Проблемы с темой Fakebook при интеграции
fakebook-theme is really attractive.
I tried fakebook-theme on my website, only with Header Search and DiscoTOC. Devices: Chrome 30.0.6723.92 (arm64) and Safiri18.1 (20619.2.8.11.10)
When using this theme, I have 4 questions.
  1. On topic list page, every topic has an unexpected square. These squares appear even switching to other scheme like Default. How can I fix it?
  1. Also, on topic list page, does right sidebar supports specific links(like ads link) or related topics instead of plain text?
  2. On topic list page, buttons looks strange. How can I fix it?
  3. On topic detail page, the bottom of the first post is unexpected below.
Thanks!
Hi Jun, welcome to Meta :discourse: :wave:
For the first question, that is the Solved plugin. Look for empty box on unsolved in site settings and uncheck the setting.
Not sure about the rest of your questions as I don’t use the fakebook theme. What device are you using?
There are topics in the Theme component category which may interest you for example Discourse Bars 🍻 🍸 (a sidebar framework) if you’re looking for places to place stuff around the page.
3 лайка
Thanks! Unexpected squares have been solved. I’ve added my website link and devices info.
