Отключить «просмотры» в теме
how can i turn off the views on topic?
1 лайк
I don’t think you can turn it off entirely. If you want to hide the counter, though, you can do so with CSS.
2 лайка
do you know what the specific css code is for that?
1 лайк
You can right-click the counter and Inspect it.
2 лайка
If you just want to hide it, then I think you can use this (in common-CSS of theme or theme component):
.topic-map__contents .topic-map__stats .fk-d-menu__trigger {
    display: none;
If you want to do it for specific category:
.category-[your-category-slug] {
    display: none;
…and yes, I pretty much did what @NateDhaliwal said above to get that. The link he posted above tells you how to make those kind of modifications.
5 лайков
