업데이트 실패: "require_message" 열이 존재하지 않습니다
Hi,
I have been running Discourse without problems for a few years. Today I tried to run an update using ./launcher rebuild app and it fails. Can I get some help decoding the errors from the log below.
Thanks
sudo ./launcher rebuild app
WARNING: Docker version 20.10.18 deprecated, recommend upgrade to 24.0.7 or newer.
x86_64 arch detected.
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20240825-0027: Pulling from discourse/base
Digest: sha256:6de68cb49198b5281f79ed9401b3fe818c854d220dcf0238549fe2f2adb19146
Status: Image is up to date for discourse/base:2.0.20240825-0027
docker.io/discourse/base:2.0.20240825-0027
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-11-07T19:34:23.535124 #1]  INFO -- : Reading from stdin
I, [2024-11-07T19:34:23.558469 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2024-11-07T19:34:23.571625 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2024-11-07T19:34:23.581705 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2024-11-07T19:34:23.592389 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2024-11-07T19:34:23.602698 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2024-11-07T19:34:23.604250 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data'                                                        in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-07T19:34:23.605604 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postg                                                       resql.conf
I, [2024-11-07T19:34:23.606565 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/p                                                       ostgresql/13/main/postgresql.conf
I, [2024-11-07T19:34:23.608107 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13                                                       /main/postgresql.conf
I, [2024-11-07T19:34:23.609566 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.c                                                       onf
I, [2024-11-07T19:34:23.612994 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_tex                                                       t_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-07T19:34:23.613568 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /et                                                       c/postgresql/13/main/postgresql.conf
I, [2024-11-07T19:34:23.614631 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/post                                                       gresql/13/main/postgresql.conf
I, [2024-11-07T19:34:23.617876 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_dura                                                       tion_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-11-07T19:34:23.621489 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/                                                       postgresql/13/main/pg_hba.conf
I, [2024-11-07T19:34:23.622082 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/p                                                       g_hba.conf
I, [2024-11-07T19:34:23.627193 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/p                                                       g_hba.conf
I, [2024-11-07T19:34:23.628520 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
I, [2024-11-07T19:34:29.881880 #1]  INFO -- : Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
I, [2024-11-07T19:34:29.882186 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres                                                       :ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-11-07T19:34:29.895227 #1]  INFO -- : File > /usr/local/bin/create_db  chmod: +x  chown:
I, [2024-11-07T19:34:29.909249 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2024-11-07T19:34:29.915646 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2024-11-07T19:34:29.916056 #1]  INFO -- : > sleep 5
2024-11-07 19:34:29.939 UTC [39] LOG:  starting PostgreSQL 13.16 (Debian 13.16-1.pgdg120+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-1                                                       4) 12.2.0, 64-bit
2024-11-07 19:34:29.939 UTC [39] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2024-11-07 19:34:29.940 UTC [39] LOG:  listening on IPv6 address "::", port 5432
2024-11-07 19:34:29.946 UTC [39] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-11-07 19:34:29.957 UTC [48] LOG:  database system was shut down at 2024-11-07 19:34:11 UTC
2024-11-07 19:34:29.975 UTC [39] LOG:  database system is ready to accept connections
I, [2024-11-07T19:34:34.920455 #1]  INFO -- :
I, [2024-11-07T19:34:34.920764 #1]  INFO -- : > /usr/local/bin/create_db
2024-11-07 19:34:35.054 UTC [58] postgres@postgres ERROR:  database "discourse" already exists
2024-11-07 19:34:35.054 UTC [58] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
2024-11-07 19:34:35.183 UTC [61] postgres@discourse ERROR:  role "discourse" already exists
2024-11-07 19:34:35.183 UTC [61] postgres@discourse STATEMENT:  create user discourse;
NOTICE:  extension "hstore" already exists, skipping
NOTICE:  extension "pg_trgm" already exists, skipping
NOTICE:  extension "vector" already exists, skipping
NOTICE:  version "0.7.4" of extension "vector" is already installed
I, [2024-11-07T19:34:36.252292 #1]  INFO -- : GRANT
ALTER SCHEMA
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
CREATE EXTENSION
CREATE EXTENSION
CREATE EXTENSION
ALTER EXTENSION
UPDATE 0
I, [2024-11-07T19:34:36.252684 #1]  INFO -- : > echo postgres installed!
I, [2024-11-07T19:34:36.256493 #1]  INFO -- : postgres installed!
