Aggiornamento fallito per qualche motivo?
Hi guys,
As usual, the admin dashboard told me to update, so i did.
but a message came up to update image data (which ive accessed through my digital ocean drop consol)
I entered in:
 cd /var/discourse
        git pull
       ./launcher rebuild app
It has done its thing and i noticed its come up as failed.
The error message starts from here:
I, [2022-03-30T20:44:14.785500 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all'
I, [2022-03-30T20:44:21.621280 #1]  INFO -- : wp-discourse-shortcodes is already at latest compatible version
docker_manager is already at latest compatible version
discourse-reactions is already at latest compatible version
I, [2022-03-30T20:44:21.622145 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
2022-03-30 20:44:29.148 UTC [702] discourse@discourse ERROR:  column "bookmarkable_id" of relation "bookmarks" already exists
2022-03-30 20:44:29.148 UTC [702] discourse@discourse STATEMENT:  ALTER TABLE "bookmarks" ADD "bookmarkable_id" integer
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
PG::DuplicateColumn: ERROR:  column "bookmarkable_id" of relation "bookmarks" already exists
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-3.0.0/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-3.0.0/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:47:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:46:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract_adapter.rb:696:in `block (2 levels) in log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract_adapter.rb:695:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract_adapter.rb:687:in `log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/postgresql/database_statements.rb:45:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/schema_statements.rb:611:in `add_column'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/postgresql/schema_statements.rb:398:in `add_column'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:929:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:897:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:897:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:918:in `method_missing'
/var/www/discourse/db/migrate/20220322024216_add_bookmark_polymorphic_columns.rb:5:in `change'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:867:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:9:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:851:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:850:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/connection_pool.rb:462:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:849:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1037:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1329:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1380:in `block in ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/transactions.rb:209:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1380:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1328:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1302:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1302:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1251:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1401:in `block in with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1416:in `block in with_advisory_lock_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1416:in `with_advisory_lock_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1397:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1251:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1086:in `up'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/migration.rb:1061:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.7/lib/active_record/tasks/database_tasks.rb:237:in `migrate'
/var/www/discourse/lib/tasks/db.rake:218:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:33:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:29:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:14:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:210:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
Caused by:
ActiveRecord::StatementInvalid: PG::DuplicateColumn: ERROR:  column "bookmarkable_id" of relation "bookmarks" already exists
Caused by:
Tasks: TOP => db:migrate
I, [2022-03-30T20:44:29.206010 #1]  INFO -- : == 20220322024216 AddBookmarkPolymorphicColumns: migrating ====================
-- add_column(:bookmarks, :bookmarkable_id, :integer)
I, [2022-03-30T20:44:29.207187 #1]  INFO -- : Terminating async processes
I, [2022-03-30T20:44:29.207624 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 41
I, [2022-03-30T20:44:29.207964 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 102
2022-03-30 20:44:29.208 UTC [41] LOG:  received fast shutdown request
102:signal-handler (1648673069) Received SIGTERM scheduling shutdown...
2022-03-30 20:44:29.223 UTC [41] LOG:  aborting any active transactions
2022-03-30 20:44:29.232 UTC [41] LOG:  background worker "logical replication launcher" (PID 50) exited with exit code 1
2022-03-30 20:44:29.233 UTC [45] LOG:  shutting down
2022-03-30 20:44:29.259 UTC [41] LOG:  database system is shut down
102:M 30 Mar 2022 20:44:29.265 # User requested shutdown...
102:M 30 Mar 2022 20:44:29.265 * Saving the final RDB snapshot before exiting.
102:M 30 Mar 2022 20:44:29.304 * DB saved on disk
102:M 30 Mar 2022 20:44:29.304 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 688 exit 1>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
06d69ff39a1465361099e8afc13dc9f6037ce48ca1e76e891eaa25cd374319bc
Any help pointing me in the right direction would be amazing!
Thanks,
Nick
Ciao,
questo sembra correlato a
e
sembra che questo commit non abbia risolto il problema precedente?
e
