Hi there,
Is anyone having the same issue? Chat text field doesn’t work until I click on the link inside the chat ![]()
Any help will be very much appreciated!
Hi there,
Hi @Helga_Razinkova,
Which browser are you using please? I can’t repro this so far on chrome/mac.
Does it happen in private navigation? Do you know other users having the same issue?
Hi @j.jaffeux, thank you for looking into this!
I’m using Chrome too, and I see the same issue in incognito mode. The problem was reported by a client, but I’m not sure how widespread it is.
Ah nevermind, I finally reproed it ![]()
This should fix the issue: FIX: Simplify max-height calculation for chat composer by pmusaraj · Pull Request #29822 · discourse/discourse · GitHub
I see you are a hosted customer @Helga_Razinkova, will schedule a deploy of your site shortly.
Thank you so much for the help, it seems the issue has been fixed! ![]()
