This is the old template I’m trying to elminate and move it to a Glimmer Component
{{#if model.showLocationControls}}
{{add-location-controls
location=buffered.location
categoryId=buffered.category.id
{{/if}}
Lower down, there is simply a this.set("location", location); which appears to exhibit two way binding.
This works fine.
Accessing the buffer with buffered provides the necessary connectivity to pass up changes to location.
The challenge comes when when using a replacement Glimmer Component:
export default class EditLocationDetails extends Component {
@action
updateLocation(location) {
this.args.outletArgs.buffered.location = location;
<template>
{{#if this.args.outletArgs.model.showLocationControls}}
<AddLocationControls
@location={{this.args.outletArgs.buffered.location}}
@category={{this.args.outletArgs.buffered.category}}
@updateLocation={{this.updateLocation}}
{{/if}}
</template>
Now the attribute can be updated, but it doesn’t stick, presumably as its a data down Glimmer argument.
What am I missing?
Is there an action I can access that allows me to pass up the change?