I, [2024-11-07T19:34:36.265063 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2024-11-07T19:34:36.272729 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2024-11-07T19:34:36.281351 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2024-11-07T19:34:36.283273 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2024-11-07T19:34:36.284352 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2024-11-07T19:34:36.285312 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-11-07T19:34:36.293884 #1]  INFO -- :
I, [2024-11-07T19:34:36.295010 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-11-07T19:34:36.296468 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2024-11-07T19:34:36.298169 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-11-07T19:34:36.299844 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-11-07T19:34:36.301569 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-11-07T19:34:36.303376 #1]  INFO -- : > echo redis installed
I, [2024-11-07T19:34:36.307405 #1]  INFO -- : redis installed
I, [2024-11-07T19:34:36.307822 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-11-07T19:34:36.316259 #1]  INFO -- : logfile ""
I, [2024-11-07T19:34:36.316711 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-11-07T19:34:36.321345 #1]  INFO -- : > sleep 10
107:C 07 Nov 2024 19:34:36.335 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
107:C 07 Nov 2024 19:34:36.335 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=107, just started
107:C 07 Nov 2024 19:34:36.335 # Configuration loaded
107:M 07 Nov 2024 19:34:36.336 * monotonic clock: POSIX clock_gettime
107:M 07 Nov 2024 19:34:36.337 * Running mode=standalone, port=6379.
107:M 07 Nov 2024 19:34:36.337 # Server initialized
107:M 07 Nov 2024 19:34:36.338 * Loading RDB produced by version 7.0.7
107:M 07 Nov 2024 19:34:36.338 * RDB age 25 seconds
107:M 07 Nov 2024 19:34:36.338 * RDB memory usage when created 8.18 Mb
107:M 07 Nov 2024 19:34:36.369 * Done loading RDB, keys loaded: 2512, keys expired: 0.
107:M 07 Nov 2024 19:34:36.369 * DB loaded from disk: 0.031 seconds
107:M 07 Nov 2024 19:34:36.369 * Ready to accept connections
I, [2024-11-07T19:34:46.328108 #1]  INFO -- :
I, [2024-11-07T19:34:46.328719 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-11-07T19:34:46.335431 #1]  INFO -- : thpoff is installed!
I, [2024-11-07T19:34:46.335870 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail                                                        is not configured!"; exit 1; end'
I, [2024-11-07T19:34:46.478257 #1]  INFO -- :
I, [2024-11-07T19:34:46.478397 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Dom                                                       ain is not configured!"; exit 1; end'
I, [2024-11-07T19:34:46.632162 #1]  INFO -- :
I, [2024-11-07T19:34:46.632306 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must                                                        have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-11-07T19:34:46.792566 #1]  INFO -- :
I, [2024-11-07T19:34:46.792816 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-11-07T19:34:46.799857 #1]  INFO -- :
I, [2024-11-07T19:34:46.806261 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2024-11-07T19:34:46.814523 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2024-11-07T19:34:46.824323 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2024-11-07T19:34:46.833947 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2024-11-07T19:34:46.842792 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2024-11-07T19:34:46.850581 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2024-11-07T19:34:46.850759 #1]  INFO -- : Replacing # postgres with if [ -f /root/install_postgres ]; then
  rm /root/install_postgres
fi
sv start postgres || exit 1
 in /etc/service/unicorn/run
I, [2024-11-07T19:34:46.853568 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
Updating files: 100% (34680/34680), done.
I, [2024-11-07T19:34:57.445426 #1]  INFO -- : HEAD is now at 274e18622 FIX: Video uploads sometimes hang indefinitely (#28523)
I, [2024-11-07T19:34:57.445566 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-11-07T19:34:57.805189 #1]  INFO -- :
I, [2024-11-07T19:34:57.805321 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-a-gjs-ace
 - [deleted]             (none)     -> origin/better-respect-End-key-in-topics
 - [deleted]             (none)     -> origin/category-experts-approved-webhook-event
 - [deleted]             (none)     -> origin/chat-sound-respects-indicator-pref
 - [deleted]             (none)     -> origin/d-button-noautoclass
 - [deleted]             (none)     -> origin/dependabot/bundler/omniauth-google-oauth2-1.1.2
 - [deleted]             (none)     -> origin/dependabot/bundler/sass-embedded-1.77.8
 - [deleted]             (none)     -> origin/dependabot/bundler/sassc-embedded-1.77.8
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/ember-cli-deprecation-workflow-3.0.2
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/ember/test-helpers-4.0.1
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/eslint-9.7.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/sass-1.77.8
 - [deleted]             (none)     -> origin/detect-default-readonly
 - [deleted]             (none)     -> origin/dev/add-skeleton-of-section-landing-page-and-items
 - [deleted]             (none)     -> origin/dev/remove-header-widgets
 - [deleted]             (none)     -> origin/ensure_default_timeouts_for_net_http
