq/processor.rb:181:in 'Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:86:in 'Sidekiq::Processor#process_one'
sidekiq-7.3.10/lib/sidekiq/processor.rb:76:in 'Sidekiq::Processor#run'
sidekiq-7.3.10/lib/sidekiq/component.rb:10:in 'Sidekiq::Component#watchdog'
sidekiq-7.3.10/lib/sidekiq/component.rb:19:in 'block in Sidekiq::Component#safe_thread'
info
Unrecognized error type (ActiveRecord::Deadlocked: PG::TRDeadlockDetected: ERROR:  deadlock detected
DETAIL:  Process 1170676 waits for ShareLock on transaction 3318694; blocked by process 1169876.
Process 1169876 waits for ExclusiveLock on tuple (4,27) of relation 74547 of database 16384; blocked by process 1170546.
Process 1170546 waits for ShareLock on transaction 3318690; blocked by process 1170676.
HINT:  See server log for query details.
CONTEXT:  while updating tuple (1,54) in relation "user_stats"
) when processing incoming email
Backtrace:
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:109:in 'PG::Connection#exec'
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:109:in 'PG::Connection#async_exec'
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/connection_adapters/postgresql/database_statements.rb:167:in 'ActiveRecord::ConnectionAdapters::PostgreSQL::DatabaseStatements#perform_query'
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/connection_adapters/abstract/database_statements.rb:556:in 'block (2 levels) in ActiveRecord::ConnectionAdapters::DatabaseStatements#raw_execute'
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/connection_adapters/abstract_adapter.rb:1022:in 'block in ActiveRecord::ConnectionAdapters::AbstractAdapter#with_raw_connection'
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.5/lib/active_support/concurrency/null_lock.rb:9:in 'ActiveSupport::Concurrency::NullLock#synchronize'
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/connection_adapters/abstract_adapter.rb:991:in 'ActiveRecord::ConnectionAdapters::AbstractAdapter#with_raw_connection'
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/connection_ad...
env
hostname	ubuntu-app
process_id	2297
db	default
time	7:48 pm
backtrace
info
DETAIL:  Process 1170678 waits for ShareLock on transaction 3318690; blocked by process 1170676.
Process 1169876 waits for ExclusiveLock on tuple (4,27) of relation 74547 of database 16384; blocked by process 1170678.
CONTEXT:  while locking tuple (4,27) in relation "categories"
Backtrace:
  /var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/connection_ada...
Hi, thanks for taking a look - I want to make sure I gather the right additional data before running anything noisy on the server.
Based on the deadlock and how Jobs::ProcessEmail runs, I’m thinking the following might help narrow this down, but I’d appreciate confirmation before I proceed.
1. Email header comparison (failed vs successful)
I can extract and post redacted raw headers from:
  • /admin/email/received → “Show original”
For:
  • 1 failed email
or both as per
  • 1 successful email of the same pattern
as per
This would include:
  • Message-ID
  • From
  • To
  • Delivered-To
  • Return-Path
  • top Received: lines
:backhand_index_pointing_right: Would that comparison be useful here?
2. Sidekiq job outcome (retry / dead set)
Since this is happening inside Jobs::ProcessEmail, I can check whether the jobs:
  • retried
  • eventually succeeded
  • or landed in the dead set
Using:
./launcher enter app
rails c
Sidekiq::RetrySet.new.select { |j| j.klass == "Jobs::ProcessEmail" }
Sidekiq::DeadSet.new.select { |j| j.klass == "Jobs::ProcessEmail" }
:backhand_index_pointing_right: Would confirming the retry/dead-set behaviour help diagnose this?
  1. Concurrency configuration
I mentioned I’m running with 1 web worker, but I realise Sidekiq concurrency is likely more relevant for a deadlock.
I can share the relevant values from app.yml, e.g.:
UNICORN_WORKERS:
SIDEKIQ_CONCURRENCY:
At the moment, I don’t have SIDEKIQ_CONCURRENCY explicitly set in app.yml, so I believe this is running with the default concurrency (i.e. multiple Sidekiq threads).
:backhand_index_pointing_right: Would that be important context for interpreting the deadlock?
  1. PostgreSQL version
Since this is a PG::TRDeadlockDetected, I can also confirm the exact PostgreSQL version in use.
:backhand_index_pointing_right: Is that worth including?
  1. Timing of inbound emails
I observed that the two failed emails were processed very close together in time (same minute).
I can extract more precise timing from logs if useful.
:backhand_index_pointing_right: Would tighter timing correlation help confirm whether this is a concurrency-triggered issue?
If helpful, I can gather and post all of the above in a follow-up - just wanted to check what would be most useful first.
Thanks again :+1:
