Перемещение отгрузок вызывает ошибку
Message
PG::UniqueViolation (ERROR:  duplicate key value violates unique constraint "post_timings_unique"
DETAIL:  Key (topic_id, post_number, user_id)=(43481, 51, 9553) already exists.
lib/mini_sql_multisite_connection.rb:109:in `run'
app/models/post_mover.rb:479:in `copy_shifted_post_timings_from_temp'
app/models/post_mover.rb:137:in `handle_moved_references'
app/models/post_mover.rb:108:in `move_posts_to'
app/models/post_mover.rb:35:in `block in to_topic'
app/models/post_mover.rb:35:in `to_topic'
app/models/topic.rb:1308:in `move_posts'
app/controllers/topics_controller.rb:1415:in `move_posts_to_destination'
app/controllers/topics_controller.rb:917:in `move_posts'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:403:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:26:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:360:in `call'
Backtrace
rack-mini-profiler (3.3.1) lib/patches/db/pg.rb:110:in `exec'
rack-mini-profiler (3.3.1) lib/patches/db/pg.rb:110:in `async_exec'
mini_sql (1.6.0) lib/mini_sql/postgres/connection.rb:217:in `run'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:38:in `block in run'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:34:in `block in with_lock'
activesupport (7.2.2.1) lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:34:in `with_lock'
mini_sql (1.6.0) lib/mini_sql/active_record_postgres/connection.rb:38:in `run'
mini_sql (1.6.0) lib/mini_sql/postgres/connection.rb:196:in `exec'
activerecord (7.2.2.1) lib/active_record/connection_adapters/abstract/transaction.rb:616:in `block in within_new_transaction'
activerecord (7.2.2.1) lib/active_record/connection_adapters/abstract/transaction.rb:613:in `within_new_transaction'
activerecord (7.2.2.1) lib/active_record/connection_adapters/abstract/database_statements.rb:361:in `transaction'
activerecord (7.2.2.1) lib/active_record/transactions.rb:234:in `block in transaction'
activerecord (7.2.2.1) lib/active_record/connection_adapters/abstract/connection_pool.rb:421:in `with_connection'
activerecord (7.2.2.1) lib/active_record/connection_handling.rb:296:in `with_connection'
activerecord (7.2.2.1) lib/active_record/transactions.rb:233:in `transaction'
actionpack (7.2.2.1) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:226:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
i18n (1.14.6) lib/i18n.rb:353:in `with_locale'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:77:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `block in instrument'
activesupport (7.2.2.1) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `instrument'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:76:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.2.2.1) lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:163:in `process'
actionview (7.2.2.1) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.2.2.1) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (7.2.2.1) lib/action_controller/metal.rb:335:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `each'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:896:in `call'
rack (2.2.10) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.10) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.10) lib/rack/head.rb:12:in `call'
actionpack (7.2.2.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.10) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.10) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster (2.20.0) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.2.2.1) lib/rails/rack/logger.rb:41:in `call_app'
railties (7.2.2.1) lib/rails/rack/logger.rb:29:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/request_id.rb:33:in `call'
rack (2.2.10) lib/rack/method_override.rb:24:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/executor.rb:16:in `call'
rack (2.2.10) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties (7.2.2.1) lib/rails/engine.rb:535:in `call'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.10) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.10) lib/rack/urlmap.rb:58:in `each'
rack (2.2.10) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Env
HTTP HOSTS: -----
After updating to this build version yesterday, I am getting an error while trying to move posts. The error logs are as above. What can I do?
This is only part of the traceback - can you post the complete error?
You should be able to find more in the /logs URL as admin.
2 лайка
I just rebuilt discourse but I keep getting the error (./launcher rebuild app)
Message
Backtrace
Env
HTTP HOSTS: -----
Can anyone help? Similar topics are starting to pop up on the forum and I can’t move them :frowning:
The problem was solved by rebuilding. You can close the topic.
1 лайк
