I tried enabling the “embeddings module,” but I got the same error as before: “Sorry, an error has occurred.” Other AI features are running fine, though. Could it be something wrong with my settings, or is there something else I should check?
Yeah, I agree configuring embeddings today is complicated, even when documented, I tried configuring this @Falco / @Roman and got:
NoMethodError (undefined method `instance' for class DiscourseAi::Inference::GeminiEmbeddings)
lib/site_settings/type_supervisor.rb:287:in `validate_value'
lib/site_settings/type_supervisor.rb:168:in `to_db_value'
lib/site_setting_extension.rb:433:in `add_override!'
lib/site_setting_extension.rb:678:in `block in setup_methods'
lib/site_setting_extension.rb:500:in `public_send'
lib/site_setting_extension.rb:500:in `set'
lib/site_setting_extension.rb:513:in `set_and_log'
app/services/site_setting/update.rb:65:in `save'
lib/service/base.rb:148:in `instance_exec'
lib/service/base.rb:148:in `call'
lib/service/base.rb:443:in `block in run!'
lib/service/base.rb:443:in `each'
lib/service/base.rb:443:in `run!'
lib/service/base.rb:436:in `run'
lib/service/base.rb:295:in `call'
lib/service/runner.rb:146:in `result'
lib/service/runner.rb:131:in `call'
lib/service/runner.rb:126:in `call'
lib/service/base.rb:296:in `call'
The good news though is that we are working on a revamp of all our embedding config, moving this to a bug report.
Revamp work is undergoing and landing in the next weeks, will update here when it’s ready.
Things will definitely get better once we revamp embedding config, but in the meantime, this should fix the issue:
