Discourse チャットボット 🤖
:information_source: Summary The Original AI Chatbot for Discourse
:hammer_and_wrench: Repository Link GitHub - merefield/discourse-chatbot: An AI bot with RAG capability for Topics, Chat & Customer Support in Discourse, currently powered by OpenAI · GitHub
:open_book: Install Guide How to install plugins in Discourse
:heart: Sponsorship Please consider becoming an ongoing sponsor of my open source work at a level that suits your or your organisation’s resources and needs to ensure this plugin gets the maintenance it deserves and continues to work for your site in the future.
Enjoying this plugin? Please :star: it on GitHub ! :pray:
:information_source: As this is an independently contributed plugin, please make support, bug, ux, and feature requests here in this topic. NB This plugin is not available on Discourse.org hosting. You can install it if you are self-hosted and possibly if you are on third party hosting (but check with your provider).
What is it?
  • The original Discourse AI Chatbot!
  • You can use this bot for some Customer Support information tasks (see this guide Building a technical support chatbot)
  • Converse with the bot in any Topic or Chat Channel, one to one or with others! Supports Threads.
  • Customise the character of your bot to suit your forum!
    • want it to sound like William Shakespeare, or Winston Churchill? can do!
  • The “RAG Mode” bot can:
    • Search your forum** for answers so the bot can be an expert on the subject of your forum.
      • Rerank the searches to favour particular groups of authors or Topic tags
      • not just be aware of the information on the current Topic or Channel.
    • Ask your users privately about their outstanding incomplete User Fields.
    • Render and edit AI pictures
    • Search Wikipedia
    • Search current news*
    • Search Google*
    • Crawl remotes sites*
    • Return current End Of Day market data for stocks.*
    • Do “complex” maths accurately (with no made up or “hallucinated” answers!)
    • These “tools” can be extended with a plugin, see below.
  • Vision support - the bot can see your pictures and answer questions on them!
  • Automatically respond to new Topics in specific Categories
  • Uses cutting edge Open AI API and functions capability of their excellent, industry leading Large Language Models.
  • Includes a special quota system to manage access to the bot: more trusted and/or paying members can have greater access to the bot!
    • Meter usage by Query or by Tokens.
  • Also supports Azure and proxy server connections.
    • Use third party proxy processes to translate the calls to support alternative LLMs like Gemini e.g. this one
*sign-up for external (not affiliated) API services required. Links in settings.
RAG mode is very smart and knows facts posted on your forum:
Basic bot mode can sometimes make mistakes, but is cheaper to run because it makes fewer calls to the Large Language Model:
(Sorry China! :wink: )
:biohazard: **Bot’s “vision” - what it can see (potentially share) and privacy :biohazard:
This bot can be used in public spaces on your forum. To make the bot especially useful there is RAG mode (one setting per bot trust level). This is not set by default.
In this mode the bot is, by default, privy to all content a Trust Level 1 user would see, working from this setting:
Thus, if interacted with in a public facing Topic, there is a possibility the bot could “leak” information if you tend to gate content at the Trust Level 0 or 1 level via Category permissions. This level was chosen because through experience most sites usually do not gate sensitive content at low trust levels but it depends on your specific needs.
For this mode, make sure you have at least one user with Trust Level 1 and no additional group membership beyond the automated groups. (bear in mind the bot will then know everything a TL1 level user would know and can share it). You can choose to lower chatbot embeddings benchmark user trust level if you have a Trust Level 0 user with no additional group membership beyond automated groups.
Alternatively:
  • Switch chatbot embeddings strategy to category and populate chatbot embeddings categories with Categories you wish the bot to know about. (Be aware that if you add any private Categories, it should know about those and anything the bot says in public, anywhere might leak to less privileged users so just be a bit careful on what you add).
  • only use the bot in normal mode (but the bot then won’t see any posts)
  • mitigate with moderation
In addition, note anything it can “see” gets shared with Open AI.