 - [deleted]             (none)     -> origin/feature/site-text-result-selected-lang
 - [deleted]             (none)     -> origin/fix/add-user-to-user-directory-when-activated
 - [deleted]             (none)     -> origin/fix_default_value_validation_fail
 - [deleted]             (none)     -> origin/issue/fix-bookmark-clearing-reminder
 - [deleted]             (none)     -> origin/loic-drop-compiled-js-column
 - [deleted]             (none)     -> origin/mt/converter
 - [deleted]             (none)     -> origin/mt/uploads-command
 - [deleted]             (none)     -> origin/native-class-components-2
 - [deleted]             (none)     -> origin/native-class-components-3
 - [deleted]             (none)     -> origin/notifications_id_bigint
 - [deleted]             (none)     -> origin/prevent-desktop-notifications-on-mobile
 - [deleted]             (none)     -> origin/rails_7_1_upgrade
 - [deleted]             (none)     -> origin/tobiaseigen-patch-3
 - [deleted]             (none)     -> origin/tobiaseigen-patch-5
 - [deleted]             (none)     -> origin/update-composer-media-optimization-requirements
 - [deleted]             (none)     -> origin/ux/admin-plugins-ui-guidelines
   274e18622..484006056  main                    -> origin/main
 * [new branch]          0-a-dl                  -> origin/0-a-dl
 * [new branch]          add-live-reload-disable-option -> origin/add-live-reload-disable-option
 * [new branch]          add-shift-detect        -> origin/add-shift-detect
 * [new branch]          add-verbose-logging-for-google-oauth -> origin/add-verbose-logging-for-google-oauth
 * [new branch]          auto-grid-images        -> origin/auto-grid-images
 * [new branch]          chat-uppy-upload        -> origin/chat-uppy-upload
 * [new branch]          chunk-size              -> origin/chunk-size
 * [new branch]          cleanup-mobile-topic-footer-area -> origin/cleanup-mobile-topic-footer-area
 + 7f254be61...4264fe0d6 coco/generic-importer   -> origin/coco/generic-importer  (forced update)
 * [new branch]          dependabot/bundler/omniauth-google-oauth2-1.2.0 -> origin/dependabot/bundler/omniauth-google-oauth2-1.2.0
 * [new branch]          dependabot/bundler/rackup-1.0.1 -> origin/dependabot/bundler/rackup-1.0.1
 * [new branch]          dependabot/bundler/sass-embedded-1.80.6 -> origin/dependabot/bundler/sass-embedded-1.80.6
 * [new branch]          dependabot/bundler/sassc-embedded-1.80.1 -> origin/dependabot/bundler/sassc-embedded-1.80.1
 * [new branch]          dependabot/npm_and_yarn/glimmer/component-2.0.0 -> origin/dependabot/npm_and_yarn/glimmer/component-2.0.0
 * [new branch]          dependabot/npm_and_yarn/sass-1.80.6 -> origin/dependabot/npm_and_yarn/sass-1.80.6
 * [new branch]          dev-faster-tests        -> origin/dev-faster-tests
 * [new branch]          dev-nginx-conf          -> origin/dev-nginx-conf
 * [new branch]          dev/automation-scriptable-add-with-class -> origin/dev/automation-scriptable-add-with-class
 * [new branch]          dev/composer_args_simplification -> origin/dev/composer_args_simplification
 * [new branch]          dev/convert-admin-emojis-ui-to-new-layout -> origin/dev/convert-admin-emojis-ui-to-new-layout
 * [new branch]          dev/glimmer-post-menu   -> origin/dev/glimmer-post-menu
 * [new branch]          dev/port-outlet-wrapper-to-stable -> origin/dev/port-outlet-wrapper-to-stable
 * [new branch]          dev/refactor-themes-controller-to-services-part-1 -> origin/dev/refactor-themes-controller-to-services-part-1
 * [new branch]          dev/remap-enhancements  -> origin/dev/remap-enhancements
 * [new branch]          dev/remove-deprecated-respect-plugin-positional-argument -> origin/dev/remove-deprecated-respect-plugin-positional-argument
 * [new branch]          dev/use-new-filestore-download-method -> origin/dev/use-new-filestore-download-method
 + 59bf25001...8e5e61375 devcontainer            -> origin/devcontainer  (forced update)
 * [new branch]          drawer-composer-positioning -> origin/drawer-composer-positioning
 * [new branch]          events-ui               -> origin/events-ui
 * [new branch]          feature-paginate-categories -> origin/feature-paginate-categories
 * [new branch]          feature/add-user-to-topic_tags_changed-event -> origin/feature/add-user-to-topic_tags_changed-event
 + a0042745d...6d5864113 feature/bulk-dismiss-buttons-confirmation -> origin/feature/bulk-dismiss-buttons-confirmation  (forced update)
 * [new branch]          feature/custom-fields-for-existing-users -> origin/feature/custom-fields-for-existing-users
 * [new branch]          fix-safari-below-18-detection -> origin/fix-safari-below-18-detection
 * [new branch]          fix/resume_editing_pm   -> origin/fix/resume_editing_pm
 * [new branch]          glint                   -> origin/glint
 * [new branch]          issue/fix-plugin-actions-outlet -> origin/issue/fix-plugin-actions-outlet
 * [new branch]          loic-enable-rspec-rule  -> origin/loic-enable-rspec-rule
 * [new branch]          loic-experiment-model-value-type -> origin/loic-experiment-model-value-type
 * [new branch]          loic-persist-step-services -> origin/loic-persist-step-services
 + 26e2ddbde...10b203c30 loic-rails-7.2          -> origin/loic-rails-7.2  (forced update)
 * [new branch]          mt/idb                  -> origin/mt/idb
 * [new branch]          perf-chat-auto-join-take-42 -> origin/perf-chat-auto-join-take-42
