미읽음 표시가 관련이 없어도 최신 게시물과 알림을 미읽음으로 표시합니다
I was a little confused when I used the mark unread feature recently. I clicked the button at the bottom of the topic so I could get back to it later.
At first, everything seemed to work as expected: the topic was added to /unread, I had an indicator in the sidebar, and there was an unread count next to the topic. However, I noticed there was also an unread notification about a like.
When I opened the topic, all the unread indicators disappeared, but the one for the like remained.
It turns out this is connected to a post from May: DiscoTOC - automatic table of contents - #434 by Moin. The notification about the like was also created in May.
How is “mark unread” expected to work? Should it mark the last post in the topic as unread? Should it mark the latest notification as unread? Should both happen if they are about the same post, for example, because you were mentioned in the latest post? Should both happen if the notification is about a post you wrote and received a like six months ago?
2개의 좋아요
I’m an avid Defer (how it used to be called :sweat_smile:) user and this quirk has always bothered me.
Whenever there’s a mention / quote / assign (or anything that triggers a notification) in the topic, it will be re-triggered when you click “mark unread” :slightly_frowning_face:
I’ll have a quick look :eyes:
1개의 좋아요
Was made aware that this was indeed a feature :sweat_smile:
Marking a topic as unread will re-trigger the last notification in that topic :man_shrugging:
그러면 이 문제를 #contribute:feature로 옮기고, 좋아요가 제외되도록 요청해야 하나요?
(누군가 ask.discourse에 이것이 기능 요청임을 알려줘야 해요 :slight_smile: )