You can see that this setup is a compromise. In order to make the bot useful it needs to be knowledgeable about the content on your site. Currently it is not possible for the bot to selectively read members only content and share that only with members which some admins might find limiting but there is no way to easily solve the that whilst the bot is able to talk in public. Contact me if you have special needs and would like to sponsor some work in this space. Bot permissioning with semantic search is a non-trivial problem. The system is currently optimised for speed. NB Private Messages are never read by the bot.
FYI’s
  • May not work on mulit-site installs (not explicitly tested), but PR welcome to improve support :+1:
  • Open AI API response can be slow at times on more advanced models due to high demand. However Chatbot supports GPT 3.5 too which is fast and responsive and perfectly capable.
  • Is extensible and supporting other cloud bots is intended (hence the generic name for the plugin), but currently ‘only’ supports interaction with Open AI Large Language Models (LLM) such as GPT-4 natively. Please contact me if you wish to add additional bot types or want to support me to add more. PR welcome. Can already use proxy servers to access other services without code changes though!
  • Is extensible to support the searching of other content beyond just the current set provided.
Setup
Prerequisites
Aside from the normal changes to app.yml you need to be aware of the following:
To build with Chatbot or AI Topic Summary you need at least version 0.5.1 of the pgvector postgres extension.
Most people will have at least this version already. However, occasionally some installs have an older version installed. This will prevent you building with an error similar to: PG::UndefinedObject: ERROR: access method "hnsw" does not exist
First make sure your container is running:
./launcher restart app
then enter your container
./launcher enter app
then go into the database and update the version of pgvector:
:/var/www/discourse# su postgres -c 'psql discourse'
\dx
ALTER EXTENSION vector UPDATE;
\dx
exit
now leave the container with exit
You should now be able to rebuild.
Creating the Embeddings
If you wish Chatbot to know about the content on your site, turn this setting ON:
chatbot_embeddings_enabled
Only necessary if you want to use the RAG type bot and ensure it is aware of the content on your forum, not just the current Topic.
Initially, we need to create the embeddings for all in-scope posts, so the bot can find forum information. This now happens in the background once this setting is enabled and you do not need to do anything.
This seeding job can take a period of days for very big sites.
Embeddings Scope
This is determined by several settings:
  • chatbot_embeddings_strategy which can be either “benchmark_user” or “category”
  • chatbot_embeddings_benchmark_user_trust_level sets the relevant trust level for the former
  • chatbot_embeddings_categories if category strategy is set, gives the bot access to consider all posts in specified Category.
If you change these settings, over time, the population of Embeddings will morph.
To speed population up
Enter the container:
and run the following rake command:
rake chatbot:refresh_embeddings[1]
which at present will run twice due to unknown reason (sorry! feel free to PR) but the [1] ensures the second time it will only add missing embeddings (ie none immediately after first run) so is somewhat moot.
In the unlikely event you get rate limited by OpenAI (unlikely!) you can complete the embeddings by doing this:
rake chatbot:refresh_embeddings[1,1]
which will fill in the missing ones (so nothing lost from the error) but will continue more cautiously putting a 1 second delay between each call to Open AI.
Compared to bot interactions, embeddings are not expensive to create, but do watch your usage on your Open AI dashboard in any case.
NB Embeddings are only created for Posts and only those Posts for which a Trust Level One user would have access. This seemed like a reasonable compromise. It will not create embeddings for posts from Trust Level 2+ only accessible content.
Useful Data Explorer query to monitor embeddings population
@37Rb writes: “Here’s a SQL query I’m using with the Data Explorer plugin to monitor & verify embeddings… in case it helps anyone else.”
SELECT e.id, e.post_id AS post, p.topic_id AS topic, p.post_number,
       p.topic_id, e.created_at, e.updated_at, p.deleted_at AS post_deleted
FROM chatbot_post_embeddings e LEFT JOIN posts p ON e.post_id = p.id
Error when you are trying to get an embedding for too many characters.
