Интеграция SSO в DiscourseConnect с входом через Google
Hello,
I configured DiscourseConnect SSO and it worked correctly for me - I can log in using our own login provider. However, I realized that DiscourseConnect SSO completely replaces the Discourse authentication as described in the documentation.
My question is: how can I use Google login, local login, and our custom company provider together?
I saw that there is a Discourse VK Authentication plugin. Is there a way to install the Discourse VK Authentication plugin on our standard plan, or how can we resolve our problem in a different way?
Best regards,
1 лайк
This is currently not possible. The typical recommendation is to allow the various login methods on your DiscourseConnect login provider, and have users route through there.
The standard plan has a fixed set of plugins. You can take a look at Plugin directory | Discourse - Civilized Discussion to see what plugins are offered on which levels.
3 лайка
