Начало работы с Postman и API Discourse
Summary
Postman is a way to easily construct and test requests against an API.
Configuring with Discourse
  1. After opening Postman, click Create Workspace:
  2. Choose Blank workspace and click Next.
  3. Title it Discourse API and select Create:
  4. Click Collections:
  5. Click Import:
  6. Paste https://docs.discourse.org/openapi.json (which is the “Download” URL shown on docs.discourse.org):
  7. Choose to import as a Postman Collection:
Create a new Environment
  1. Click on Environments and Create Environment. This will hold variables specific to the instance you’re testing. For this example, we’ll use try.discourse.org.
    • add a new variable: defaultHost with the value try.discourse.org:
    • select the try.discourse.org environment from the ⑤ Environment dropdown
Hello World!
Let’s try a request!
  1. Select Collectionscategories.jsonRetrieves a list of categories and click Send. You should see the result:
Add authentication to requests
To use the API with API key authentication:
  1. Add the following variables to this or a new environment:
    • api-username
    • api-key
    (their values must of course be valid for the site you are querying)
  2. Add a script to the collection
    Select CollectionsDiscourse API DocumentationScriptsPre-request and paste the following:
    pm.request.headers.add({
        key: "api-key",
        value: pm.variables.get("api-key")
        key: "api-username",
        value: pm.variables.get("api-username")
7 лайков
