Unstar all badges
The discussion revolves around the “Unstar all badges” theme component by NateDhaliwal, designed to unstar all favorited badges for a user. The component was created in response to a user issue where un starring badges via the console was difficult, especially on mobile NateDhaliwal. It uses a script to fetch the user’s badges and unstar those marked as favorites. The component includes a repository link, install guide, and a preview. Moin notes that the underlying bug has been fixed, making the component potentially obsolete. In response, NateDhaliwal has added an end-of-life tag to the component, indicating it will no longer be maintained.
Install this theme component
After reading this topic, I realised that it may not be very easy for users to open the console, especially on mobile. To help that, I made a simple Theme Component to do this.
Then once the button is clicked:
I used the code here:
to make this component.
I think the bug was fixed, so hopefully the component is no longer needed.
Going to add a end-of-life on this.