 * [new branch]          post-badge-poc          -> origin/post-badge-poc
 * [new branch]          redesign-permalinks     -> origin/redesign-permalinks
 * [new branch]          render-glimmer-granular -> origin/render-glimmer-granular
 * [new branch]          revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-setting -> origin/revert-28587-revert-28321-dev/remove-create_post_for_category_and_tag_changes-sett
 * [new branch]          safari-hacks-sayonara   -> origin/safari-hacks-sayonara
 * [new branch]          sidebar-a11y-viewport-zoom -> origin/sidebar-a11y-viewport-zoom
 * [new branch]          sort-chat-channels-with-unread-threads -> origin/sort-chat-channels-with-unread-threads
   d3ad2ecda..6cd6ed5b8  stable                  -> origin/stable
 * [new branch]          tabs                    -> origin/tabs
 * [new branch]          tag-name-transformer    -> origin/tag-name-transformer
 * [new branch]          testing_debian_12       -> origin/testing_debian_12
   274e18622..484006056  tests-passed            -> origin/tests-passed
 * [new branch]          virtual-keyboard-fix-login -> origin/virtual-keyboard-fix-login
 * [new branch]          whats-new-notify-plugins -> origin/whats-new-notify-plugins
 t [tag update]          beta                    -> beta
 t [tag update]          latest-release          -> latest-release
 * [new tag]             v3.3.1                  -> v3.3.1
 * [new tag]             v3.3.2                  -> v3.3.2
 * [new tag]             v3.4.0.beta1            -> v3.4.0.beta1
 * [new tag]             v3.4.0.beta2            -> v3.4.0.beta2
I, [2024-11-07T19:34:58.945416 #1]  INFO -- :
I, [2024-11-07T19:34:58.945546 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2024-11-07T19:35:04.538466 #1]  INFO -- : branch 'tests-passed' set up to track 'origin/tests-passed'.
I, [2024-11-07T19:35:04.538640 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-11-07T19:35:04.565429 #1]  INFO -- :
I, [2024-11-07T19:35:04.565594 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-11-07T19:35:04.571229 #1]  INFO -- :
I, [2024-11-07T19:35:04.571407 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-11-07T19:35:04.577468 #1]  INFO -- :
I, [2024-11-07T19:35:04.577635 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-11-07T19:35:04.583818 #1]  INFO -- :
I, [2024-11-07T19:35:04.583984 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-11-07T19:35:04.589677 #1]  INFO -- :
I, [2024-11-07T19:35:04.589812 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-11-07T19:35:04.595224 #1]  INFO -- :
I, [2024-11-07T19:35:04.595361 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2024-11-07T19:35:04.601289 #1]  INFO -- :
I, [2024-11-07T19:35:04.601434 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-11-07T19:35:04.610769 #1]  INFO -- :
I, [2024-11-07T19:35:04.610903 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/di
I, [2024-11-07T19:35:04.619848 #1]  INFO -- :
I, [2024-11-07T19:35:04.619981 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2024-11-07T19:35:04.636483 #1]  INFO -- :
I, [2024-11-07T19:35:04.637391 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-11-07T19:35:04.663135 #1]  INFO -- :
I, [2024-11-07T19:35:04.663283 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2024-11-07T19:35:04.674349 #1]  INFO -- :
I, [2024-11-07T19:35:04.674500 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-11-07T19:35:04.687279 #1]  INFO -- :
I, [2024-11-07T19:35:04.687417 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-11-07T19:35:05.168181 #1]  INFO -- :
I, [2024-11-07T19:35:05.168344 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-11-07T19:35:05.179835 #1]  INFO -- :
I, [2024-11-07T19:35:05.180335 #1]  INFO -- : Replacing # redis with if [ ! -d /shared/redis_data ]; then
fi
sv start redis || exit 1 in /etc/service/unicorn/run
I, [2024-11-07T19:35:05.183224 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-11-07T19:35:06.292926 #1]  INFO -- :
I, [2024-11-07T19:35:06.302691 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-11-07T19:35:06.323863 #1]  INFO -- :
I, [2024-11-07T19:35:06.324325 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-11-07T19:35:06.345166 #1]  INFO -- :
I, [2024-11-07T19:35:06.345559 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2024-11-07T19:35:06.360681 #1]  INFO -- :
I, [2024-11-07T19:35:06.361834 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2024-11-07T19:35:06.362793 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2024-11-07T19:35:06.363496 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2024-11-07T19:35:06.366234 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2024-11-07T19:35:06.367840 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2024-11-07T19:35:06.368440 #1]  INFO -- : > echo "done configuring web"
I, [2024-11-07T19:35:06.381488 #1]  INFO -- : done configuring web
I, [2024-11-07T19:35:06.381959 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-11-07T19:35:08.003914 #1]  INFO -- : Successfully installed bundler-2.5.18
1 gem installed
I, [2024-11-07T19:35:08.004091 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-11-07T19:35:22.478869 #1]  INFO -- :
I, [2024-11-07T19:35:22.479564 #1]  INFO -- : > cd /var/www/discourse && if [ -f yarn.lock ]; then
  if [ -d node_modules/.pnpm ]; then
    echo "This version of Discourse uses yarn, but pnpm node_modules are preset. Cleaning up..."