You might get an error like this:
OpenAI HTTP Error (spotted in ruby-openai 6.3.1): {"error"=>{"message"=>"This model's maximum context length is 8192 tokens, however you requested 8528 tokens (8528 in your prompt; 0 for the completion). Please reduce your prompt; or completion length.", "type"=>"invalid_request_error", "param"=>nil, "code"=>nil}}
This is how you resolve it …
As per your error message, the embedding model has a limit of:
8192 tokens
You need to drop the current value of this setting:
chatbot_open_ai_embeddings_char_limit:
by about 4 x the diff and see if it works (a token is roughly 4 characters).
So, in this example, 4 x (8528 - 8192) = 1344
So drop chatbot_open_ai_embeddings_char_limit current value by 1500 to be safe. However, the default value was set according to a lot of testing for English Posts, but for other languages it may need lowering.
This will then cut off more text and request tokens and hopefully the embedding will go through. If not you will need to confirm the difference and reduce it further accordingly. Eventually it will be low enough so you don’t need to look at it again.
How To Switch Embeddings model
You don’t need to do anything but change the setting: the background job will take care of things, if gradually.
If you really want to speed the process up, do:
  • Change the setting chatbot_open_ai_embeddings_model to your new preferred model
  • It’s best to first delete all your current embeddings:
    • go into the container ./launcher enter app
    • enter the rails console rails c
    • run ::DiscourseChatbot::PostEmbedding.delete_all
    • exit (to return to root within container)
  • run rake chatbot:refresh_embeddings[1]
  • if for any Open AI side reason that fails part way through, run it again until you get to 100%
  • the new model is known to be more accurate, so you might have to drop chatbot_forum_search_function_similarity_threshold or you might get no results :). I dropped my default value from 0.8 to 0.6, but your mileage may vary.
Bot Type
Take a moment to read through the entire set of Plugin settings. The chatbot bot type setting is key, and there is one for each chatbot “Trust Level”:
RAG mode is superior but will make more calls to the API, potentially increasing cost. That said, the reduction in its propensity to ultimately output ‘hallucinations’ may facilitate you being able to drop down from GPT-4 to GPT-3.5 and you may end up spending less despite the significant increase in usefulness and reliability of the output. GPT 3.5 is also a better fit for the Agent type based on response times. A potential win-win! Experiment!
For Chatbot to work in Chat you must have Chat enabled.
How to get the bot to respond
Basic rules
  • If permissioned in plugin settings, the bot will Reply to every Post or Message if invoked in a Topic or Chat Channel with only a single User until more people join.
  • the bot will always be invoked if you @ mention it
Special per Category auto-responder
  • Per Category, you can get Chatbot to Reply to every new Topic and you can give it special instructions on what to do, governed by a Category specific prompt that you set up in the Category settings.
Should start something like:
“Welcome me by saying hello and introduce yourself. Share with me 5 posts on the forum by using local forum search relevant to my first post, include links”
ie you need to write it in first person as if user is asking for help. It is not a system prompt. It is not describing how the bot should behave (that’s for the system prompt which is still sent). It is a user asking for specific help (albeit hidden) Basically you write it as if a user post without having to mention the bot.
Bot’s speed of response
This is governed mostly by a setting: ‎chatbot_reply_job_time_delay‎ over which you have discretion.
The intention of having this setting is to:
  • protect you from reaching rate limits of Open AI
  • protect your site from users that would like to spam the bot and cost you money.
  • allow Discourse enough time to upload hotlinked images so the bot can see them.
It is now default ‘2’ seconds and can now be reduced to zero :racing_car: , but be aware of the above risks. Bot vsion (if you are using it) is particularly sensitive to this setting. If you find the bot is not seeing your images, try increasing this value.
Setting this zero and the bot, even in ‘agent’ mode, becomes a lot more ‘snappy’.
