Entwicklung-Installation schlägt fehl beim Ausführen von bin/rails db:migrate
Basically, I am trying to do a dev install on my Pi, following this guide. I ran bin/rails db:create, which worked fine. Then when trying to run bin/rails db:migrate, it ends by saying something about oxipng binary file not working? It tells me to either put a proper binary file or use some command (I cannot remember it exactly, I’ll tell you why).
But, um, my VNC lagged out when doing this (I think the processing was too much? I did a bin/ember-cli -u even with this oxipng thing. Anyway, I then clicked on something and all I say was a grey screen. I closed the VNC session and tried to reconnect. Nothing happened for a long time. I disconnected and reconnected my Pi (yes, force shut down. Very bad.). As such, I don’t know that oxipng message much.
Tried again to run bin/rails db:migrate, and this was the error (same error as well when running RAILS_ENV=test bin/rails db:create db:migrate):
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrating ===========
-- execute("DELETE FROM web_hook_event_types WHERE (name, id) IN (('category_experts_approved', 1901), ('category_experts_unapproved', 1902))")
   -> 0.0011s
== 20241024093027 RemoveCategoryExpertsWebHookEventTypes: migrated (0.0029s) ==
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:16:in `expire_cache'
/home/natedhaliwal/discourse-f/app/models/post_action_type.rb:42:in `reload_types'
/home/natedhaliwal/discourse-f/app/models/flag.rb:37:in `reset_flag_settings!'
(eval):78:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `eval'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:46:in `block (2 levels) in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:58:in `block in open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:57:in `open'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:36:in `block in run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activesupport-7.1.4.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/transactions.rb:212:in `transaction'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:35:in `run_file'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:26:in `block in run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/seed-fu/runner.rb:25:in `run'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse-seed-fu-2.3.12/lib/discourse-seed-fu.rb:29:in `seed'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:264:in `block (2 levels) in <main>'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:53:in `block in synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:49:in `synchronize'
/home/natedhaliwal/discourse-f/lib/distributed_mutex.rb:34:in `synchronize'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:234:in `block in <main>'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block (2 levels) in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:27:in `block in perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:44:in `block in with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/rake_module.rb:59:in `with_application'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:41:in `with_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/rake/rake_command.rb:20:in `perform'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:156:in `invoke_rake'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:73:in `block in invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:149:in `with_argv'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:69:in `invoke'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.1.4.1/lib/rails/commands.rb:18:in `<main>'
<internal:/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
bin/rails aborted!
ActiveRecord::RecordNotFound: Couldn't find Upload with 'id'=-6 (ActiveRecord::RecordNotFound)
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:119:in `resolve_original'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `each'
/home/natedhaliwal/discourse-f/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/home/natedhaliwal/discourse-f/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
Tasks: TOP => db:migrate
When running it with --trace, I get:
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails db:create db:migrate --trace
** Invoke db:create (first_time)
** Invoke db:force_skip_persist (first_time)
** Execute db:force_skip_persist
** Invoke db:load_config (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute db:load_config
** Execute db:create
Database 'discourse_test' already exists
Database 'discourse_test_multisite' already exists
** Invoke db:migrate (first_time)
** Invoke set_locale (first_time)
** Execute set_locale
** Invoke assets:precompile:theme_transpiler (first_time)
** Execute assets:precompile:theme_transpiler
** Execute db:migrate
bin/rails aborted!
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
Any thoughts on what I should do?
Hmm, die Antwort ist wahrscheinlich diese Zeile:
ActiveRecord::RecordNotFound: Konnte Upload mit 'id'=-6 nicht finden (ActiveRecord::RecordNotFound)
Hast du kürzlich ein Symbol entfernt?
Ein Symbol? Meinen Sie ein Bild-Symbol (z. B. FA)?
Öffnen Sie die Rails-Konsole und überprüfen Sie die uploads-Tabelle, um zu bestätigen, dass die ID = -6 fehlt:
RAILS_ENV=test bin/rails console
Upload.find_by(id: -6)
Der Fehler zeigt an, dass der Datensatz mit ID = -6 gelöscht wurde. Sie müssen die Seed-Daten oder Fixtures in Ihrer Testumgebung entsprechend aktualisieren.
Hallo, ich habe das gleiche Problem, aber ich stecke vor dem Abschluss der Installation fest, daher habe ich noch kein bin/rails… wie kann ich das beheben? Und ich kann die App nicht betreten (./launcher enter app), der bin-Ordner ist leer.
@woozievert, bitte teile den detaillierten Trace deines Fehlers
gleicher Fehler:
FEHLGESCHLAGEN
Pups::ExecError: cd /var/www/discourse & su discourse -c 'bundle exec rake db:migrate' fehlgeschlagen mit Rückgabewert #<Process::Status: pid 1962 exit 1>
Ort des Fehlschlags: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec fehlgeschlagen mit den Parametern {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
bootstrap fehlgeschlagen mit Exit-Code 1
** BOOTSTRAP FEHLGESCHLAGEN ** Bitte scrollen Sie nach oben und suchen Sie nach früheren Fehlermeldungen, es kann mehr als eine geben.
./discourse-doctor kann helfen, das Problem zu diagnostizieren.
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.4.1/lib/active_record/core.rb:253:in `find'
/var/www/discourse/lib/site_icon_manager.rb:119:in `resolve_original'
/var/www/discourse/lib/site_icon_manager.rb:71:in `block in ensure_optimized!'
/var/www/discourse/lib/site_icon_manager.rb:70:in `each'
/var/www/discourse/lib/site_icon_manager.rb:70:in `ensure_optimized!'
/var/www/discourse/lib/tasks/db.rake:272:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:234:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
(Vollständige Trace durch Ausführen der Aufgabe mit --trace anzeigen)
Ich habe hier gepostet und vergessen, dir zu antworten, sorry
Ich habe das ausgeführt und nil erhalten.
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb:37:in `require'
/home/natedhaliwal/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails aborted!
natedhaliwal@raspberrypi:~/discourse-f $ RAILS_ENV=test bin/rails console
Loading test environment (Rails 7.1.4.1)
irb(main):001> Upload.find_by(id: -6)
=> nil
irb(main):002>
Bei welchem Schritt befinden Sie sich gerade? Haben Sie Discourse bereits geklont?
Ich verwende Docker-Installation
Ich bin gerade auf Folgendes gestoßen, als ich eine neue lokale DB erstellt und migriert habe.
Leider glaube ich, dass dies durch FIX: reset cache after flags are seed by lis2 · Pull Request #28801 · discourse/discourse · GitHub eingeführt wurde. Brandneue Migrationen von Grund auf sind jetzt nicht mehr möglich.
@kris.kotlarek könnten Sie sich das bitte ansehen. Ich glaube, das Berühren des Redis-Caches im Initializer könnte das Problem sein.
Danke für den Bericht @NateDhaliwal
Kris hat das Problem behoben mit
Wir sollten jetzt gut sein!
