Добавить кнопку выхода в шапку для тем Discourse
:information_source: Summary Add a logout button in header
:eyeglasses: Preview GitHub - pushpinder6805/logout-header
:hammer_and_wrench: Repository REPOSITORY_LINK
:question: Install Guide How to install a theme or theme component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
A button in header to logout users
Screenshots…
Detailed description…
To remove logo
.logout svg{
    display: none;
To remove text
.logout span {
display:none;
Hello :wave: it looks like this component is empty and doesn’t do anything in this state…
2 лайка
+1, I can reproduce this error.
1 лайк
Please wait updating code
1 лайк
I have unlisted this topic until code is provided.
3 лайка
i have added the code , please list the topic
please check
Installed and checked; it works perfectly fine. Just two suggestions:
  1. It would be great to have either the logout text or the logout icon, but not both.
  2. In the Install this theme component section, it would be better to include only the repository link for easy installation.
I’ve attached the snippet below for your reference.
There could be some need to tune up a bit.
iPad:
iPhone:
Could you add an option to cancel the text? Thank you.
@Monikas I’ve opened a PR to add a setting to do just that:
1 лайк