Obviously this can be a bit artificial and no real person would actually type that fast … but set it to your taste and wallet size.
NB I cannot directly control the speed of response of Open AI’s API - and the general rule used to be the more sophisticated the model you set the slower this response will usually be. What is more generally the case now is the ‘mini’ models tend to be quicker.
AI powered User Fields collection (experimental)
If a User has some Optional User Fields that are currently blank, enabling this setting, will cause the bot to start asking the user for the information. It will progress through the outstanding User Fields until they are completed and then revert to normal behaviour.
(sorry for slowness of response - this was recorded in dev)
NB This feature only supports:
  • Text
  • Dropdowns
  • Confirmations
Multi-select is not yet supported.
The fields must be optional
The order of the User Fields determines priority.
Ollama & llama3 support
Ollama support for (the completely AWESOME!) llama3 is now shipping:
This is for when the bot is run locally in dev or in the cloud with ollama server … and in Basic mode:
  • make sure model is llama3:
  • custom URL needs to be set http://localhost:11434:
If you have a big enough server, you could be serving ollama in the cloud there.
DeepSeek Hype :sweat_smile:
Get in on the act with Chatbot :rocket:
You can use the bot in at least Basic mode at least to access V3 and R1
I’ve used:
(no affiliate)
which hosts their models.
Set up like so:
Be sure to set Basic bot mode and substitute your key.
But you may be able to use DeepSeek AI directly if you can access their website to sign up :sweat_smile:
Base URL would be “https://api.deepseek.com”.
OpenAI
You must get a token from https://platform.openai.com/ in order to use the current bot. A default language model is set (one of the most sophisticated), but you can try a cheaper alternative, the list is here
There is an automated part of the setup: upon addition to a Discourse, the plugin currently sets up a AI bot user with the following attributes
  • Name: ‘Chatbot’
  • User Id: -4
  • Bio: “Hi, I’m not a real person. I’m a bot that can discuss things with you. Don’t take me too seriously. Sometimes, I’m even right about stuff!”
  • Group Name: “ai_bot_group”
  • Group Full Name: “AI Bots”
You can edit the name, avatar and bio (see locale string in admin → customize → text) as you wish but make it easy to mention.
It’s not free, so there’s a quota system, and you have to set this up
Initially no-one will have access to the bot, not even staff.
Calling the Open AI API is not free after an initial free allocation has expired! So, I’ve implemented a quota system to keep this under control, keep costs down and prevent abuse. The cost is not crazy with these small interactions, but it may add up if it gets popular. You can read more about OpenAI pricing on their pricing page.
In order to interact with the bot you must belong to a group that has been added to one of the three levels of trusted sets of groups, low, medium & high trust group sets. You can modify each of the number of allowed interactions per week per trusted group sets in the corresponding settings.
You must populate the groups too. That configuration is entirely up to you. They start out blank so initially no-one will have access to the bot:
In this example I’ve made staff have high trust access, whilst trust_level_0 have low trust. They get the corresponding quotas in three additional settings.
Note the user gets the quota based on the highest trusted group they are a member of.
“Prompt Engineering”
There are several locale text “settings” that influence what the bot receives and how the bot responds.
The most important one you should consider changing is the bot’s system prompt. This is sent every time you speak to the bot.
For the basic bot, you can try a system prompt like:
’You are an extreme Formula One fan, you love everything to do with motorsport and its high octane levels of excitement’ instead of the default.
(For the rag bot you must keep everything after “You are a helpful assistant.” or you may break the agent behaviour. Reset it if you run into problems. Again experiment!)
Try one that is most appropriate for the subject matter of your forum. Be creative!
Note that there are now two system prompts for each bot type. One .open is used when talking to the bot in “public”. The other .private is applied when talking to the bot in Personal Messages or Direct Message chat. This is so that you can customize private behaviour for e.g. a support bot.
