게시글 아래에 콘텐츠(HTML)를 추가하는 방법?
how to add content (html) below posts?
In the image, the placement is right below the like bar and link of each post
Out of curiosity, could you send the link to this topic?
I found a tutorial topic for this here.
But I’m worried that ad blockers will hide the content (html) below these posts.
this is the code i use, but if i want to change the position of the content (html) to the position right below the row : post author and date. Can anyone help me customize the position in this code ?
In the image, I am circling the location where I want to place the content using code.
  const RawHtml = require("discourse/widgets/raw-html").default;
  api.decorateWidget("post:after", helper => {
      return [
        new RawHtml({
          html: `<div id="custom-ad">
<h3>Another simple box</h3>
<p>
  Integer velit ante,
  <a href="https://meta.discourse.org/">DISCOURSE</a>
  amet tristique in, gravida at ligula. Sed gravida mauris id
  neque vestibulum semper. Suspendisse potenti. Nam
  nec maximus ligula. Ut eget semper est. Sed ornare
  sit amet justo eu rutrum. Integer sit amet facilisis ipsum.
</p>
                 </div>`
</script>
You don’t want to use widgets. See Widgets, the Widget API and their roadmap?
