Users are requesting to disable chat threads by default in Direct Messages (DMs), citing confusion and unnecessary complexity. MarcP initiated the discussion, noting that threads are automatically enabled in new DMs — contrary to channels, which default to no threading. sam confirmed the inconsistency and suggested flipping the default to “no threading” for DMs, allowing users to enable it per conversation if needed. Jagster and nathank echoed frustrations, including UI bugs (e.g., unread thread indicators not displaying properly) and usability issues, especially with AI chats. donaldsoncd and fokx highlighted navigation difficulties and advocated for a global disable option. Jonathan5 linked the issue to low chat adoption due to clutter. In response, lindsey confirmed the team will change the default to threading off for new DMs to align with channel behavior. davidb noted the fix is implemented via a commit and will apply to new DMs only; existing DMs remain unchanged but can be manually adjusted.
When I reply to a particular message, Discourse automatically makes this a thread. We can disable this per channel/chat basis..
How can we stop this behaviour from happening in DM’s by default (or completely)? This is very aggressive and actually making simple DM’s very complex to follow.
Yeah @lindsey I feel like our default is flipped here.
When you create a channel we default to “no threading”
When you create a DM now we default to “yes threading”. (all old DMs you have have “no threading” for extra confusion)
At a minimum I wonder if we can default to no threading, should be tiny change. Then people who need threading in a DM can click the button to enable it?
Yes, the sidebar tells I have unread thread, but it doesn’t show it.
But this an issue with AI. Chatting with real persons doesn’t create threads. I asked that some times ago and then I was told that thing now just are this way with AI. And sorry, but I really dislike that way and that’s why no one uses chat anymore with AI in my forum.
I know, I know. This is a bug or an UI issue — but I trust moderators know what to do
I’ve just encountered this again today - and I really want to disable threading for DMs by default. But can’t!!!
The vast majority of our DMs (including group chats) are well served by a single thread. Occasionally threading would be helpful, in which case we can turn it on for that chat conversation.
The present default seems bananas. I agree with Sam!
Has this fallen off the radar? I note that there are 7 votes on this Topic (which is quite a few in this category).
I thought it was a bug (after having read this topic which said that it shouldn’t be showing up unless I have threads enabled), but then I dug into my DMs and found that my most recent DM had threading enabled. I’m guessing that this was on by default because I wouldn’t have chosen to have it on.
(It’s kind of a separate thing, but if threads are turned on and it shows up in the navbar, it might make sense for it to appear below "DMs” instead of so high up.)
In slow network environment, navigating between main DM and different threads can be a pain. Also I think chat should offer an option to disable thread for all users globally.
I’d like to have threads off by default too. See Is it possible to get rid of the "My Threads" link/button?. If chat isn’t getting used a lot it’s just an extra complication and it’s unclear (in that same scenario) what the My Threads icon/button is for.
Thanks for the feedback here, folks — we’re going to switch the default here so that DMs have threading off by default so it better matches the channel defaults. We’ll share an update here once that change is complete.
It’s worth noting that this will take effect for all new DM chats initiated. Existing chats are not changed but threads can still be turned off manually within each channel’s settings.