Changing these locale strings can make the bot behave very differently but cannot be amended on the fly. I would recommend changing only the system prompt as the others play an important role in agent behaviour or providing information on who said what to the bot.
NB In Topics, the first Post and Topic Title are sent in addition to the window of Posts (determined by the lookback setting) to give the bot more context.
You can edit these strings in Admin → Customize → Text under chatbot.prompt., the most important of which are the system prompts which are in: chatbot.prompt.system.
Supports both Posts & Chat Messages!
The bot supports Chat Messages and Topic Posts, including Private Messages (if configured).
You can prompt the bot to respond by replying to it, or @ mentioning it. You can set how far the bot looks behind to get context for a response. The bigger the value the more costly will be each call.
There’s a floating quick chat button that connects you immediately to the bot. Its styling is a little experimental (modifying some z-index values of your base forum on mobile) and it may clash on some pages. This can be disabled in settings. You can choose whether to load the bot into a 1 to 1 chat or a Personal Message.
Now you can choose your preferred icon (default :robot: ) or if setting left blank, will pick up the bot user’s avatar! :sunglasses:
avatar:
OR icon:
And remember, you can also customise the text that appears when it is expanded:
… using Admin → Customize → Text
(though you may need to customise the CSS a little to accommodate colours and sizing you want).
Some debugging help
  • make sure setting chatbot include inner thoughts in private messages is ON
  • make sure setting chatbot enable verbose rails logging is ON
  • ssh into your server
  • cd /var/discourse/shared/standalone/log/rails
  • in parallel ask the bot something in the PM
  • go back to console immediately
  • look for these kind of messages:
    • general chat = tail -n 2000 production.log | grep {\"model\":\"
    • vision calls = tail -n 2000 production.log | grep {\"type\":\"image_url\"
  • check “inner thoughts” in the PM
Extending Chatbot’s toolset with plugins
Chatbot plugin has the ability to add other functions in separate plugins, so you don’t have to maintain a fork of the Chatbot repo.
Example function plugin here:
https://github.com/merefield/discourse-chatbot-function-extension-example
but of course you could add this to any plugin …
This feature was added in this PR
If you need help with extending Chatbot, you can hire me to help you.
Uninstalling the plugin - Important!
Due to recent efforts to simplify the plugin, the only steps necessary to uninstall the plugin are now to remove the clone statement.
Thanks for your interest in the plugin!
Disclaimer: I’m not responsible for what the bot responds with. Consider the plugin to be at Beta stage and things could go wrong. It will improve with feedback. But not necessarily the bots response :rofl: Please understand the pro’s and con’s of a LLM and what they are and aren’t capable of and their limitations. They are very good at creating convincing text but can often be factually wrong.
Important Privacy Note: whatever you write on your forum may get forwarded to Open AI as part of the bots scan of the last few posts once it is prompted to reply (obviously this is restricted to the current Topic or Chat Channel). Whilst it almost certainly won’t be incorporated into their pre-trained models, they will use the data in their analytics and logging. Be sure to add this fact into your forum’s TOS & privacy statements. Related links: https://openai.com/policies/terms-of-use, https://openai.com/policies/privacy-policy, https://platform.openai.com/docs/data-usage-policies
Copyright: Open AI made a statement about Copyright here: https://help.openai.com/en/articles/5008634-will-openai-claim-copyright-over-what-outputs-i-generate-with-the-api
TODO/Roadmap Items
  • Add front and back-end tests :construction:
  • Add “bot typing” indicator and “response streaming” (@Aizada_M, @MarcP) :construction:
  • forgot to mention the bot? Get bot to respond to edits that add its @ mention (@frold )
  • Add a badge? You did mention @botname (@frold )
  • Add setting to include Category and Pinned Posts prompt? (@Ed_S)
  • Ditto Bios to each message history prompt? (@Ed_S , @codergautam). Will this even work. Let’s get evidence.
  • Update Discourse Frotz with this better codebase?
