hugh
(Hugh Lashbrooke)
October 28, 2025, 7:33am
1
New features in 3.6.0.beta2
Editing built-in theme colour palettes
Until recently, colour palettes that come packaged with themes have not been editable. Now, instead of duplicating those palettes to fill your admin, you can simply edit them directly. Modified colours can always be reverted to those that came with the theme if needed, allowing for more flexible colour palette management.
Live progress data for your AI translations
When using the AI translations feature that is built into Discourse, your translation progress is clearly displayed in your dashboard. You can see the number of posts translated and the completion percentage for each locale, as your translations are backfilled according to your settings. In addition to this, you can now see the estimated completion time in hours and minutes until all your posts are fully translated.
Stay on top of wiki updates
To help you stay apprised of wiki topics, they are now ābumpedā when an edit is made to the original topic. This helps to ensure that your community is aware of important updates to these topics, and you have can easily review them as edits are made. This is especially helpful for documentation topics, which are a common use case for the wiki feature.
Security Updates
This release includes fixes for these security issues reported by our community and HackerOne .
tgxworld
(Alan Tan)
3
Even more!
But wait, thereās more! We do our best to highlight new features and changes for you, but thereās always too many changes to detail. For a full list of new features, bug fixes, UX improvements, and more, be sure to review the Additional Features and Fixes listed below.
Plugin improvements
discourse-akismet
Bug Fixes
Remove discourse_dev dependency from plugin.rb (185 )
discourse-anon-usernames
New Features
Add anonymous username generator plugin (1 )
Bug Fixes
Reduce generation strictness (2 )
discourse-category-experts
Bug Fixes
Auto-tag improperly when category is changed (215 )
discourse-doc-categories
New Features
Bump topic on OP of doc categories topics (61 )
Bug Fixes
Ensure PMs are handled when moving index topics (62 )
discourse-no-bump
Bug Fixes
Remove bump on revision logic (80 )
discourse-preset-topic-composer
Bug Fixes
Update for core change to new topic btn (53 )
discourse-route-blocker
Bug Fixes
Raise Discourse::NotFound when route is blocked (9 )
discourse-theme-creator
Bug Fixes
Update html builder after the admin dir move (124 )
Index route import (122 )
All Features and Fixes
New Features
Add plugin hook for extra username validations (35522 )
Promote discourse_reactions_allow_any_emoji out of experimental (35589 )
Add full-text search for chat messages (34704 )
Add Czech default quotation marks (34797 )
Add estimated completion time to AI translation backfill (35474 )
Append limited search results with semantic search (35446 )
Experimental Photoswipe Lightbox (35109 )
Add settings for connect/revoke capability in Login with Amazon (35387 )
Enforce prosemirror-gapcursor on additional block nodes (35415 )
Always show All, Topics, and Replies subtabs for unified new (35292 )
Support for newer Gemini Embedding model (35390 )
Hosted LLM credit system (35162 )
Auto enable AI search (full page) when no regular results (35336 )
Disable link notification user preference (35352 )
Link to āAll settingsā for real in the admin sidebar (35263 )
Update India Diwali 2025 Holiday (35354 )
Switch to markdown when unsupported tokens are found on rich editor (35044 )
Allow adding anchor tag to 404 page title (35318 )
Add locale as a filter on topic /filter (35299 )
Also process manually updated translations (35276 )
Add the option to flag, delete and silence in LLM Triage (35285 )
Introduce āgoogle_site_verification_tokenā site setting (35229 )
Add oneboxes and lightboxes to localized posts (34900 )
Add plugin_modifier to include AI summary in topic view serializer (35110 )
Split setting for allowing mods to manage categories and groups (35174 )
Allow editing theme-owned palettes (34722 )
Bump wiki topics when OP is edited (35137 )
Add site setting to prevent mods from changing trust levels (35160 )
Bug Fixes
Filter out hidden/whisper/deleted posts from keyword filter. (35648 )
Canāt update close based on last post timer to close timer (35541 )
Ensures edited post in fast edit is not mutated (35622 )
Improves position of post toolbar on iOS (35574 )
Improves modal on iOS when input is focused (35619 )
Restore support for normalized plugin routes under admin/ (35598 )
Topic filter should respect whisper rights (35555 )
Add request tracking headers to Message Bus responses (35537 )
Clear partial flag when streaming tool calls finish (35605 )
Add distinct emoji context for discourse-reactions picker (35614 )
Rich editor input rule wrapping missing options (35548 )
Prevent duplicate PMs when multiple LLM triage rules flag same post (35596 )
Twitter login problem check not reporting accurately (35593 )
Moving first post sequentially doesnāt bump the destination topic (35559 )
Fully hides section if user canāt send dms (35595 )
Handle media optimization worker load timeouts and errors (34943 )
Skip trust level changes when group grant_trust_level is 0 (35572 )
Lightbox img size within details element (35570 )
