Ошибка регистрации через Google SSO (OAuth) при использовании полноэкранного входа/регистрации
Recently set up a new discourse (Discourse v3.4.0.beta3-dev) on a fresh vps.
When I enable Google Oauth and head to the /signup page and sign up with a new Google user everything goes through Google just fine, however when the Oauth returns to my site I get a JS error in the console of:
rsvp.js:23 Uncaught TypeError: Cannot read properties of undefined (reading 'set')
    at auth-complete.js:145:38
    at Array.forEach (<anonymous>)
    at auth-complete.js:144:57
    at _ (rsvp.js:434:1)
    at y (rsvp.js:420:1)
    at invoke (backburner.js.js:282:1)
    at d.flush (backburner.js.js:197:1)
    at p.flush (backburner.js.js:358:1)
    at B._end (backburner.js.js:798:1)
    at B.end (backburner.js.js:589:1)
    at B._runExpiredTimers (backburner.js.js:905:1)
However, if I go to the /login page and do the same it works just fine.
The bug also happened when I tried to sign up here so it’s not just an issue with my install.
1 лайк
After a bit more playing around, if I disable the experimental full page login setting the signup works fine.
2 лайка
Thanks @MrSleeps for reporting this one! It should be fixed now. The social signups should work when using the experimental fullpage login.
6 лайков
This topic was automatically closed after 3 days. New replies are no longer allowed.
