고정/고정 해제 버튼에 대한 접근 권한 제한 방법
i try this code in header
document.addEventListener("DOMContentLoaded", function() {
    setTimeout(() => {
        let userTrustLevel = parseInt(Discourse.User.current().trust_level);
        if (userTrustLevel < 4) {
            document.querySelectorAll(".pin-topic, .unpin-topic").forEach(button => {
                button.style.pointerEvents = "none";
                button.style.opacity = "0.5";
                button.title = "You don't have permission to pin topics";
    }, 1000);  complet
and in css
.d-header-icons .pin-topic,
.d-header-icons .unpin-topic,
.controls .pin-topic,
.controls .unpin-topic {
    display: none !important;
but simple user with trust 1 or 0 can tap to pin button and can see it.
Automatically unpin topics when the user reaches the bottom by default. this is off
Automatically unpin topics when the user reaches the bottom. this is off
Hey, welcome! :wave:
Are you talking about these buttons?
You can hide the buttons with CSS only.
Install first this component: CSS Classes for Current User's Groups. It will add the current user group names, e.g., group-<name>, into the <body> element.
Then you can target anything:
:not(.group-trust_level_4) #topic-footer-buttons .pinned-button {
  display: none;
Also note there are several places a topic can be pinned/unpinned:
