전체 카테고리에서 카테고리 발췌문의 길이를 조절하는 방법
I’m using the Graceful theme (customized) (not sure if it matters), and my category descriptions are cut with the ellipsis … after a certain amount of words, and only a little more is needed to show them all fully. I haven’t found a setting. It would look a bit better if they weren’t cut off. How to achieve this?
I had to use a plugin to show them above the topic list and that pulls the full text at least. But this is for the overview screen.
