Пользовательский тип записи урока TutorLMS — связанная запись Discourse не сохраняется [решено]
Hey guys
I found this thread with similar issue like the one I am experiencing: Discourse Publishing Link for Custom Post Type Disappears
I am using TutorLMS WP plugin which registers its lesson Custom post type
I can connect a Lesson post to an existing topic and post the content to Discourse. But after reloading the wp editor, the topic is not linked anymore.
@angus if necessary, I can give you access to our Staging to reproduce the issue.
Solved it via
function add_custom_fields_support_to_lesson() {
    add_post_type_support('lesson', 'custom-fields');
add_action('init', 'add_custom_fields_support_to_lesson', 11);
3 лайка