  • Move to use pgvector in favour of pgembedding for vector search now that former supports fast HNSW lookup. :white_check_mark:
  • Add semantic search so that the bot can read your forum Posts and become an “expert” :wink: :white_check_mark:
  • Add agent behaviour to reduce hallucinations and leverage reliable, factual information. :white_check_mark:
  • Add extra logic to convert suspected usernames into @ mentions (@frold ) :white_check_mark:
  • Add GPT-4 support (when Open AI deems me worthy enough of access! :sweat_smile: ) :white_check_mark:
  • Add custom model name support. :white_check_mark:
  • Add option to strip out quotes from Posts before passing text to API. :white_check_mark:
  • Improve error transparency & handling for when Open AI returns an error state :white_check_mark:
  • Add retry capability for timed out API requests :white_check_mark:
  • Add support for ChatGPT :white_check_mark:
  • Lint the plugin to Discourse core standards :white_check_mark:
  • Add CI workflows :white_check_mark:
  • Add settings to influence the nature of the bots response (e.g. how wacky it is). :white_check_mark:
  • include Topic Title & first Posts to prompt :white_check_mark:
  • Add setting to switch from raw Post/Message data to cooked to potentially leverage web training data better (suggestion by @MarcP). NB May cost more and limit what is returned as input tokens are counted and cooked is much bigger. think we’ve abandoned this idea
Credits:
*It still uses OpenAI’s chat GPT engine, but can now leverage local functions and data from API calls to limit hallucinations.
「いいね!」 104
Answer feature
Webhooks on chat messages?
How to check what prevents rake migrate?
Site down after upgrade via SSH - how to fix?
2023: The Year in Review
Character count when writing description
Advice on a support bot for a technical support forum (Discourse AI vs Discourse Chatbot)
Is there an option to use Discourse Chat as a customer service type of chat?
Configure AI Chatbot for Trust Level 0 Access
Creating bot on discourse
AI Helper Plugin
Copy custom file in discourse container while build
Voice to text integration
Allow specifiy user different from guardian.user in chat services such as Chat::CreateMessage
How to add a ChatGPT trained AI to discourse?
Cannot get the js in my component to compile SyntaxError: Private field must be used in an enclosing class
Allow ChatBot to read PDFs so it can join in a group discussion
How are we all feeling about ChatGPT and other LLMs and how they'll impact forums?
How to create a custom ChatGPT based bot?
Discourse and Coveo
Link for new DM / personal chat message with pre-filled information
UX IPhone issues
How to respond to automatic topics with AI
Comparison between discourse-ai AI Bot and merefield/discourse-chatbot
Allow multiple ‘new topic’ drafts
I have error when upgrade the latest discourse
Two different answers from gpt4o - one right, one wrong.. !?
Is the shortcut to start AI conversation a user setting or not?
Training a model on a site's posts?
Setting Form Templates with a tag
Recommendation: chatbot to support discussion in threads
Photography Mentor Bot
Grouped Site Settings under Headings in Plugins
Update Not Completed and Discourse not opening
Multisite vs multiple containers
Create posts with AI
Discourse AI Topic Summary :robot:
Hubot Adapter for Discourse
Verbose log
Making the case for a hard cap feature on user group AI usage for AI bots and AI Helper
LLMs and the impact on customer support
2024: The Year in Review
What User Information is Exposed to LLMs in Discourse AI
Auto responder using AI
What's the best way to store data with a plugin?
ChatGPT Assistant Integration
Discourse Chat Bridge (Telegram)
AI personas integration of the chat plugin: It would be great if site users could chat with AI personas
Use AI to request summary and others things from topic
Embed additional explainer text in Form Template
Upgrading from /admin/upgrade takes *very* long
We need prompt chains: Allow custom AI persona tools to access LangChain.js and/or longer execution time
Enabling AI Bot in Chat
When I start a conversation with the AI, it gives two answers to my question
Balancing Costs and Functionality in AI-Powered Forums
Weekly Summary of AI topics
Interact with discourse from Python?