    find ./node_modules ./app/assets/javascripts/*/node_modules -mindepth 1 -maxdepth 1 -exec rm -rf {} +
  fi
  su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
else
  su discourse -c 'CI=1 pnpm install --frozen-lockfile'
fi
I, [2024-11-07T19:36:21.891214 #1]  INFO -- : Detected yarn-managed node_modules. Performing one-time cleanup...
cleanup done
Scope: all 19 workspace projects
Lockfile is up to date, resolution step is skipped
Progress: resolved 1, reused 0, downloaded 0, added 0
Packages: +1828
Progress: resolved 1828, reused 0, downloaded 0, added 0
Progress: resolved 1828, reused 0, downloaded 16, added 0
Progress: resolved 1828, reused 0, downloaded 32, added 21
Progress: resolved 1828, reused 0, downloaded 119, added 156
Progress: resolved 1828, reused 0, downloaded 190, added 260
Progress: resolved 1828, reused 0, downloaded 248, added 311
Progress: resolved 1828, reused 0, downloaded 326, added 393
Progress: resolved 1828, reused 0, downloaded 363, added 428
Progress: resolved 1828, reused 0, downloaded 371, added 438
Progress: resolved 1828, reused 0, downloaded 394, added 457
Progress: resolved 1828, reused 0, downloaded 472, added 538
Progress: resolved 1828, reused 0, downloaded 539, added 606
Progress: resolved 1828, reused 0, downloaded 582, added 651
Progress: resolved 1828, reused 0, downloaded 644, added 711
Progress: resolved 1828, reused 0, downloaded 689, added 756
Progress: resolved 1828, reused 0, downloaded 705, added 768
Progress: resolved 1828, reused 0, downloaded 894, added 965
Progress: resolved 1828, reused 0, downloaded 927, added 994
Progress: resolved 1828, reused 0, downloaded 1014, added 1080
Progress: resolved 1828, reused 0, downloaded 1068, added 1140
Progress: resolved 1828, reused 0, downloaded 1123, added 1189
Progress: resolved 1828, reused 0, downloaded 1132, added 1196
Progress: resolved 1828, reused 0, downloaded 1172, added 1237
Progress: resolved 1828, reused 0, downloaded 1173, added 1238
Progress: resolved 1828, reused 0, downloaded 1179, added 1248
Progress: resolved 1828, reused 0, downloaded 1191, added 1254
Progress: resolved 1828, reused 0, downloaded 1253, added 1319
Progress: resolved 1828, reused 0, downloaded 1380, added 1445
Progress: resolved 1828, reused 0, downloaded 1399, added 1466
Progress: resolved 1828, reused 0, downloaded 1434, added 1503
Progress: resolved 1828, reused 0, downloaded 1493, added 1560
Progress: resolved 1828, reused 0, downloaded 1508, added 1578
Packages are hard linked from the content-addressable store to the virtual store.
  Content-addressable store is at: /home/discourse/.local/share/pnpm/store/v3
  Virtual store is at:             node_modules/.pnpm
Progress: resolved 1828, reused 0, downloaded 1512, added 1580
Progress: resolved 1828, reused 0, downloaded 1513, added 1580
Progress: resolved 1828, reused 0, downloaded 1527, added 1591
Progress: resolved 1828, reused 0, downloaded 1546, added 1612
Progress: resolved 1828, reused 0, downloaded 1605, added 1673
Progress: resolved 1828, reused 0, downloaded 1660, added 1731
Progress: resolved 1828, reused 0, downloaded 1718, added 1792
Progress: resolved 1828, reused 0, downloaded 1741, added 1828, done
.../core-js@3.33.0/node_modules/core-js postinstall$ node -e "try{require('./postinstall')}catch(e){}"
.../core-js@2.6.12/node_modules/core-js postinstall$ node -e "try{require('./postinstall')}catch(e){}"
.../node_modules/@swc/core postinstall$ node postinstall.js
.../esbuild@0.24.0/node_modules/esbuild postinstall$ node install.js
.../lefthook@1.8.2/node_modules/lefthook postinstall$ node postinstall.js
.../core-js@3.33.0/node_modules/core-js postinstall: Done
.../core-js@2.6.12/node_modules/core-js postinstall: Done
.../lefthook@1.8.2/node_modules/lefthook postinstall: Done
.../node_modules/@swc/core postinstall: Done
.../esbuild@0.24.0/node_modules/esbuild postinstall: Done
devDependencies:
+ @babel/plugin-proposal-decorators 7.25.9
+ @discourse/lint-configs 1.4.2
+ @discourse/moment-timezone-names-translations 1.0.0
+ @fortawesome/fontawesome-free 6.6.0
+ @glint/core 1.5.0
+ @glint/environment-ember-loose 1.5.0
+ @glint/environment-ember-template-imports 1.5.0
+ @glint/template 1.5.0
+ @mixer/parallel-prettier 2.0.3
+ @swc/core 1.9.1
+ chart.js 3.5.1
+ chartjs-plugin-datalabels 2.2.0
+ chrome-launcher 1.1.2
+ chrome-remote-interface 0.33.2
+ concurrently 9.1.0
+ ember-template-lint 6.0.0
+ esbuild 0.24.0
+ eslint 8.57.0
+ jsdoc 4.0.4
+ lefthook 1.8.2
+ licensee 11.1.0
+ lint-to-the-future 2.2.0
+ lint-to-the-future-ember-template 1.2.0
+ lint-to-the-future-eslint 2.2.0
+ magnific-popup 1.1.0
+ moment 2.30.1
+ moment-timezone 0.5.45
+ pikaday 1.8.2
+ prettier 2.8.8
+ puppeteer-core 23.7.0
+ squoosh 2.0.0
+ terser 5.36.0
+ typescript 5.6.3
Done in 58.8s
I, [2024-11-07T19:36:21.910086 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --jobs $(($(nproc) - 1)) --retry 3'
I, [2024-11-07T19:39:36.059985 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/........
