فشل تثبيت التطوير عند تشغيل bin/rails db:migrate
Basically, I am trying to do a dev install on my Pi, following this guide. I ran bin/rails db:create, which worked fine. Then when trying to run bin/rails db:migrate, it ends by saying something about oxipng binary file not working? It tells me to either put a proper binary file or use some command (I cannot remember it exactly, I’ll tell you why).
But, um, my VNC lagged out when doing this (I think the processing was too much? I did a bin/ember-cli -u even with this oxipng thing. Anyway, I then clicked on something and all I say was a grey screen. I closed the VNC session and tried to reconnect. Nothing happened for a long time. I disconnected and reconnected my Pi (yes, force shut down. Very bad.). As such, I don’t know that oxipng message much.
Tried again to run bin/rails db:migrate, and this was the error (same error as well when running RAILS_ENV=test bin/rails db:create db:migrate):
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrating ===========
-- execute("DELETE FROM web_hook_event_types WHERE (name, id) IN (('category_experts_approved', 1901), ('category_experts_unapproved', 1902))")
   -> 0.0011s
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrated (0.0029s) ==
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:16:in `expire_cache'
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:42:in `reload_types'
/home/natedhaliwal/discourse-f/app/models/flag.rb:37:in `reset_flag_settings!'
(eval):78:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `eval'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:58:in `block in open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:57:in `open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:36:in `block in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activesupport-7.1.4.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/transactions.rb:212:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:35:in `run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:26:in `block in run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/discourse-seed-fu.rb:29:in `seed'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:264:in `block (2 levels) in <main>'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:53:in `block in synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:49:in `synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:34:in `synchronize'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:234:in `block in <main>'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block (2 levels) in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:44:in `block in with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/rake_module.rb:59:in `with_application'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:41:in `with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:20:in `perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:156:in `invoke_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:73:in `block in invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:149:in `with_argv'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:69:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands.rb:18:in `<main>'
<internal:/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
bin/rails aborted!
ActiveRecord::RecordNotFound: Couldn't find Upload with 'id'=-6 (ActiveRecord::RecordNotFound)
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:119:in `resolve_original'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `each'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
Tasks: TOP => db:migrate
When running it with --trace, I get:
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails db:create db:migrate --trace
** Invoke db:create (first_time)
** Invoke db:force_skip_persist (first_time)
** Execute db:force_skip_persist
** Invoke db:load_config (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute db:load_config
** Execute db:create
Database 'discourse_test' already exists
Database 'discourse_test_multisite' already exists
** Invoke db:migrate (first_time)
** Invoke set_locale (first_time)
** Execute set_locale
** Invoke assets:precompile:theme_transpiler (first_time)
** Execute assets:precompile:theme_transpiler
** Execute db:migrate
bin/rails aborted!
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
Any thoughts on what I should do?
حسنًا، الإجابة على الأرجح هي هذا السطر:
هل قمت مؤخرًا بإزالة أيقونة؟
أيقونة؟ تقصد مثل أيقونة صورة (على سبيل المثال، FA)؟
افتح وحدة تحكم Rails وافحص جدول uploads للتحقق من أن المعرف = -6 مفقود:
RAILS_ENV=test bin/rails console
Upload.find_by(id: -6)
يشير الخطأ إلى أنه تم حذف السجل ذي المعرف = -6. ستحتاج إلى تحديث بيانات البذور أو التثبيتات وفقًا لذلك في بيئة الاختبار الخاصة بك.
مرحباً، أنا أواجه هذه المشكلة أيضاً، لكنني عالق قبل انتهاء التثبيت، لذلك ليس لدي bin/rails… كيف يمكنني إصلاح ذلك. ولا يمكنني الدخول إلى التطبيق (./launcher enter app) المجلد bin فارغ
@woozievert، يرجى مشاركة تتبع الخطأ التفصيلي الخاص بك
نفس الخطأ:
فشل
Pups::ExecError: cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate' فشل مع العودة #<Process::Status: pid 1962 exit 1>
موقع الفشل: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
فشل التنفيذ مع المعلمات {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
فشل التمهيد برمز الخروج 1
** فشل التمهيد ** يرجى التمرير لأعلى والبحث عن رسائل خطأ سابقة، قد يكون هناك أكثر من واحدة.
قد يساعد ./discourse-doctor في تشخيص المشكلة.
ActiveRecord::RecordNotFound: لم يتم العثور على Upload بالمعرف '-6' (ActiveRecord::RecordNotFound)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
/var/www/discourse/lib/site_icon_manager.rb:119:in `resolve_original'
/var/www/discourse/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/var/www/discourse/lib/site_icon_manager.rb:70:in `each'
/var/www/discourse/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/var/www/discourse/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:234:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
المهام: TOP => db:migrate
(انظر التتبع الكامل عن طريق تشغيل المهمة مع --trace)
لقد نشرت هنا ونسيت أن أرد عليك آسف
لقد قمت بتشغيل هذا وحصلت على nil.
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails aborted!
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails console
Loading test environment (Rails 7.1.4.1)
irb(main):001> Upload.find_by(id: -6)
=> nil
irb(main):002>
في أي خطوة أنت حاليًا؟ هل قمت باستنساخ Discourse حتى الآن؟
أنا أستخدم تثبيت دوكر
لقد صادفت هذا للتو عند إنشاء قاعدة بيانات محلية جديدة وترحيلها.
للأسف، أعتقد أن هذا تم تقديمه بواسطة FIX: reset cache after flags are seed by lis2 · Pull Request #28801 · discourse/discourse · GitHub. لم تعد عمليات الترحيل الجديدة تمامًا من البداية ممكنة الآن.
@kris.kotlarek هل يمكنك إلقاء نظرة من فضلك. أعتقد أن لمس ذاكرة التخزين المؤقت لـ Redis في المُهيئ قد يكون المشكلة.
شكرا على التقرير @NateDhaliwal
قام كريس بإصلاح المشكلة باستخدام
يجب أن نكون بخير الآن!