Sidekiq not working
Locations Plugin :earth_africa:
Lessons from Colossal Caves
Issue after Rebuilding Discourse on Digital Ocean Droplet
GPT-4 with vision available
I have error when upgrade new version of discourse
Jina.ai を、ウェブ検索およびウェブクロールに使用できるサポート対象 API のリストに追加しました。1 つのキーで両方のサービスを利用できます。キーを削除しない限り、既存の API が使用されます。
主な理由は 2 つあります。
  • クロールのパフォーマンスが非常に良好に見える
  • 月額料金制ではなく、従量課金制を提供しているため、私にもあなたにも適している可能性があります。
設定へのリンク。
皆さん、こんにちは。
@merefield さんが作成したAIチャットボットは本当に素晴らしいです。私たちのコミュニティで素晴らしい仕事をしてくれています。しかし、デフォルトのDiscourse AIセットアップでAI投稿分類器ができるような、すべての投稿に返信する機能はありますか?
可能でしょうか?
よろしくお願いします! :slight_smile:
「いいね!」 1
Discourse Chatbotにご関心をお寄せいただきありがとうございます。
関連する可能性のある点が2つあります。
  • トピックにユーザーが1人しかいない場合、より多くの人が参加するまで、ボットはすべての投稿に返信します。
  • カテゴリごとに、ボットがすべての新しいトピックに返信するように設定でき、カテゴリ設定で設定したカテゴリ固有のプロンプトによって、何をするか特別な指示を与えることができます。
ボットは常に@メンションされると起動するため、この機能も利用できるかどうかはわかりません。
「いいね!」 1
@merefield 様、迅速なご返信ありがとうございます。
ご説明ありがとうございます。しかし、私たちのユースケースは異なります。カスタムプロンプトを使用して、割り当てられたカテゴリ内のさまざまなキーワードに基づいてAIチャットボットをトリガーしたいのです。
例えば、サポートカテゴリがあり、AIチャットボットがすべての新しいトピックに応答するようにしたいとします。次に、プライベートサポートカテゴリがあり、AIチャットボットがメンションされずに「すべての」投稿に応答するようにしたいとします。AIチャットボットはキーワードによってトリガーされる必要があります。
「すべての」投稿ですか?それともキーワードが付いた投稿のみですか?それらは異なる要件ですか?
定義済みの応答にチャットボットについて言及すれば、ボットがフォローアップするのではないでしょうか?それは2つの投稿になりますが、機能するかもしれません。
定義済みの応答が「@Chatbot(または名前を変更した場合)これをお願いします」であった場合、チャットボットがフォローアップします。もちろん、その応答はカスタマイズできます。
チャットボットはウィスパーにも応答できることに注意してください(設定した場合)。定義済みの応答がウィスパーであった場合、通常のユーザーにはチャットボットの応答のみが表示され、よりきれいに見えるかもしれません。
他の人にも役立つ十分に一般的なソリューションを考案できる限り、必要であればチャットボットの機能を拡張することにも前向きですが、既存のものを活用するのが良いと思いますか?
ここで最善の行動は、AIポスト分類子にウィスパー機能を追加することでしょうか?誰かにPRを依頼するか、#featureとして提起して優先されることを期待することができます。それは間違いなく一般的に役立つでしょうか
OpenAI API に追加された機能を利用して、コードの簡略化を行いました。問題が発生した場合はお知らせください。
これを 1.0.0 と呼ぶことにしました :champagne: :tada: :partying_face:
「いいね!」 4
チャットボットリポジトリのフォークを維持する必要がないように、別のプラグインで他の関数を追加する機能を追加しました。
例の関数プラグインはこちら:
もちろん、これを任意のプラグインに追加できます…
PR:
「いいね!」 4
@Festinger これを解決しましたか?