Add extra tag_id, topic_id index to topic_tags (35565 )
Always save post drafts no matter content length (35540 )
Duplicate results in AI quick search (35554 )
Update optionalRequire paths after admin directory move (35551 )
Ensure AI default LLM model fallback is present (35549 )
Revert scroll on focus solution (35544 )
Rich editor link toolbar Max call stack exceeded (35530 )
Fix scroll more chat spec (35543 )
Make system user fallback optional for category email (35536 )
Handle cancel action in topic reply choice dialog (35534 )
[rich editor] convert newlines to hard breaks when parsed from HTML (35518 )
Add Azure communication service endpoint to SMTP authentication override (33226 )
Persist reviewable notes when toggle tabs (35495 )
Ensure chat service has loaded channel before rendering channel (35433 )
Adds timeout to prevent-scroll-on-focus modifier (35503 )
Prevents body scroll in input focus (35497 )
Prosemirror input rule code mark check (35416 )
Improve topic tracking state sync (35478 )
Disable AI Problem Checks (35475 )
Job exception: Holidays::InvalidRegion (35473 )
Allows check_policy to find mailer class (35464 )
Add data attrs to quoted images (35455 )
Phantom notification when being added to an event in a message⦠(35459 )
Unsuspend a moderator (35452 )
DeleteReplies should use the guardian instead of checking for staff (35443 )
Remove category definition topics in hot (35449 )
Improves input method editor in chat (35448 )
Donāt create AI Problem check trackers without a target LLM. (35447 )
Add lightbox class to chat quoted images (35442 )
Show flair visibility warning after groups configuration page reload (35445 )
Wide images on FAQ page overflowing on mobile (35398 )
Event location field in .ics / google calendar exports (35355 )
Eager āload moreā in users directory (35439 )
Fix a loading loop when a topic is removed (35409 )
Donāt try to track search suggestion clicks (35431 )
Ensures user can DM to show start new dm button (35440 )
Broken reviewable link to relevant automation (35434 )
Only load the api-docs rake task definition when required gems are available (35432 )
Subcategories_with_featured_topics rendering of topics (35418 )
Clear stored mark on rich editor mark input rule conversion (35360 )
Moderator notifications when new post auto-silences a user (35403 )
Exclude fields hidden on sign-up from invite signup form (35405 )
Twitter health check broken on Faraday update (35407 )
Handle nil @post in CookedProcessorMixin for chat messages (35386 )
Update composer placeholder when toggled (35383 )
Moving a topicās first post to an existing topic resets bumped_at (35373 )
Missing topic properties in category-featured-topics (35380 )
Watching_first_post topic filter & query (35353 )
Treat the topic status enabled param as a truthy value. (35366 )
Remove unused service (35364 )
Resolve race condition where draft is not loaded for a chat channel (35351 )
Use default locale for temporarily_closed_due_to_flags (34718 )
Safari color palette pasting (35348 )
Use system user for email-in when staged users disabled (34655 )
URL encode usernames in grant admin redirect (34664 )
Correct assignment of admin user groups property (35315 )
Reduce false positives in AI LLM status problem check (35304 )
Offline mode should not send typing indicator (35279 )
Invites to private topic when using discourse connect (35303 )
Allow AI tagging automation to tag posts by bots (35310 )
Prevent left-over markup for old hidden post notices (35311 )
Do not return translated name when editing category (35297 )
Ensure scheduled problem checks honor perform_every configuration (35291 )
Add backup codes immediately after adding 2FA (35287 )
PG::UniqueViolation for PostTimings in posts:reorder_posts rake task when PostTiming records have no corresponding Post (35212 )
Let user recover their own deleted topics (35214 )
Possible crash during category creation (35277 )
Add minimal load-more-sentinel height (35262 )
Confirmation prompt breaks when using pipe (35261 )
Remove btn-default from the DActionButton component (35196 )
Another category modal partial loading edge case (35204 )
Opening category dropdown should not reset translated name (35232 )
Simultaneous rich editor data img uploads (35098 )
Remove error section when viewing details for received emails (35228 )
Wildcard watched word and regexps (35217 )
Skip triage on edits when unhandled flags exist (35218 )
Spec ambiguity when selecting category dropdowns (35215 )
Navigating via topic filters should not untranslate a category name (35211 )
Crash in Admin::PluginsController when plugin has nil commit URL path (35186 )
Ensure a reviewable is created when directly taking action on user (35198 )
Align text display behaviour for user-menu-billing with other buttons (35200 )
Double declarative button class names (35177 )
Pass ancestor data to category badge helper (35169 )
Disable replies button until replies are loaded (35136 )
Notification reminder is deleted with bookmark (35141 )
Respect img size when quoting multiple elements (35144 )
Streamline topic bump functionality and notification settings behaviour (34945 )
Removes debugging line (35157 )
Donāt link seeded LLMs on the features page (35151 )
Use personaās allowed groups for AI helperās custom prompts access (35150 )
