Результаты публикации ссылок с ошибкой веб-сервера
Heya!
On forum.creative.gimkit.com, when I try posting a link, using the “insert hyperlink” feature, this screen shows up shortly after:
A reload doesn’t work, it’s been happening for a month now. It’s so annoying and I can’t fix it. Pls help, thanks!
Also, I’m on the chrome web browser.
If it’s not happening here on meta or try.discourse.org, you may want to see if it happens on other browsers/devices and contact the admins of gimkit. If it happens only on gimkit, it’s probably on their end :slight_smile:
4 лайка
You can try safe mode and see if it persists.
3 лайка
Also, if you ever notice a browser crash, I recommend:
  1. Try a second browser (e.g., Firefox) to confirm if it is browser-specific.
  2. Most importantly, update the browser to the latest version.
  3. Run the browser in browser safe mode with all extensions disabled.
3 лайка
I’ve tried that. Didn’t work.
Now it happens with polls.
Does it also happen at try.discourse.org?
1 лайк
Are you the admin there? Are there unsupported plugins? Do you see anything in /logs?
@Moin and @Canapin it seems to be forum specific. try.discourse.org/ is working fine.
No
sorry, i’m not the most advanced and don’t know what you are talking about :sweat_smile:
@sam, it happens on just that forum.
Did you do this?
2 лайка
I figured out that it only works on this device and this forum. Also, trying to contact admins has gotten me nowhere D:
It turns out this is just a matter of the forum being old, the forum recently got updated and this stopped.
Thanks for trying to help.
1 лайк
