Как получить все темы из конкретной категории с использованием параметров offset/page в запросе API?
I have found an API which can list all the topics from a specific subject (whose slug is “mlt-kb”) from between a certain date range. Here is the endpoint:
https://{default_host}/search.json?q=%23courses%3Amlt-kb%20after%3A2024-09-24%20before%3A2024-12-29
But this URL doesn’t list all topics. It only lists the first 50 topics. There must be some other parameter like offset or page…but I cannot understand how to add them to this URL. Can someone figure this out?
Thanks in advance!
As always: If this is possible using UI, try Reverse engineer the Discourse API
2 лайка
You can use this - https://docs.discourse.org/#tag/Search/operation/search (scroll down!)
You’ll see that besides ?q, we also have ?page, so…
https://{default_host}/search.json?q=%23courses%3Amlt-kb%20after%3A2024-09-24%20before%3A2024-12-29&page=1
2 лайка
If you want them all at once you could Run Data Explorer queries with the Discourse API
1 лайк
There’s a script example that loops page results here:
But as Jay said, depending on your goal, using data explorer might be a way better solution if you’re admin.
