Matomo Analytics
:discourse2: Summary Matomo Analytics is a script to enable Matomo analytics on Discourse.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-matomo-analytics
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Matomo is an open source analytics platform. Users can choose between self-hosting or paying for professional hosting in the cloud.
:mega: Matomo was formerly named Piwik. See Piwik is now Matomo - Announcement - Analytics Platform - Matomo for details about the name change.
To enable Matomo analytics on your Discourse forum, all you have to do is install the official theme component.
Valid for Matomo API v1.5 and newer
  1. Follow the theme installation guide to import from the following URL:
    https://github.com/discourse/discourse-matomo-analytics.git
    And you will see
  2. Enter the Host URL and Website ID
  3. Add the theme component “Matomo Analytics” to your active theme(s).
That’s it!
Settings
Name Description
host url Host URL without http:// or https://
website id
exclude groups Comma separated list of groups to exclude from tracking such as admins, staff
user id tracking An indentifying field name on the current user object such as id, username or external_id.
subdomain tracking Track visitors across main domain & subdomains, assuming discourse is on a subdomain.
do not track So tracking requests will not be sent if visitors do not wish to be tracked.
disable cookies Disables all first party cookies. Existing Matomo cookies for this website will be deleted on the next pageview.
Credits
Thanks to @mattab & @brahn @tagtomat and @simon
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
38 Me gusta
Thanks for this howto, works fine for me. :thumbsup:
In order to comply with the European laws, users must have the possibility to reject piwik’s cookie. Piwik offers a really simple solution for this, by including an IFrame.
Unfortunately, Discourse doesn’t allow iframe tags in posts… :grimacing:
Does anyone see a way to include this piwik iframe in Discourse TOS ?
Thanks.
1 me gusta
:wave: I just created a new “Matomo Analytics” theme component, and updated the instructions on how to set it up.
Could you give it a try? Please also remember to remove the original custom scripts.
8 Me gusta
Looks good on first sight. No error in javascript console. Requests to piwik.php being in the webserver log again.
Statistics in Matomo are available as well.
5 Me gusta
Is this iframe thing still a concern?
1 me gusta
Hey @xrav3nz :clap: your component works great - thanks!
Yes it is. Opt-out should be possible, and Matomo provides this via including an iFrame: see Matomo documentation
3 Me gusta
This doesn’t appear to be working for me at the moment? I can add the component, and add the correct URL and siteid, but it doesn’t render anything:
I added the comments around the code to find it quicker in the page:
1 me gusta
We are on beta 6+git1 on our instance
Inline JavaScripts in themes and components are automatically extracted to an external “theme JavaScript” file.
Could you try checking the one immediately after your comments?
9954b74cfdb3c6f0230e7e9f4c6a3db0764c1373
7 Me gusta
This is at the main page on https://discuss.pixls.us:
Edit
Hold on, I’ve got a new hash on the file on recent refresh, it looks like the code is there. Thank you @xrav3nz!
Looks like it’s working now - not sure what I was doing wrong yesterday - user error.
5 Me gusta
So I have the JS loaded into the theme customizations, and the external “theme JavaScript file”* is linked in my test browser, just under where I inserted it like in the screenshot in a few posts earlier … BUT the requests aren’t coming through to the Matomo tracking web server.
(Tracking works fine for other non-Discourse sites, FWIW.)
Has anyone else seen that happen?
* e.g. https://discourse-cdn.example.com/standard11/theme-javascripts/{numeric_string}.js?__ws=my-discourse-forum.example.org
Thanks for the component!
I’m confused why the tracking code is sending a custom variable called Anonymous. Isn’t that custom for your particular Matomo setup? It doesn’t seem like it should be there for everyone.
_paq.push(['setCustomVariable', 1, 'Anonymous', !currentUser, 'visit']);
I added a few lines so that it would track visitors between discourse on a subdomain and a main site. Happy to send a pull request if you want it.
Debes añadir tu URL de Matomo a la lista de permitidos en la cabecera Content-Security-Policy. Busca la configuración de administración content_security_policy_script_src y agrega allí tu dominio (incluyendo https://).
6 Me gusta
Tengo problemas para que esto funcione en mi instalación. He instalado el componente y lo he añadido a mi tema, pero Matomo indica que no hay datos para el sitio. Supongo que tengo la configuración correcta:
Pero veo este error en la consola de mi navegador:
…y cuando veo el sitio en Matomo, obtengo esto:
¿Qué estoy pasando por alto?
Edición: Una investigación más detallada revela que el error en la consola de JavaScript solo aparece en Firefox, no en Chrome (con las últimas versiones de cada uno en un Mac). Ahora estoy viendo algunos resultados en Matomo, aunque Firefox está notablemente ausente; todos los visitantes, excepto uno, usan Chrome; la única excepción está usando Safari.
¿Alguna idea sobre esto? Este post:
sugiere que podría ser la configuración de “no rastrear” de Firefox, pero incluso cuando las desactivo para mi sitio, obtengo el mismo error en la consola web con Firefox. Y, en cualquier caso, Firefox no parece estar considerando esto como un rastreador:
Intenta eliminar la última / de “https://www.familybrown.org/analytics/” → “https://www.familybrown.org/analytics
1 me gusta
Gracias. Lamentablemente, sigo obteniendo el mismo error:
¿Podrías darme la URL de tu foro?
¿Es necesario completar estos dos campos? No los entiendo muy bien.