Fetching base64 0.2.0
Installing base64 0.2.0
Fetching benchmark 0.3.0
Installing benchmark 0.3.0
Fetching i18n 1.14.6
Installing i18n 1.14.6
Fetching logger 1.6.1
Installing logger 1.6.1
Fetching mutex_m 0.2.0
Installing mutex_m 0.2.0
Fetching securerandom 0.3.1
Installing securerandom 0.3.1
Fetching activesupport 7.1.5
Installing activesupport 7.1.5
Fetching loofah 2.23.1
Installing loofah 2.23.1
Fetching actionview 7.1.5
Installing actionview 7.1.5
Fetching rack 2.2.10
Installing rack 2.2.10
Fetching actionpack 7.1.5
Installing actionpack 7.1.5
Fetching activejob 7.1.5
Installing activejob 7.1.5
Fetching date 3.4.0
Installing date 3.4.0 with native extensions
Fetching timeout 0.4.2
Installing timeout 0.4.2
Fetching net-protocol 0.2.2
Installing net-protocol 0.2.2
Fetching net-imap 0.5.0
Installing net-imap 0.5.0
Fetching actionmailer 7.1.5
Installing actionmailer 7.1.5
Fetching activemodel 7.1.5
Installing activemodel 7.1.5
Fetching activerecord 7.1.5
Installing activerecord 7.1.5
Fetching msgpack 1.7.3
Installing msgpack 1.7.3 with native extensions
Fetching cgi 0.4.1
Installing cgi 0.4.1 with native extensions
Fetching openssl 3.2.0
Installing openssl 3.2.0 with native extensions
Fetching css_parser 1.19.1
Installing css_parser 1.19.1
Fetching diffy 3.4.3
Installing diffy 3.4.3
Fetching digest 3.1.1
Installing digest 3.1.1 with native extensions
Fetching dry-initializer 3.1.1
Installing dry-initializer 3.1.1
Fetching excon 1.1.1
Installing excon 1.1.1
Fetching execjs 2.10.0
Installing execjs 2.10.0
Fetching uri 0.13.1
Installing uri 0.13.1
Fetching net-http 0.4.1
Installing net-http 0.4.1
Fetching faraday-net_http 3.3.0
Installing faraday-net_http 3.3.0
Fetching json 2.8.1
Installing json 2.8.1 with native extensions
Fetching faraday 2.12.0
Installing faraday 2.12.0
Fetching google-protobuf 4.28.3 (x86_64-linux)
Installing google-protobuf 4.28.3 (x86_64-linux)
Fetching reline 0.5.10
Installing reline 0.5.10
Fetching highline 3.1.1
Installing highline 3.1.1
Fetching stringio 3.1.1
Installing stringio 3.1.1 with native extensions
Fetching psych 5.1.2
Installing psych 5.1.2 with native extensions
Fetching irb 1.14.1
Installing irb 1.14.1
Fetching jwt 2.9.3
Installing jwt 2.9.3
Fetching webrick 1.9.0
Installing webrick 1.9.0
Fetching thor 1.3.2
Installing thor 1.3.2
Fetching zeitwerk 2.7.1
Installing zeitwerk 2.7.1
Fetching railties 7.1.5
Installing railties 7.1.5
Fetching memory_profiler 1.1.0
Installing memory_profiler 1.1.0
Fetching nio4r 2.7.4
Installing nio4r 2.7.4 with native extensions
Fetching ostruct 0.6.0
Installing ostruct 0.6.0
Fetching oj 3.16.7
Installing oj 3.16.7 with native extensions
Fetching omniauth-oauth 1.2.1
Installing omniauth-oauth 1.2.1
Fetching parallel 1.26.3
Installing parallel 1.26.3
Fetching puma 6.4.3
Installing puma 6.4.3 with native extensions
Fetching rexml 3.3.9
Installing rexml 3.3.9
Fetching ruby-readability 0.7.2
Installing ruby-readability 0.7.2
Fetching sprockets 3.7.5
Installing sprockets 3.7.5
Fetching tzinfo-data 1.2024.2
Installing tzinfo-data 1.2024.2
Fetching uglifier 4.2.1
Installing uglifier 4.2.1
Bundle complete! 146 Gemfile dependencies, 187 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
Post-install message from i18n:
PSA: I18n will be dropping support for Ruby < 3.2 in the next major release (April 2025), due to Ruby's end of life for 3.1 and below (https://endoflife.date/ruby). Please upgrade to Ruby 3.2 or newer by April 2025 to continue using future versions of this gem.
