Пожалуйста, подождите, пока другие пользователи не примут участие, прежде чем отвечать
Something has changed, and quite recently.
Normal user, happens when user owns that topic: second consenqutive post gives this. Nagging should pop up with third post and get a room setting is five. So what does trigger this?
1 лайк
Do you use the no bump plugin?
8 лайков
Yes I do (if I’m remembering right :face_with_peeking_eye:). It has worked before. But that is quite easy to test.
Thanks. it was no bump indeed. And there was that TL2 limit too I was wondering. Well, it is too aggressive so it will go.
I must learn how to search Github :thinking:
2 лайка