投稿の埋め込み:問題が発生しましたが、制限まで再試行します:nil に対する undefined method `destroy!’
前回のアップデートの後、上記のエラーが発生し始めました。特に画像に関してこのエラーが発生します。私のビジョンモードの設定は次のとおりです。直接。以前はこの種のエラーは発生していませんでした。
投稿(またはトピック)を作成した直後に削除したことを覚えていますか?
投稿を作成してから、埋め込みが作成される前に削除した場合にこのエラーが発生します。そのため、削除すると、Chatbot は存在しない埋め込みを削除しようとし、迷惑なログメッセージが生成されますが、害はありません :wink:
より良い方法があれば、自由に PR を提出してください。
「いいね!」 1
ユーザーから送信された問題で、このようなエラーが発生しました。私が削除したものではありません。
ユーザーはこれにどのように気づいたのでしょうか?これはログにのみ表示されるものですか?
ログで確認しました。1日ほど追跡していますが、特に長期間メンバーであるユーザーの投稿で問題が発生しています。新規メンバーが画像を添付してトピックを開いた場合は、通常問題なく、エラーも受信しません。古いユーザーが画像を添付してトピックを開くと、問題が発生します。
バックトレースを共有してもらえますか?
では、なぜユーザーはあなたに問題を送信したのですか? ユーザーは何を言いましたか? ユーザーは問題に気づくべきではありません。ログに表示されるだけですよね?
「古参メンバー」が最近作成したトピックや投稿を(削除方法を知っているので)削除しているということでしょうか?
何らかの自動化は行っていますか?
画像を含む投稿の作成中に破壊は発生しないため、どのようにしてそれが起こりうるのか分かりません。
更新:画像をサイトにアップロードしましたが、再現できませんでした。
「いいね!」 1
SerpAPI は問題なく、統計情報では Google へのリクエストが実行されたことが示されていますが、チャットボットは Google を使用できないと主張しています。この状況はしばらく続いていますが、当時は DAI も Google を使用したくなかったため、対応しませんでした。
エラーメッセージはありません。
「いいね!」 1
「ウェブを検索して…」と言うとどうなりますか?
内部プロンプトは汎用的であるため、Googleを想定していません…
この強力な機能の非常に優れたデモを以下に示します。
(ただし、これはバンドルされている代替の jina.ai を使用しています)
それを試しました。システムプロンプトには「ユーザーがGoogleで検索するように求めた場合、ユーザーは実際にはあなたがアクセスできるWeb検索機能を使用することを意味します」とありました。その部分を削除し、ユーザープロンプトでWeb検索という言葉を試しました。結局、GoogleのAPIを使用しているわけではないので。うまくいかず、同様の回答でした。「Web検索はできません…」
これは見つけたものですが、開きません。
  "id": "chatcmpl-A1wT9Dp1fCIVSzRsVPhr3NnNCcPjW",
  "object": "chat.completion",
  "created": 1725026447,
  "model": "gpt-4o-2024-05-13",
  "choices": [
      "index": 0,
      "message": {
        "role": "assistant",
        "content": null,
        "tool_calls": [
            "id": "call_MvzexRPsDj6EGuXhuiFcmtrd",
            "type": "function",
            "function": {
              "name": "web_search",
              "arguments": "{\"query\":\"International Dog Day date, reason, and history\"}"
        "refusal": null
      "logprobs": null,
      "finish_reason": "stop"
  "usage": {
    "prompt_tokens": 1203,
    "completion_tokens": 20,
    "total_tokens": 1223
  "system_fingerprint": "fp_157b3831f5"
「いいね!」 2
ターゲットはチャットボットを社内Q/Aボットとして使用することなので、それなしでも問題ありません。Jinaは(WordPress経由で)メインコンテンツサイトを使用する問題を解決してくれるかもしれません。
しかし、外部から検索した結果は期待どおりではありませんでした。
「いいね!」 1
再現できるか試してみます
「いいね!」 1
