WP Discourse performing a lot of requests to site.json
@RGJ is experiencing an issue with WP Discourse making a large number of requests to site.json. RGJ provided logs showing repeated GET requests to site.json from the WordPress server. joffreyjaffeux suggested the issue might be related to a specific call in the plugin-utilities.php file, which is used to fill the category selector, meta box, and discourse sidebar.
RJG investigated further and found that the issue is likely due to the $discourse_categories transient not being saved, despite other transients working correctly. RGJ discovered that the transient saves when the data is json_encode()ed, and suspects a WordPress issue, possibly caused by a security plugin interfering. The issue cannot be reproduced on another WordPress instance.
I’m working on an integration for a client and I had a tail on the Discourse logs while working on their Wordpress forum.
And this is what I saw coming by (sorry for the odd log format). The IP address is the IP address of the Wordpress server. It is running WP Discourse 2.5.5.
I’ve been looking through the code and I can’t figure out why this is happening.
2024-10-23T06:39:30+00:00|67.225.163.100|5857|0.023|200|GET /site.json HTTP/1.1
2024-10-23T06:39:30+00:00|67.225.163.100|5857|0.022|200|GET /site.json HTTP/1.1
2024-10-23T06:39:30+00:00|67.225.163.100|5857|0.020|200|GET /site.json HTTP/1.1
2024-10-23T06:39:31+00:00|67.225.163.100|5857|0.023|200|GET /site.json HTTP/1.1
2024-10-23T06:39:31+00:00|67.225.163.100|5857|0.024|200|GET /site.json HTTP/1.1
2024-10-23T06:39:31+00:00|67.225.163.100|5857|0.020|200|GET /site.json HTTP/1.1
2024-10-23T06:39:31+00:00|67.225.163.100|5857|0.019|200|GET /site.json HTTP/1.1
2024-10-23T06:39:31+00:00|67.225.163.100|5857|0.022|200|GET /site.json HTTP/1.1
2024-10-23T06:39:31+00:00|67.225.163.100|5857|0.021|200|GET /site.json HTTP/1.1
2024-10-23T06:39:32+00:00|67.225.163.100|5857|0.018|200|GET /site.json HTTP/1.1
2024-10-23T06:39:32+00:00|67.225.163.100|5857|0.021|200|GET /site.json HTTP/1.1
2024-10-23T06:39:33+00:00|67.225.163.100|5857|0.021|200|GET /site.json HTTP/1.1
2024-10-23T06:39:33+00:00|67.225.163.100|5857|0.024|200|GET /site.json HTTP/1.1
2024-10-23T06:39:33+00:00|67.225.163.100|5857|0.020|200|GET /site.json HTTP/1.1
2024-10-23T06:39:33+00:00|67.225.163.100|5857|0.022|200|GET /site.json HTTP/1.1
2024-10-23T06:39:34+00:00|67.225.163.100|5857|0.022|200|GET /site.json HTTP/1.1
2024-10-23T06:39:34+00:00|67.225.163.100|5857|0.023|200|GET /site.json HTTP/1.1
2024-10-23T06:39:34+00:00|67.225.163.100|5857|0.021|200|GET /site.json HTTP/1.1
2024-10-23T06:39:34+00:00|67.225.163.100|662|0.012|429|GET /site.json HTTP/1.1
2024-10-23T06:39:34+00:00|67.225.163.100|662|0.014|429|GET /site.json HTTP/1.1
2024-10-23T06:39:34+00:00|67.225.163.100|662|0.011|429|GET /site.json HTTP/1.1
I imagine it’s coming from this call: wp-discourse/lib/plugin-utilities.php at main · discourse/wp-discourse · GitHub
Which apparently is used in 3 cases:
  • fill the category selector in some form
  • meta box
  • discourse-sidebar
Yeah.
The weird thing is that it is supposed to be cached, and I have no reason to believe that it is not.
$categories = get_transient( 'wpdc_discourse_categories' );
if ( ! empty( $options['publish-category-update'] ) || ! $categories ) {
  $body = $this->discourse_request( '/site.json' );
  if ( is_wp_error( $body ) ) {
    return $body;
  if ( $body->categories ) {
    // removed for brevity
    // Note that setting the cache to 0 will disable transient expiration.
    $category_cache_period = apply_filters( 'wpdc_category_cache_minutes', 10 );
    set_transient( 'wpdc_discourse_categories', $discourse_categories, intval( $category_cache_period ) * MINUTE_IN_SECONDS );
    return $discourse_categories;
  } else {
    return new \WP_Error( 'key_not_found', 'The categories key was not found in the response from Discourse.' );
EDIT When I list the transients I do have a key timeout_wpdc_discourse_categories with a value of a timestamp in 5 minutes, but I do not have a wpdc_discourse_categories :thinking:
EDIT 2 set_transient( 'wpdc_discourse_categories', $discourse_categories, intval( $category_cache_period ) * MINUTE_IN_SECONDS ); is returning false. $discourse_categories is correctly filled. Other transients are working.
Update: The transient is simply not saving. It is saving when I json_encode() it.
Also, I am unable to reproduce this on another Wordpress instance, so I’m moving this to support because I believe this is a Wordpress issue. I suspect there might be some kind of security plugin interfering.
