Something has changed, and quite recently.
Normal user, happens when user owns that topic: second consenqutive post gives this. Nagging should pop up with third post and get a room setting is five. So what does trigger this?
Do you use the no bump plugin?
Yes I do (if Iām remembering right
). It has worked before. But that is quite easy to test.
Thanks. it was no bump indeed. And there was that TL2 limit too I was wondering. Well, it is too aggressive so it will go.
I must learn how to search Github ![]()
