I used upcloud in the past and I thought they were fine. Performance seemee to be good. I’m currently using Phoenix NAP and have a inexpensive dedicated server from them which more than meets my need. Needed their help a couple of times because I messed up the OS and they were more than willing to jump in and help out with a reload or whatever. Very responsive, they call and verify who you are and what your site is. Overall a very good experience. https://phoenixnap.com
I use GCP for my forum. Inexpensive, and it’s great. The free tier gives you a e2-micro server for free, but the resources are really low, so if you have the patience to wait 3 hours for a rebuild, you can do that (for the free plan).
DO looks great and Contabo looks very worth it.
More details can be found in the guide @Lilly linked above.
Why? I’m living in Finland, northern Europe, and it doesn’t play any roll if I’m using center in San Francisco, London or anywhere in Europe. Only reason I’m using nowadays Helsinki with Hetzner is I want to support businesses located in Finland.
But sure, I’ve heard that reason before, and everytime from US. So I wonder if this is a hype or is there really so bad connections that nearby centers are really needed.
Or maybe it’s so good there that we have no idea how bad it actually is out here
My only experience is with more exotic countries. We had a customer from Egypt and the connectivity anywhere outside of Egypt was not good. We made it with an EU based Azure in the end (the US worked much worse for them) but still image uploads etc. were not so great in Egypt. This was something else than Discourse, therefore we needed Azure.
Aren’t you sitting on a transatlantic optical cable out there ?
I know this is very much 1st world point on view, and because of that it may be totally wrong, but I wouldn’t compare Egypt and its rural areas and USA. But again — I don’t know and just weaknesses or lacking of mobile coverage in USA is quite often shock to me. I understand it in deserts and large wilderness, but still.
But I’m curious to know if connections are really that bad in USA that location of a data center really plays a significant role.