Allow saving category when color attributes are 3-digits hex (35119 )
Donāt update last_seen_at when impersonating a user (34872 )
Allow mediaconvert client without endpoint (35135 )
Show more button now loads additional root-level subcategories (35101 )
Allow aws mediaconvert to use iam profile (35091 )
Show AI gists in mobile messages (35124 )
Discourse_id_challenge response when using subfolder (35123 )
Hides redundant chat icon on mobile chat routes (35015 )
Run scheduled problem checks even when no tracker exists yet (35102 )
Notification reminder is deleted with bookmark (35069 )
Post voting comments editing UX (35108 )
Clicking on subject in admin email logs broken (35030 )
Translate string in search 404 page (35090 )
Topic pagination overflow with deleted posts (35081 )
Force update size on full calendar (35075 )
Topic footer dropdown/anonymousOnly null handling (35072 )
Uses css selector to ensure we use waiters (35063 )
Correctly replace emojis in bookmark reminder (35061 )
Avoid returning duplicate voters from /polls/voters.json endpoint (34433 )
UX Changes
When closing lightbox avoid jitter if thumb is cropped (35646 )
Allow inline-footnote content to shrink-to-fit (35633 )
Add modifier to customize invite template (35458 )
Show magnifying glass on left for picker (35621 )
Adds padding top to picker on mobile (35618 )
Simplify PM participant removal (34022 )
Close lightbox on backdrop tap on mobile (35571 )
Set border-radius to 0 for buttons in DMenu (35602 )
Use custom icon for searching in chat (35600 )
Add missing btn class (35562 )
Link to post when clicking on subject in received email logs (35567 )
Make sentiment analysis reports accessible to moderators (35577 )
Move quote and code dark mode styles to element selectors for emails (35576 )
Remove z-index for header notification badge (35575 )
Add missing translations for lightbox (35568 )
Uses flat btn for search filter bar in chat (35566 )
Slightly reduce padding above chat composer (35546 )
Improve messaging when auto closed based on last post topic timer (35538 )
Add class to draft error ignore button (35531 )
Update remove password button to use btn-danger class (35514 )
Show AI gist toggle on /filter route, fix appearance of gists (35521 )
Move AI bot PM to navigation menu (35189 )
Mobile lightbox padding and styling improvements (35494 )
Fix overflow on admin search input (35481 )
Remove total and update backfill message for AI translations (35479 )
Sort AI translations by completion, show decimal between 99 and 100% (35461 )
Additional AI translation chart adjustments (35454 )
Add btn class to wizard buttons (35450 )
Show only posts needing translation for default locale in AI translation chart (35397 )
User card metadata links should use link color (35427 )
Remove redundant unread/new labels for empty topic list (35350 )
Add exact URL matching for sidebar section links (34677 )
Replace dropdown with a dedicated index page for email templates (35284 )
Simplify Composer Discard confirmation dialog: removes Safe draft button (35298 )
Add missing declarative classes to btn (35312 )
Show SCSS files in theme admin āextra filesā section (35300 )
Better separate login and authentication settings (33711 )
User inbox styling fix (35258 )
Remove double actions buttons in bookmark modal on mobile (35183 )
Add missing button class to secret toggle (35254 )
Make translations easier to set up by showing requisite site setting (35078 )
Remove subtitle from 404 page (35185 )
Update the copy in settings for the mobile logo (35184 )
Make lightbox hover caption unselectable (35148 )
Rework button classes (34882 )
Always apply discoveries padding regardless of viewport (35154 )
Update topic-footer buttons automatically when viewport changes (35074 )
Show remove password button without suspense (34635 )
Update Discourse ID setting description (35094 )
Add missing post notice styling (35093 )
Add āworks withā explanation for Discourse ID logins (35088 )
Improve kbd shortcut appearance on macOS (35099 )
Hide time in month view on mobile (35107 )
Remove love background on hover (35089 )
Fix hover effect on heart icon in double-like button (35086 )
Post notices part 2 (35049 )
Update strings for filter (35062 )
Security Changes
Error responses missing Cache-Control header
Performance
Optimize AI translation stats query and remove caching (35597 )
Use persona cache for translation and summarization lookups (35560 )
Fix N+1 queries due to user custom fields when loading chat DMs (35516 )
N+1 when checking for category moderators when loading channels (35466 )
Use correctly-encoded JS files for webpack chunks on S3 (35444 )
Cache requests when navigating user directory (35371 )
Re-use topic-footer-button elements when rerendering (35167 )
Accessibility
Make ariaLabelledBy conditional for topic lists (35334 )
Remove aria-controls from expandable replies in topic (35333 )
Remove aria-controls from search input, fix result count (35332 )
Add aria-label to search results region (35327 )
Add role to video thumbnail button (35326 )
Fix ariaHidden for user links (35329 )
Add aria-label to topic footer button region (35328 )
Add href to post voting comment username (35325 )
Add aria-label, title, to interface color selector (35324 )
