(устарело) Руководство по настройке среды разработки Discourse — GitHub Codespace
Developing Using GitHub Codespaces
GitHub Codespace is a great development option. It’s great because it’s hosted in the cloud, I can easily ensure that everyone developing here has the same environment, no dealing with local docker installations, easy access to making my local dev instance available publicly, and also just using new technology is fun.
I’m currently re-learning development and decided to pickup GitHub Codespaces in addition to learning some Discourse development, so I made this guide for anyone else looking to develop on Discourse in GitHub Codespace rather than setting up a local environment.
I decided to write this guide after going through a slew of issues getting this working with GitHub Codespace myself:
This guide will assume nothing, so we don’t miss a single step to getting you up and running. I suspect some of this process can be improved at the core repo level for the GitHub Codespace configuration, or at least due to my lack of understanding. Don’t hesitate to point these out.
Fork the Discourse repository
  1. Navigate to https://github.com/discourse/discourse
  2. Click the Fork button in the top-right of the page and click the green 'Create fork` button on the subsequent page.
  3. After a brief moment, you’ll be taken to your new fork of the discourse/discourse repository:
Setup Your GitHub Codespace
  1. Click the green <> Code button
  2. Switch to the Codespaces tab and click the green Create codoespace on main button.
  3. You’ll be taken to a new window where GitHub will start creating your codespace. This should take 1-3 minutes:
    chrome_LYoRTOWojo
  4. After a few minutes, you’ll be presented with your GitHub Codespace (which is just VS Code in your browser):
Setup Your Codespace Environment
There are some configurations to make to your codespace environment before you’re up and running.
  1. Create a new bash shell by click Ctrl + Shift + backtick on Windows/Linux, or Cmd + Shift + backtick on Mac. Your shell should have you starting int he /var/www/discourse directory.
  2. Navigate to the discourse directory:
cd workspace/discourse
  1. Install everything from the project Gemfile
bundle install --gemfile ./Gemfile
The command is quite long, but you’ll see something like this:
  1. Add a new config.hosts to the development.rb
    1. From the directory you’re currently in (/var/www/discourse/workspace/discourse) open the file config/environments/development.rb.
    2. Find the line config.hosts << /\A(([a-z0-9-]+)\.)*localhost(\:\d+)?\Z/ and create a new line below it with the following, then save the file:
config.hosts << /^(.*)\.app\.github\.dev$/
The tail-end of your file should look like this (notice line 102 in my screenshot):
  1. Back down in your terminal, run bundle exec rake admin:create to create your first admin account. The command will ask you to choose an email and a password (password must be at least 10 characters)
Start Your Engines Server
It will take 1-2 minutes to build and start the server. At this point, you should now have everything you need to run and access your application.
  1. In the same terminal you’re in, run the following command to start your server:
bin/ember-cli -u
  1. Switch from the Terminal tab to the PORTS tab in your console:
  2. Click on the Forwarded Address for port 4200 using Ctrl + click for Windows/Linux, or Cmd + click for Mac and you’ll be greeted with your development environment!
Hopefully this helps someone else in getting started with GitHub Codespaces! :tada:
11 лайков
Great, it’s a good option when traveling light
2 лайка
Or in my case, I really don’t want to develop on windows and docker, but also don’t want to switch to a Unix environment at home (though I use one at work).
I just like the idea that everything is right there in my GitHub repo.
3 лайка
I think this guide needs some updating. It doesn’t work when running step 5, since the databases aren’t made yet.
1 лайк
I managed to get it working by running
bash <(wget -qO- https://raw.githubusercontent.com/discourse/install-rails/main/linux)
Then
bin/rails db:create
bin/rails db:migrate
RAILS_ENV=test bin/rails db:create db:migrate
Followed by
bin/ember-cli -u
Then in a split terminal
bin/rails admin:create
1 лайк
@jordan-violet I assume this is an unsupported-install? I can’t find my app.yml, so I can’t install plugins.
To install a plugin you can follow the steps in Install plugins in your non-Docker development environment
3 лайка
You symlink from your plugins folder to the folder of your plugin code
2 лайка
@jordan-violet thanks for creating this guide with all the workarounds that were previously necessary :pray:
I’m glad to say that we’ve now merged a bunch of changes to our devcontainer/codespaces configuration, which should make it much easier to get things going without needing to fork or manually configure anything.
Here’s the official guide:
I’m gonna add a note to the top of the OP here, directing people to the official guides :writing_hand:
6 лайков