1 installed gem you directly depend on is looking for funding.
  Run `bundle fund` for details
I, [2024-11-07T19:39:36.060335 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2024-11-07T19:39:45.423920 #1]  INFO -- : docker_manager is already at latest compatible version
I, [2024-11-07T19:39:45.424716 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-11-07T19:39:45.435538 #1]  INFO -- : > sleep 10
1969:C 07 Nov 2024 19:39:45.487 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
1969:C 07 Nov 2024 19:39:45.488 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=1969, just started
1969:C 07 Nov 2024 19:39:45.488 # Configuration loaded
1969:M 07 Nov 2024 19:39:45.488 * monotonic clock: POSIX clock_gettime
1969:M 07 Nov 2024 19:39:45.489 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
1969:M 07 Nov 2024 19:39:45.489 # Failed listening on port 6379 (TCP), aborting.
I, [2024-11-07T19:39:55.442925 #1]  INFO -- :
I, [2024-11-07T19:39:55.443635 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
2024-11-07 19:40:01.597 UTC [2012] discourse@discourse ERROR:  column "require_message" does not exist at character 72
2024-11-07 19:40:01.597 UTC [2012] discourse@discourse STATEMENT:  SELECT id, name, name_key, description, notify_type, auto_action_type, require_message, applies_to, position, enabled, score_type FROM "flags" ORDER BY "flags"."position" ASC
rake aborted!
ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR:  column "require_message" does not exist (ActiveRecord::StatementInvalid)
LINE 1: ..._key, description, notify_type, auto_action_type, require_me...
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/db/pg.rb:69:in `exec_params'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.5/lib/active_record/connection_adapters/postgresql_adapter.rb:894:in `block (2 levels) in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:1027:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:999:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.5/lib/active_record/connection_adapters/postgresql_adapter.rb:893:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.5/lib/active_record/connection_adapters/abstract_adapter.rb:1142:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.5/lib/active_record/connection_adapters/postgresql_adapter.rb:892:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.5/lib/active_record/connection_adapters/postgresql_adapter.rb:872:in `execute_and_clear'
/var/www/discourse/lib/freedom_patches/fast_pluck.rb:40:in `select_raw'
/var/www/discourse/lib/freedom_patches/fast_pluck.rb:60:in `pluck'
/var/www/discourse/lib/post_action_type_view.rb:26:in `block in all_flags'
/var/www/discourse/lib/cache.rb:93:in `fetch'
/var/www/discourse/lib/post_action_type_view.rb:22:in `all_flags'
/var/www/discourse/lib/post_action_type_view.rb:67:in `flags'
/var/www/discourse/lib/post_action_type_view.rb:74:in `flag_types'
/var/www/discourse/app/models/post_action_type.rb:68:in `block (2 levels) in singleton class'
/var/www/discourse/app/models/reviewable_score.rb:14:in `types'
/var/www/discourse/app/models/reviewable_score.rb:21:in `reload_types'
/var/www/discourse/app/models/post_action_type.rb:43:in `reload_types'
/var/www/discourse/app/models/flag.rb:37:in `reset_flag_settings!'
/var/www/discourse/config/initializers/100-flags.rb:6:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:448:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:448:in `block in make_lambda'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:202:in `block (2 levels) in halting'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:707:in `block (2 levels) in default_terminator'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:706:in `catch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:706:in `block in default_terminator'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:203:in `block in halting'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:598:in `block in invoke_before'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:598:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:598:in `invoke_before'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/callbacks.rb:109:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.5/lib/active_support/reloader.rb:96:in `prepare!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/application/finisher.rb:74:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/application.rb:426:in `initialize!'
/var/www/discourse/config/environment.rb:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/zeitwerk-2.7.1/lib/zeitwerk/core_ext/kernel.rb:34:in `require'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/application.rb:402:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/railties-7.1.5/lib/rails/application.rb:591:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Caused by:
PG::UndefinedColumn: ERROR:  column "require_message" does not exist (PG::UndefinedColumn)
Tasks: TOP => db:migrate => db:load_config => environment
I, [2024-11-07T19:40:01.649438 #1]  INFO -- :
I, [2024-11-07T19:40:01.649982 #1]  INFO -- : Terminating async processes
I, [2024-11-07T19:40:01.650065 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 39
I, [2024-11-07T19:40:01.650139 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 107
2024-11-07 19:40:01.650 UTC [39] LOG:  received fast shutdown request
107:signal-handler (1731008401) Received SIGTERM scheduling shutdown...
