orli
(orjanL)
September 10, 2021, 10:32am
1
Hi, I would like to create some weekly statistic reports using the REST API. I will be doing this for
forum linkingyourthinking com
but I would like to start early before I have gotten the keys from the administrator which might take a while, since they are in the middle of a 6 week workshop.
So I was hoping to begin right now with try.discourse.org , Is that possible? I have tried
curl -X GET https://try.discourse.org/site.json
and it works nicely.
You can set up a local development instance of discourse for such work. It is fairly simple to do so.
See How do I set up a local Discourse Development Environment?
orli
(orjanL)
September 10, 2021, 11:51am
3
Thanks for the tip! Will there by any demo data in such an instance: users, groups and posts?
There will be some default seeded data but you’re always free to create some data as per your own need.
Falco
(Falco)
September 10, 2021, 1:04pm
5
If you are doing reports on public data on try.discourse.org you won’t need the API keys, as the GET requests will work just fine without it!
orli
(orjanL)
September 10, 2021, 1:11pm
6
Thank you! I don’t have the terminology clear for me right now. I want to
list all groups
for each group, list group member statistics: seen, posts, read time, …
do this on a weekly basis and mail to the group leaders/guides.
That data is probably not public?
Falco
(Falco)
September 10, 2021, 1:20pm
7
It is! Discourse aims to be an open and crawleable platform by default . In fact you can even do the same on Meta.
orli:
list all groups
curl https://meta.discourse.org/g.json
orli:
curl https://meta.discourse.org/groups/translators/members.json?offset=0&order=&asc=true&filter=
https://meta.discourse.org/u/falco/summary.json
Group leader data will be on the first request.
Hi can anyone tell me the difference and usage of Api-key and Api-Username.
Canapin
(Coin-coin le Canapin)
January 28, 2025, 3:47pm
9
The api username will tell Discourse which capabilities are enabled. An admin or a regular user don’t have the same capabilities, and using one or another will restrict what you can achieve using the api.
the api key is the password to be used with the api username.
So in my scenario I only want to use the discourse api and my confusion is that every user who is using my app can create post, like, comment other features so now do i want to create api-username and api-key for each user to use respective api’s?
Lilly
( Lilly)
January 29, 2025, 6:40am
12
have you read the api documentation?
especially this
Discourse contains a system for generating API keys per user if a very specific protocol is followed. This feature facilitates “application” access to Discourse instances without needing to involve moderators.
High level description
At a high level:
Client (desktop app, browser plugin, mobile app) generates a private/public key pair and return url
Client redirects to a route on discourse giving discourse its public key
Discourse gets approval from user to use app
Discourse generat…
also these
Discourse API
Please view the Discourse API Documentation site for detailed info:
https://docs.discourse.org
Deprecation Warning!
On April 6th, 2020 we dropped support for all non-HTTP header based authentication (excluding some rss, mail-receiver, and ics routes). This means that API requests that have an api_key and api_username in the query params or in the HTTP body of the request will soon stop working. Please see the example cURL request below for how to update your API requ…
Acc. to doc I have created a “All users” api key but I am getting this error
"errors": [
"You are not permitted to view the requested resource. The API username or key is invalid."
"error_type": "invalid_access"
in post man while hitting this api /tags.json.
Can you please help me with this
Canapin
February 4, 2025, 12:36pm
14
Can you post your full request here?
