Добавление кнопок «Нравится» и «Не нравится» и встроенных ответов в тему Redditish
Feature Request: Like/Dislike Buttons + Inline Replies
Hi everyone!
I’m using the Redditish theme and looking to add:
  1. Like/Dislike Buttons similar to Reddit/Facebook for quick reactions.
  2. Inline Replies: Show 2 comments directly under posts on the main screen for better context.
Here’s an example of the current setup:
Questions:
  • Can this be done using Discourse settings or plugins?
  • Any tips to implement inline replies while keeping the layout clean?
Thanks for your help! :blush:
2 лайка
Yes these things are possible, but you may need to do some dev or go to Marketplace to get customisation like this done, as it’s a little involved.
Yes, it can be done, see Topic List Previews, where you can Like from the Topic List directly.
yes, see: Topic List Latest-Post Excerpt for an example.
For a client, I’ve once implemented a list of thumbnails to the Topic List that includes the latest images from the Topic.
3 лайка
That doesn’t work with Topic List Previews, right?
No, just pointing out it can be done.
1 лайк
You could contrive dislike buttons with Discourse Reactions
But you can’t operate those on the Topic List? (I think that’s what the OP is referring to)
1 лайк
Exactly, I want it to be shown on the main feed like the topic page itself.
1 лайк
I’m not sure you’ll get far with a feature request here – this isn’t something that we will build. You are likely better off posting in the Marketplace.
5 лайков
Oh. I didn’t get that. Passing judgement on a topic that you haven’t read is pretty much the opposite of Civilized Discussion. :slight_smile:
5 лайков
Hahaha, true! But since I’m using a Redditish theme, it will probably show some small to medium-sized posts on the topic page itself.
1 лайк
I worked on it myself in the end. I did look around to see if any plugins or components were available, but nothing quite fit, so I decided to code it myself. I also had a chance to check out the marketplace, it’s really impressive!
3 лайка
Brilliant! Glad you got it sorted.
In that case I’ll move this out of Feature and into Support so the discussion isn’t lost.
2 лайка
Sure sure, that would be great.
2 лайка