2024-11-07 19:40:01.661 UTC [39] LOG:  aborting any active transactions
2024-11-07 19:40:01.667 UTC [39] LOG:  background worker "logical replication launcher" (PID 54) exited with exit code 1
2024-11-07 19:40:01.671 UTC [49] LOG:  shutting down
107:M 07 Nov 2024 19:40:01.697 # User requested shutdown...
107:M 07 Nov 2024 19:40:01.697 * Saving the final RDB snapshot before exiting.
2024-11-07 19:40:01.700 UTC [39] LOG:  database system is shut down
107:M 07 Nov 2024 19:40:01.767 * DB saved on disk
107:M 07 Nov 2024 19:40:01.767 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1973 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
a319251d257d8fcc097076b314a588960619a77de266182f68d581901d846666
1개의 좋아요
This seems like the issue.
Here’s where it got added. What is the commit of your current container? (If it’s not running, you should be able to do a ./launcher start app to get it going again.)
1개의 좋아요
Hi @pfaffman ,
Thanks for responding so quickly. While waiting I managed to clear the outdated Docker version problem, but still get the same errors.
I tried ./launcher start app, the app started and the web interface still does not load. So I’m really not sure what commit I was on. I remember seeing that I was one minor revision 3.1 beta something I think. Not even sure what release channel I am using, whatever is default when you follow the install instructions.
So I’m not sure what to… Can I rebuild using the previous commit?
1개의 좋아요
I don’t know what to tell you either. I wonder whether there’s another problem with migrations getting added/removed in other commits that’s left you in a broken state. I don’t have a good suggestion at this point.
My guess is that your database got migrated beyond the version of discourse in your container and that you’ll need a successful build to fix that.
It might be that you can add that column by hand and then try again. Or maybe make a backup, spin up a new site and restore the backup there.
Ummmmm not looking forward to that… fortunately I have daily backups.
I did notice that
 docker images -a
REPOSITORY            TAG                 IMAGE ID       CREATED             SIZE
local_discourse/app   latest              5692a781232c   About an hour ago   4.21GB
discourse/base        2.0.20240825-0027   9dc96b6115cb   2 months ago        3.38GB
<none>                <none>              b492a384cb07   4 months ago        4.18GB
discourse/base        2.0.20240602-0023   814acddaf6fd   5 months ago        3.14GB
Could I tell launcher to start one of these? Or is it better to wipe out and rebuild? If so how do I do this?
If you’re OK going to the most recent backup then I’d spin up a new server and restore the backup there.
If spinning up a new server is hard, the living dangerous approach would be to delete the postgres directories and then rebuild and restore. If you confirm that the backup will restore on another server then that would make this way a bit safer, but it sounds like your os may be beyond end of life anyway.
I spun up a new VM, installed Discourse and tried to restore the backup. I get the same error:
[2024-11-07 22:06:11] Migrating the database...
[2024-11-07 22:06:18] EXCEPTION: /var/www/discourse/lib/discourse.rb:139:in `exec': Failed to migrate database.
rake aborted!
Now what do I do?
I’m back up. Switched to the stable branch and did the restore.
I’m also facing this error in update. what should I do?
faced this problem too.
How did you fix this problem?
If you use the same solution than @TheStealth, you need to edit the app.yml file and rebuild
cd /var/discourse
nano containers/app.yml
Around line 38, change this:
  #version: tests-passed
to
  version: stable
Save the file, then:
Given the error message, I would assume it’s related to this page:
/admin/config/flags
I would delete the custom flags you might have created in the past. Then try to rebuild on the tests-passed branch again
1개의 좋아요
Thank you very much. I got my discourse running again
However I checked here and there wasnt somthing we created.
do you have any other idea?
I have an idea, though I’m not sure how well it’d work.
What if you added the missing column manually, and then rebuilt again?
how to do this?
I’m pretty sure that this is a bug. I suspect that it has to do with a migration getting removed from some commit so that future migrations fail because require_message isn’t in the table, similar to Restore failing with missing chat_mention function
1개의 좋아요
I can confirm that this update crashed my discourse and I had to restore it from backup as well. Docker_manager, however update worked without any issues as expected.
I guess we will have to wait for another update that will fix all the issues.
2개의 좋아요
Yes for me also it is broken now.. Thanks to Steven, I changed my discourse to version: stable and rebuilt the app. It is working now.
Hi @TheStealth
Thank you for reporting this bug and sorry for the inconvenience.
This problem should be fixed with this PR :crossed_fingers:
https://github.com/discourse/discourse/pull/29693
2개의 좋아요
